Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 21, 2017 at 5:38 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    If you set your truck up to tow 6k whether its links of leafs it will greatly affect the performance of the rear when it doesn't have the weight behind it. It's a wash either way.
    If it's a money thing go with leaf springs. It'll cost you about 4k if you build the bed cage and so the install when all is said and done. If you went with a pro2 style link setup in the rear it will cost around the same but involve making a lot more parts and completely designing a suspension geometry. Poor installation of a dmz may cause cracking of shitty welds or small handling flaws. Poor design and install of links can cause a death trap
  2. Jul 21, 2017 at 5:40 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    Have you adjusted your alignment cams? They push your wheels out effectively making the tie rods shorter
    excorcist[QUOTED] likes this.
  3. Jul 21, 2017 at 7:16 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Thanks for the input. Sounding like I probably won't be happy if I stay soa. Cost/ downtime are a factor for me as well, so links are out as that would require way too much down time and fab work. But sua is a viable option. Figure the camburg kit locates to all of the stock locations so that could probably get installed over a weekend and have the truck driveable while I build shock mounts. Probably won't be starting on anything for a few months, but I was just looking for some input from any of you that might still be soa.
  4. Jul 21, 2017 at 7:24 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I was in debate about getting the camburg kit, but I hear the amount of stuff you have to drill out can really draw the process out. If you have a second POV to get around then I would go for it. Since I don't have the tools anyway and would use a fabricator for when I do mine, Im looking to do the dmz one as that way they can just cut off the junk in the way of the frame and then move on to the install instead of burning shop time removing excess pieces.
  5. Jul 21, 2017 at 7:24 AM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Dmz is selling a bolt in bed cage for he Tacomas now too. So if you did dmz you may be able to get it all on in a weekend in theory. Just make sure you have some good help.
  6. Jul 21, 2017 at 7:27 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I have a buddy literally going through this dilemma. Apparently the shock tabs on the DMZ bolt on kit will be different with the camburg kit. Because of this, he has the camburg kit installed, but is going to swap back to his DMZ kit so that the bed cage can function right. I would imagine it would be better to either fab or cage yourself or get someone to make one.
  7. Jul 21, 2017 at 7:40 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    So his bed cage can function right?...
    Just adjust the axle tabs accordingly
    Coot83[QUOTED] likes this.
  8. Jul 21, 2017 at 7:45 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    My thoughts were similar, but Tim apparently is saying its quite difficult for him to make the cage apparently. I wonder though if that is Tim trying to get him to run DMZ over the camburg kit though.
  9. Jul 21, 2017 at 8:19 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Can't seem to find it anywhere? You know if any pics or pricing on it? I do have some fab skills, so building a minimalist bed cage wouldn't be out of my skill set if buying one is gonna cost way too much.
    Coot83 likes this.
  10. Jul 21, 2017 at 8:20 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'm not super familiar with the Camburg kit, but doesn't it just bolt in to the rivets you drill out for the stock stuff?
    Coot83 likes this.
  11. Jul 21, 2017 at 8:20 AM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    DMZ on instagram or facebook page. They have pictures of the prototype
    Coot83 likes this.
  12. Jul 21, 2017 at 8:20 AM
    Rextinkleton93
    Kyle
    Phoenix, AZ
    It's on their Instagram. Probably have to call to get a price.
    Building your own saves money but you have a lot more variables that take time. Shock placement and everything. Tim did all the work for you on his so all you have to do it bolt/burn it in.
  13. Jul 21, 2017 at 8:22 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    True. I'll send him an email and see what he says. Maybe he'll do a weld it yourself kit for it to save cost
  14. Jul 21, 2017 at 8:23 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    If I remember right, it was around the $1500 mark for the bolt on bed cage. Wouldn't surprise me if there was some fluctuation in that price though.
  15. Jul 21, 2017 at 8:29 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Shoulda never joined this damn forum and just left the truck stock. Damn you all!!!
  16. Jul 21, 2017 at 8:32 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Bro retirement is a dream anyway, why save your monezzzzzzzzz!!!???
  17. Jul 21, 2017 at 8:36 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Yea, tried that and still no dice... Im now almost certain that for whatever reason the tie-rod extensions are not the correct ones for this kit... They are 3'' and a couple members with the +2 kit have said they are supposed to be 2 3/8''
  18. Jul 21, 2017 at 9:04 AM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
  19. Jul 21, 2017 at 9:14 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Best advice I can give, be patient. The more you rush the more you will spend and/or end up rebuilding later. Figure out what you really want and make a plan
  20. Jul 21, 2017 at 9:15 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Agreed on this...would of went different if I knew what I know now.
