Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 21, 2017 at 3:11 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Is there a certain kit you are looking to put on yours?
  2. Jul 21, 2017 at 3:30 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    That would be amazing!... I actually was going to call Total chaos this morning and order a set, but as my luck would have it they are not open until monday...
    I am happy to pay for them as well, ill send ya a pm.
  3. Jul 21, 2017 at 4:04 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    IMG_4317.jpgNice and tight. Sleeved through co mount with 360* box gusset on mitre. Just gotta add tabs and one sides done
  4. Jul 21, 2017 at 4:15 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Most guys go 62" springs with a 12" shackle above the frame. You can buy all the stuff from Total Chaos and Deaver. Most guys recommend the H70 (now called the E30) springs.
    http://www.chaosfab.com/1996-2004-Toyota-Tacoma-Off-Road-Suspension-Accessories.html
    There is a Giant kit that has 64" springs which is the only kit for the first gen that is recommended from them (don't get the 62" kit as you can get the same stuff for less from Total Chaos)
    DMZ is also in the works with a first gen kit I was told when I emailed them a few months ago.
  5. Jul 21, 2017 at 5:05 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Since most of you had mid travel set ups before lt, do any of you know if 1st gen tundra ucas/coilovers bolt up to 1st gen tacoma?
  6. Jul 21, 2017 at 5:29 PM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    Pretty sure coilovers will swap over with the right top hat.
    Anyone have experience with 1st gen "performance" clutches? Ive been on the fence but thinking about pull thing the trigger on one of the LCE performance ones. My last ebay one (F1 perf.) held up decent for a few years but was always a soft pedal and chattered alot. Trying to stay under the $400 mark.
  7. Jul 21, 2017 at 10:59 PM
    Tbasch
    Tbasch Well-Known Member
    Tanner
    Orange County, California/ Forth worth, Texas
    2008 DCSB Tacoma
    Right now I don't, but might do something custom when I do
    Coot83[QUOTED] likes this.
  8. Jul 22, 2017 at 1:22 AM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    I'm going to have to do this soon brake boosters suck.
    I had to get welded eyelets for my new king bypasses
  9. Jul 22, 2017 at 4:15 AM
    dirt addiction
    Flagstaff
    Definately a pain. I think I'm gonna have to get custom tube layout. I think you can clock fox's but I need to double check. Def no room for 3.0 :bananadead:
    JuansTaco[QUOTED] likes this.
  10. Jul 22, 2017 at 6:31 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    The bed is plenty strong. When I do bedsides and rtt I am going to use large 3-4" angle iron that will bolt to the factory bed rails but have the weight distributed across the top. Though this will only work for flat top bedsides, not tt style.
  11. Jul 22, 2017 at 6:37 AM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    I would definitely not sit anything on top of a fiberglass bedside... rtts are heavy, and the amount of stress it puts on the bedsides when your mobbing around. Need to have something tie into the bed bolts for sure. I know people have done it, but they are just asking for a cracked bed and fenders imo.
    Coot83 likes this.
  12. Jul 22, 2017 at 7:59 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @erok81 Having done it already, I can tell you that the bed gets a little weaker without the metal bedsides on it. I mounted a Go Pro to bed rails I had my RTT mounted to, and all the footage was so shaky I couldn't use it, while everything shot when it was mounted to my sliders was smooth as butter. When I installed the Bed Supports I had to push one side over a hair to get it to bolt up, I'm assuming it had spread out a little from having the RTT weight on it and blasting through Pismo. Would highly suggest some sort of bed rack that sits in the bed, not on the rails. Alternatively I was looking in to building some frame supports underneath the glass to support it so I could put a shell on top and not have to worry about cracking the glass or the bed.
    Dalandser likes this.
  13. Jul 22, 2017 at 8:24 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    All I could think of when I read that was:
  14. Jul 22, 2017 at 1:05 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I would be interested to see how this works out. I think Im going to continue with my bed bolt mounted bed rack though.
    Nothing a bro fears more than cracked glass!
    Silverspool likes this.
  15. Jul 22, 2017 at 1:33 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Im the opposite, because of my SUA Im trying to keep my RTT on there all the time. But at the same time, an RTT weighs alot more than just a cap. I would consider this route if a cap is all you are putting on.
  16. Jul 22, 2017 at 1:53 PM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Build a trailer and forget about the bedrack :thumbsup:
    TC yota likes this.
  17. Jul 22, 2017 at 5:29 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I know their older all pro design was not good which got redesigned. Could be worth checking depending on price? I have heard hit or kiss things about their LT kit though.
  18. Jul 22, 2017 at 5:30 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    What he said
  19. Jul 22, 2017 at 5:34 PM
    Radarninja
    Northern California
    06 taco
    yeah hate for you to have problem or not like it, even a deal is a lot of money. Why are they selling?
    Coot83 likes this.
  20. Jul 22, 2017 at 5:37 PM
    bayrak
    bayrak Well-Known Member
    Vancouver Island
    White 2008 DCLB TRD Sport
    Coastal Offroad Armour, Flippac, Ion Alloy Ion Rims , 285 BFG Ko2, Next Level Audio System, Uniball UCA, FOX 2.5 CO's
    If you dont want it I'd be interested:anonymous:
