Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 14, 2017 at 10:52 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    If you are getting bypasses the adjusters would become worthless.
  2. May 14, 2017 at 10:58 PM
    tetten
    Andy
    Socal
    They will work, but out of the box don't do much, and with a tuned bypass you likely won't feel the difference between open and closed all the way.
    erok81[QUOTED] likes this.
  3. May 14, 2017 at 10:58 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Why would you need an adjuster when you literally use a Allen key to adjust your compression with a bypass? Lol
    erok81, Tbasch and tetten like this.
  4. May 14, 2017 at 11:06 PM
    tetten
    Andy
    Socal
    With the IFP position based control of a bypass you won't get any use out of compression adjusters. All compression adjusters do is meter the oil that enters the reservoir that is displaced as the rod enters the shock on the compression stage of a stroke. I would guess if you tried to close up on a compression adjuster while running a bypass it would just shift a tiny bit more work to the bypass. I'm just speculating there, and could definitely be wrong on how that energy transfer (if any) would work.
  5. May 14, 2017 at 11:08 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Same here. I just started getting into trucks and the stuff that goes with it a couple years ago. All my friends are city people so I'm on my own in trying to learn besides the people I meet on TW - a great resource for people like us who are learning this stuff w/o being able to talk to knowledgable people face to face.
    -40 and erok81[QUOTED] like this.
  6. May 14, 2017 at 11:36 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Your builds on cars are awesome and I'm in the same boat - I can do everything on a guitar that I wanted to learn. Worked as a construction worker for years so most things around the house are no problem and I can record, edit, and write music, but for me the world of vehicle maintenance and mods is new. Between the maintenance and suspension / long travel forum there's a ton of stuff I've learned over the last two years. All I need now are time and money and I can put my knowledge to use. :p lol
    Here's a wiring job I basically did from scratch
    Now I want to be able to build a truck to that level.
    jubei likes this.
  7. May 15, 2017 at 1:21 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I think you need a little more copper shielding...
    Dalandser[QUOTED] likes this.
  8. May 15, 2017 at 1:27 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol believe it or not I had this same setup on my other guitar and I'd get sounds from touching the neck pickup adjustment screws. I had the same pickups in that one too so I was wondering what the issue could be since that one had come from the factory with the pickups in them. I thought it might be a microphonics from a bad wire / pickup, but after some googling I found that a lot of guys got that sorted out with shielding the whole back of the pickguard. Sure enough it worked once I shielded it the way I had on this guitar.
  9. May 15, 2017 at 1:37 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    A good power conditioner to plug your amp and pedals into makes a huge difference too. If you eliminate the dirty power coming in it knocks a ton of noise down. Using higher end custom shop pickups like the Texas Specials helps a lot too. Even the American pro series pick ups suck by comparison to the hot wound 50's and Texas Specials IMO.
  10. May 16, 2017 at 10:14 AM
    Large
    Large Red
    I have a potentially noob question - if I wanted to link the rear do the trailing arms have to come from the bottom side of the axle? Seems like I would lose ground clearance.
  11. May 16, 2017 at 10:51 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    You don't have to, but it all goes into set up for anti squat and squat.
  12. May 16, 2017 at 10:54 AM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    is center under the axle normal? or rotated to the front a bit more common?
  13. May 16, 2017 at 10:55 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    It will depend on the style links you use and where you plan to mount the coilovers/shocks. Setup like and rock crawler or pro2 truck you won't lose and ground clearance compared to a dmz sua kit. But running canoe style trailing arms will cost you to lose clearance reguardless of if the links are mounted to the bottom of the axle housing or in front of it. If you do more crawling than going fast sua may be the better choice.
  14. May 16, 2017 at 10:57 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    They are 50/50 I think under the bottom is easier for someone not familiar with suspension geometry to setup but in front offers more clearance. Most people linking their truck aren't worried too much about clearance. Most guys aren't rock crawling their desert truck.
    FlapJack935[QUOTED] likes this.
  15. May 16, 2017 at 11:01 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Not necessarily the bottom but downward from center hanging below a bit. From the research I did and the design calculators there was no way to make it work right without the tabs hanging down at least a couple inches. Google 3 link or 4 link suspension design there is a ton of info out there to read. Download the calculators you will find and spend the next month learning and playing with dimensions.
    Super basic explanation is that you must have a certain amount of separation between your upper and lower links at both the axle and the front end of the links too. In order to maintain a minimum required separation at the front of the links you end up with a separation at the axle of 8"-11" minimum at the axle. Within that range you can adjust the other pieces in the calculator to achieve good #'s. It's a super complex puzzle but those calculators let you play with it and figure it out.
  16. May 16, 2017 at 11:08 AM
    Large
    Large Red
    Good info here, thanks. This won't happen for a while, if at all. I just want to know my options.
  17. May 16, 2017 at 11:10 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    Simple baseline starting numbers are 25% of your tire diameter should be the distance between your upper and lower link mounts at the axle. And 50% of that number should be the verticals distance between your upper and lower link mounts at the frame. With that said link geometry is all about compromise and packaging. Figure out you center of gravity, the instant center you desire, as well as roll center and anti squat. Then go from there figuring out what will needed to be adjusted to fit.
    The biggest benefit to running the lower link mounts below the axle is that your upper link mounts won't need to be as tall which is important if your keeping your stock bed and trying to gain more bump than the off the shelf sua kits
    Dalandser and whitetoblack like this.
  18. May 16, 2017 at 7:14 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Anyone know if a 3.0 king shock will fit in the stock 3rd gen taco shock housing?
    Got a +2 kit going on the truck and have been looking at getting 3.0 sho is instead of the 2.5
  19. May 16, 2017 at 7:54 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    2.5 will be plenty for a bolt in application
    06HAOLE and Tbasch like this.
  20. May 16, 2017 at 8:01 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    That's good to know
    But I was just curious :)
    I drive like a maniac so I can't see a reason why having more would be a bad thing
