Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 12, 2017 at 2:48 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
  2. Aug 12, 2017 at 3:50 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I've got a few sets of used hubs good enough to get you home. I'm not super close to you but you can have them if you end up needing them
    Coot83, Dalandser, Caboose117 and 2 others like this.
  3. Aug 12, 2017 at 4:23 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Thanks man I appreciate it
    I gotta wait for Monday and see if toyota HB is willing to do it for me under warranty or not since the truck is only at 20k odo
  4. Aug 12, 2017 at 4:32 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    Cool. I have a brand new from bamatoy as well if you wanted to go that route, but the used ones are free. I'll also picking up tires in Long Beach Tuesday so o may be able to meet you down there if that's better
    Dalandser and Caboose117[QUOTED] like this.
  5. Aug 12, 2017 at 4:40 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    . . .this thread is killin me
    :annoyed:
  6. Aug 12, 2017 at 5:02 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    jeffz0rz[QUOTED] likes this.
  7. Aug 12, 2017 at 5:24 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yes, jack it up just enough to get the tire off the ground and grab the tire at 6 & 12 and try to wiggle it. If there is any play your wheel bearing is toast. You need to check this before you drive anymore, if the bearing is making that much noise as you described it is in really bad shape. it will self destruct soon, a catastrophic failure means watching your wheel pass you on the highway. I drove about 20 miles on one and a horrible wobble developed and I could smell smoke in the cab, luckily I was about a mile from a shop and limped in and when we put it on the lift you could move the wheel a ton.
    The dealer is not going to warranty your hub, they will take one look at your LT kit and tell you to eat shit. Check it out now and don't drive on it.
    Coot83 and Bentrodder like this.
  8. Aug 12, 2017 at 5:42 PM
    doyouquaxu
    doyouquaxu Well-Known Member
  9. Aug 12, 2017 at 6:20 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Another quick way to know is to just grab the top of the tire and pull it back and forth hard enough that the truck starts rocking a bit. If you start hearing a knocking sounds from the hub area, its toast. I never got that bearing noise, just the clunk whilst driving. When I pulled the hub off there was definitely some looseness to the hub, but it rolled just fine with no noise.
    Also, yeah, once you go LT, the dealer is mostly just for parts at that point lol. They just look at your truck and laaaaauuugh and laaaaaaugh and laaaaaaugh when you even whisper 'warranty'.
    Coot83 likes this.
  10. Aug 12, 2017 at 8:03 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Jacked the truck up
    Looked for any more leaks from the CV
    Checked for play in the wheel at the 6/12 and on the 9/3
    No play
    Spun the wheel too, no odd noise or grind other than the sound of the brakes on the caliper.
    I really need someone who knows more than me to go on a ride along and tell me what's normal noises and when I'm being dumb
    I read an absolute shit ton on LT before ordering it and putting it on the truck but nothing prepares you mentally for all the new noises especially after the CV boot and brakes problem
    Now I'm just hunting for gremlins lol
    Dalandser and Coot83 like this.
  11. Aug 12, 2017 at 8:50 PM
    VolcomTacoma
    Jeff
    NorCal
    I could never detect extra play in the wheel by hand, but by doing my method I listed above I would hear a clunk at the hub.
    Caboose117[QUOTED] likes this.
  12. Aug 12, 2017 at 9:10 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Getting the platework laser cut out this coming week... more fancy 4wd stuff showed up too ;)
  13. Aug 12, 2017 at 9:15 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Well
    Share with the class?!
  14. Aug 12, 2017 at 9:28 PM
    Basikbiker
    Trav
    Rcv inner stub shaft adapters to plug into the diff so u can bolt a 930 cv to it then run a half shaft to a u joint that connects a stub shaft to your dana44 hubs ( the guys at solo motorsports gave me some info and tips for running an ifs setup like this (similar to thier xlt kit) I'm hoping to get at least 19-20" travel out of it kit will be in the +5"track width range because of the hub offset in a Dana 44.... should be sweet when I'm done... I've spent some money his time bettin a lot on my design and hobby fab skill lol
  15. Aug 12, 2017 at 9:32 PM
    doyouquaxu
    Are you still in the Huntington Beach area? How much longer, or is your stay depending on how long your truck takes to get squared away?
  16. Aug 12, 2017 at 9:36 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    At this exact moment I'm in La Marada but HB isn't far away obviously
    And yeah I'm here til the truck is squared away. All parts have been picked up and installed
    Then I'm back to Kentucky lol
    Still waiting on my summit seat from PRP (then gotta fab mounts for it)
    Have an order with @Baja Designs to pick up as soon as it's ready
    Then gotta get some Spods from Spod and wire up all the lights, and the new yaesu I just picked up
    And lastly gotta get 5 new toyo AT's since my Yokohamas melted on my drive here and I don't wanna go back to Kentucky on them
    Getting my bed cage powdercoated this week and hopefully getting the truck wrapped soon too
    Dalandser likes this.
  17. Aug 13, 2017 at 10:14 AM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    What's the thoughts on dirt king? Seems like a good company but a Guy has a set of their uppers in town for 350$ only used a couple months. They are basically brand new with uniball and bushings. Should I Save 200$ or should I go with the camburg ball joint uppers? 2nd gen btw
    MrCrowntown and nfs257 like this.
  18. Aug 13, 2017 at 10:15 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I am super happy with my kit so far. Quality is excellent in my opinion.
    MrCrowntown and Dalandser like this.
  19. Aug 13, 2017 at 3:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have a buddy with their stock width upper heim joint and tick width lowers. They are very nice. I'd grab them.
    FlapJack935[QUOTED] likes this.
  20. Aug 13, 2017 at 3:24 PM
    FlapJack935
    Jack
    Abq New Mexico
    figure for the price im gonna snag them.
