Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 20, 2017 at 11:08 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    King's wait time right now is pretty long. Up to 3 months i think. And there was or is a big GB on Kings on here right now so that will slow things down a bit.
  2. Mar 20, 2017 at 11:08 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Try DownSouth MotorSports. I don't know what kind of stock they have, but I imagine they might have a set of 8" kings they can rebuild for your application. I hear you get good stuff if you tell them to suck your D as well
  3. Mar 20, 2017 at 11:15 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    http://stores.mcmfablv.com
    MCM might have some ADS coilovers in stock
    nfs257 likes this.
  4. Mar 20, 2017 at 11:15 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    If you get the TC kit, they use the same coilover for the 3.5 and the 2. Did you get an LT kit already?
    Coot
  5. Mar 20, 2017 at 11:19 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    That's a negative on the approach pattern ghost rider, not the same CO's for +2 and +3.5. LT uses an 8" stroke and TC for example with the +2 kit spec's a mid sized 6" ish stroke shock with a taller lower coil seat etc.
  6. Mar 20, 2017 at 11:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Highly recommend some ADS coilovers. And Matt can get you some im sure.
    Just as good if not better than kings
  7. Mar 20, 2017 at 11:28 AM
    TacoAC
    TacoAC Well-Known Member
    Cali
    DCSB In Progress
    Has anyone here that has an 05-11 tacoma done a 12-15 front end conversion? Like the lights, grill only? wouldn't need the lower bumper since I have a tube bumper and plan to cut off the front cross member.
  8. Mar 20, 2017 at 11:29 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Not sure how it is with other companies...but with TC the coilovers are the same as they are in the same locations on the LCA. I was surprised to find this out too, but yea with them you do have that option.
    Coot
  9. Mar 20, 2017 at 11:38 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Alright, I just called TC and you are correct. I swear to the dirt gods that their +2 kit used a funky custom shock with a lower rod end spacer and raised coil seat...I can vividly picture it. They did clarify that neither kit uses an 8" CO, both can only use their custom King or Fox for those kits only.
    Coot83[QUOTED] and ls1 prerunner like this.
  10. Mar 20, 2017 at 11:40 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Its all good man, I literally just called them too before responding and asked if they used the same stroke on the coilover for both 2+ and 3.5. I didn't really believe it until he told me they use the same locations which would make sense that the coilover is transferable amongst the two.
    I would think any other company that offers both sizes would use a different coilover though.
    Coot
  11. Mar 20, 2017 at 11:41 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    IIRC the "custom" coilovers on TC and Burg kits are running different top caps to reduce the length of the shock.
    Coot83 likes this.
  12. Mar 20, 2017 at 11:42 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yup for sure, I think most other manufacturers design their kits around a standard 8" coil over and then just tweak top caps etc.
  13. Mar 20, 2017 at 11:43 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yup, I think Dirt King uses that too it's the " overcap " right ?
    ls1 prerunner[QUOTED] likes this.
  14. Mar 20, 2017 at 11:43 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I almost wonder is TC losing any possible gains from their 3.5 kit by having the same coilover location on their arm as the 2+? Im sure they have a good reason behind doing it this way, but still puzzles me as well.
    Coot
  15. Mar 20, 2017 at 11:54 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I got some 8" c/o's from @dirt addiction that he ran with his do kit. They were cap over but had +1 rod ends instead of the +2's that tc uses. Not sure if he got them from DK or not, but I'm sure he can shed more light on it
  16. Mar 20, 2017 at 11:54 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    The 3.5 kit was developed before the +2 kit
    tubbsisland likes this.
  17. Mar 20, 2017 at 12:00 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Thinking about it some more...I bet TC does that to get the lower CO bolt away from the CV boot ? My Solo +2 kit uses a standard 8" and let's just say that shit comes real close to not playing well with others.
  18. Mar 20, 2017 at 12:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. CV joints bind before the shock does. And then the ball joints.
  19. Mar 20, 2017 at 2:18 PM
    Tbasch
    Tbasch Well-Known Member
    Tanner
    Orange County, California/ Forth worth, Texas
    2008 DCSB Tacoma
    https://www.filthymotorsports.com/2_5_King_Coilover_Shocks_p/king-pr25co.htm Try this it says 2-3 week wait time id email them though. :thumbsup:
  20. Mar 20, 2017 at 2:21 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Just purchased this guy: https://www.amazon.com/gp/product/B01MYRAPKK/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    shes being installed as we speak along with a brand new ps hose assembly, my banjo cracked and it's been spewing ps fluid all over.
