Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 2, 2017 at 1:56 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Oh wow that is low. Yeah I run down around 15 for crawling stuff usually, but figured 20-25 might be safer for higher speed desert stuff consistently.
    Anyone else have any input?:notsure:
  2. Aug 2, 2017 at 2:04 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Thanks. That's kinda what I was thinking and yeah I'm not doing this for short runs, but if it's gonna be a day of wheeling then I will. I'll start at 20 and see how it feels. I just didn't want to be too low when hitting higher speed stuff, but you're saying even down to 10 should be ok. Don't think I'll go that low, but I'll find my sweet spot between 18-25
  3. Aug 2, 2017 at 2:06 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Same here and I would run 18-25 when I was mid travel. Just didn't know if the speeds that come along with the jump to LT would pose any sort of an issue with lower psi
  4. Aug 2, 2017 at 2:12 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I mean you can't really just say "this many for this terrain" there's a lot of variables to take in to account. Your average speed, your terrain, type of tire, skill. I mean, at the beach I'm airing down to about 10-15 depending on how brave I'm feeling, and have just been told not to skid the truck sideways too hard or I risk slipping a bead. I still do it, but I know the risk involved. So yeah there's a general range you can probably place on types of terrain, but its all dependent on you. Shit I was at the beach for a while at like 15ish when It was recommended to me to drop to 10, immediately saw a bigger difference in traction.
  5. Aug 2, 2017 at 2:13 PM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Not in a Tacoma more than likely. But you could bend or crack wheels. De bead a tire like you were saying.
    I cracked a wheel once, didn't even know it happened for like 3 days ha
  6. Aug 2, 2017 at 2:21 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i cruise Pismo at 10-12 PSI
  7. Aug 2, 2017 at 2:21 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah definitely don't want to crack a wheel or bend it. So sounds like i just need to keep doing what I already was doing and the upped speed shouldn't really be an issue. That was my question basically.
    Thanks for the input
  8. Aug 2, 2017 at 2:27 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I'm running the trd faux beadlocks so am I good to run 0-5psi on the beach :notsure::mudding:
    Dalandser, Coot83 and LTDSC[QUOTED] like this.
  9. Aug 2, 2017 at 2:36 PM
    VolcomTacoma
    Jeff
    NorCal
    You can just let all the air out with those bad boys.
    Dalandser and LTDSC like this.
  10. Aug 2, 2017 at 2:37 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Tire pressure also affects flat tires. The less air the more the tire flexes on hard hits and puts more of the sidewall on the ground. Doesn't matter as much in pure sand but when you hit a sand deer out of nowhere it can puncture the sidewall, and lower air pressure just makes a puncture easier overall in the tread too. I've blown two Toyos with 10-12 psi in them and both were blown out sidewalls from punctures
    Dalandser, JuansTaco, Coot83 and 2 others like this.
  11. Aug 2, 2017 at 3:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Eh its kinda low. But not for my size of tire, its all about volume and i have small wheel. So lots of volume.
  12. Aug 2, 2017 at 4:15 PM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    I'm on beadlocks so that's why I'll go down to 10. As far as terrain, where I wheel there's sand dunes so I'll go low for traction, graded roads or hard dirt I'll go with 25, sorta of soft/silty but not too sandy I'll go with 18-20. El Paso, TX has all types of terrain. We got sand dunes, 3 foot whoops, fire roads, lots of silt, rocky arroyos, etc. So my pressure will vary dependant on where I wheel. Also on the TT I'll go with lower pressure when the race track has a lot of sandy areas and sand whoops.
  13. Aug 2, 2017 at 4:49 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    I just got to say the guys over at solo motorsports are rad people, askin em about parts to get for doing my 4wd kit I'm building and they were more than helpful with doing the 930 inner cv adapter setup and gave me some contact info of who to talk to and where to get some adapters.... freakin awesome... super relieved on making this kit now cause that's the biggest hurdle...keeping 4wd
  14. Aug 2, 2017 at 5:18 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    They'll have my business for life. Always answer the phone, always helpful. They might be pricey, but the way they run a business makes up for it
    Dalandser and Basikbiker[QUOTED] like this.
  15. Aug 2, 2017 at 6:24 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    I run 10psi when I go out. Like blackdog said it helps with the stupid little bumps. My crawler I run 3 on those creepy crawlers it's like glue on anything it drives on. Kinda wanna get them for the taco when I get a new daily.
  16. Aug 2, 2017 at 6:30 PM
    bravelilshitposter
    bravelilshitposter Licks paint and eats window chips
    chandler, AZ
    widebody V8
    Less length, more girth
    12psi fr and 8-10 psi rear. I don't go fast though. Any lower than that and stuff gets stuck in the beads.
  17. Aug 2, 2017 at 7:16 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah I was more concerned about going fast and hitting big bumps causing a tire to blow/ debead/ damaging wheels.
  18. Aug 2, 2017 at 7:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That depends on your tires size and wheel size.
  19. Aug 2, 2017 at 7:27 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    315/75/16 on 8.5" rims. I think my questions have been answered. I used to air down to 18-25 depending on terrain. Just didn't know about going from hitting stuff at 30 to hitting it at 50 I didn't know if it was gonna be an issue.
  20. Aug 2, 2017 at 8:16 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I know this may or may not be applicable to everyone based on specifics of their vehicles, but a. I love this guy's channel and b. I almost always learn something new whenever I watch one of his videos or at least enjoy watching it:
