Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 28, 2017 at 10:03 AM
    DirtRev.
    DirtRev. Kick the tires and light the fires...
    Oregon
    95 4x4 LT Tacoma
    Blood, Sweat, and Beers
    You are correct in wanting to be in a good range of bump vs droop travel. But your looking at it wrong the goal is not to adjust where you sit in travel spectrum using preload that is made for fine tuning adjust it with proper spring height/rate then make minor adjustments with the preload. Hopefully that makes since and I think everyone can agree with this. (Sometimes it takes a couple tries to get correct springs)
    IronPeak likes this.
  2. Jun 28, 2017 at 10:07 AM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    I'm not bashing in anyway. If your running a 8" coilover I think the recommended rate is 600# but I'll let others chime in. My vote is to cut up a brand new truck and go all out. That's what I did so don't be a pussy and go to town. Oh and bypasses or get the fuck out
  3. Jun 28, 2017 at 10:15 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Comparing to trophy trucks is apples to oranges. Tube chassis with tons of travel they can can have a low ride height but still have 12" of uptravel left, bolt on LT doesn't have that option. I would shoot for 60uptravel/40 down. Gives you enough travel before you hit bumps, but you still have some down travel.
  4. Jun 28, 2017 at 10:29 AM
    DirtRev.
    Oregon
    95 4x4 LT Tacoma
    If you want the 50/50 or 60/40 up vs down travel make that your goal and then think of it as making large adjustments with springs and then once your close to where you wanna be then fine tune with preload to get it perfect.
    jubei likes this.
  5. Jun 28, 2017 at 10:40 AM
    dirt addiction
    Flagstaff
    Once again your argument is invalid. You can't use the dirt bike setup argument, The tire is directly connected to the shock. Not the case on your truck, just because you only have 4"of shaft showing that does not mean you have 4" of up travel. See what I'm saying? 4" of shaft could equal 8" of travel, obviously you want the most amount of up travel and a 60/40 split is ideal. But on a kit you have other factors to consider, tire clearance at bump, ground clearance at bump etc. does that help?
  6. Jun 28, 2017 at 10:47 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I have to admit Im still a noob when it comes to LT theory to say the least, but with that being said I gather that its like have your axle and the shock being two independent items that work in tandem to a limited degree?
  7. Jun 28, 2017 at 10:52 AM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    litterally just crank the coilover s until you like where it sits. It will be fine.
    I know what your going for, but you are wayyyyyy over thinking it.
  8. Jun 28, 2017 at 11:51 AM
    Hippiglass
    Hippiglass Well-Known Member
    riverside ca
    2012 tacoma sport DCSB
    DTF race kit, DTF front bumper, king 10"dual rate shocks, URD CAI, total chaos upper control arm brackets, method race wheels, 35/12.5/17 bfg ko2, mcneil TT bedsides, custom SLX Motorsports front fenders, fox bump stops
    im running pretty much zero preload on my setup.. tie rods sit parallel to the ground
  9. Jun 28, 2017 at 12:02 PM
    SanClemTaco
    SanClemTaco Well-Known Member
    Sean
    San Clemente
    01 Prerunner on 37's
    Solo Motorsports XLT Kit, Giant 64
    Your forgetting one thing: alignment.
    If it can't get a proper alignment it's either too low or too high.
    My truck has this problem, if I want 60/40 my alignment would suffer as each truck is a bit different.
    Dalandser likes this.
  10. Jun 29, 2017 at 5:40 PM
    J.Maynard
    J.Maynard Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    since nobody answered... National leaf springs good bad ?
  11. Jun 29, 2017 at 6:53 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    Well, we appear to be back on track! Axle is back in the truck, new body bushings have been installed, front diff is out and getting re-geared, the remaining mounting points from my leaf springs and panhard setup have all been cut out along with the spare tire bracket, 4-link getting dialed in, new beefy coil buckets coming together, there is also talk about a rear sway bar.
    My hopes are up that I'll be out in the back country again soon.
    :fingerscrossed:
  12. Jun 29, 2017 at 11:44 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Why does it say that I need to update my account to third-party hosting?
  13. Jun 29, 2017 at 11:46 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    If you are using Photobucket it's toast they want 400$ yr. Google recent news about it. Get your files off there as soon as you can, good luck with incessant popup windows ads while you do. You need to find new hosting site or upload to media files here on tw, link from there
  14. Jun 29, 2017 at 11:48 PM
    jeffz0rz
    san diego
    Does that mean everything I have on Photobucket currently is gone? I'm unable to download my photos?
  15. Jun 29, 2017 at 11:51 PM
    IronPeak
    AuggieX
    Back to Back
    No I was able to recover mine they are still there but I ran into aggressive popup ads and windows I was unable to back click out of. Noone is Going to pay the 400 except for few suckers it's a shakedown. Think angelcities, tripod, geocities. Too many unpaid customers an their biz model didn't work. When they ask for yearly fee people flee and the company goes belly up. A lot of old posts on forums have dead pic links because of this. Other sites still have free hosting such as flickr and Amazon, though I was unable to figure out the bbcode of my amazon files.
  16. Jun 29, 2017 at 11:57 PM
    IronPeak
    AuggieX
    Back to Back
    Your files are fine, they changed their policy for free 3rd party (tw, etc) hosting. Don't sweat it but I would recommend copying everything anyway and having it in multiple cloud based services for this very reason.
  17. Jun 30, 2017 at 12:07 AM
    IronPeak
    AuggieX
    Back to Back
  18. Jun 30, 2017 at 12:28 AM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    You could just save to a computer/phone, have a cloud backup (onedrive, iCloud, google drive) and just upload from your computer/phone. I never really saw the advantage of using photobucket or Flickr...especially on here.
  19. Jun 30, 2017 at 1:04 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How much storage are you allowed to have on here - I've been using imgur.com, but I don't want to have to go through redoing all the stuff I've done at some point if not necessary?
  20. Jun 30, 2017 at 7:24 AM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    can any solid work guys on here answer a question for me?
    ls1 prerunner likes this.
