Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 2, 2017 at 7:14 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Welp good luck
  2. Sep 2, 2017 at 7:29 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Thanks Ive been following your build. It has definitely given me some ideas.
    Basikbiker[QUOTED] likes this.
  3. Sep 2, 2017 at 9:03 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    How are you planning on figuring out the geometry ?
  4. Sep 2, 2017 at 9:24 PM
    Basikbiker
    Trav
    PFM dude duh
  5. Sep 2, 2017 at 9:29 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I've got a spare set from someone that I'm going to build the jig from :thumbsup:
    Dalandser and Basikbiker like this.
  6. Sep 2, 2017 at 9:34 PM
    doyouquaxu
    doyouquaxu Well-Known Member
    Finally fixed the leaky hub I've had since I got my truck running. Took it for a joy ride and saw my front bypass puked its oil out. Too hot for this bullshit
  7. Sep 2, 2017 at 10:19 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Giving up works 100% of the time, every time.
  8. Sep 2, 2017 at 11:04 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    What if you've re done your oil pan gasket twice and you just took another look under the truck tonight and its leaking again...:(
    First reseal, 3 hours cleaning the mating surfaces alone.
    Second seal, 5 hours with a ton more tools, let it drip oil overnight to make sure I didn't have any on any surface, alcohol wipe down within literally seconds before I seated the pan with new seal to make sure there was nothing interfering with the seal.
    And now this.
    I hate Toyota for using RTV instead of a gasket.
  9. Sep 2, 2017 at 11:23 PM
    doyouquaxu
    Any of you smart guys ever removed the headlight and turn signal switch and replace them with rockers? Have wire diagrams, forgot shit is negatively switched. The wires should read +12v with headlights or turn signals off, and 0 or close to it with the lights on, right? How would I hook up the wires to the switches.
  10. Sep 2, 2017 at 11:26 PM
    PapaBear
    Austin
    SIN CITY
    I thought about using it the second time, but I just opted to use Toyota's seal kit again, guess that didn't work. I've got to much shit to do on it elsewhere, probably just gonna have it done by the stealership TBH.
  11. Sep 3, 2017 at 12:26 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Total chaos +2 race installed
    Old "stuff" off and sold
    stumbles, PapaBear and Dalandser like this.
  12. Sep 3, 2017 at 4:27 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Is it leaking from the same spot / random / or all around?
  13. Sep 3, 2017 at 6:29 AM
    PapaBear
    Austin
    SIN CITY
    Random, first it was front and center, now it's left side rear, the first time I was conservative with the seal, the second time I used 3/4 of the tube which seemed to be just down the middle. I know they give you extra in the tube just incase but I used the right amount the second time. And it's worse of a leak now. Before it would just pool on the drain plug and drip (the drain plug isn't leaking, the seal is, I know for sure) Now this time it almost looks like it's sprayed out at some point because it's actually on the lower part towards the transmission.
    Dalandser[QUOTED] likes this.
  14. Sep 3, 2017 at 7:09 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I guess that's better than the same place twice. Is it Toyota fipg that they give you with the seal kit? Permatex makes some similar stuff that people seem to like.
    PapaBear[QUOTED] likes this.
  15. Sep 3, 2017 at 7:17 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I went to autozone and got a felpro gasket. Thin layer rtv both sides of gasket. Let it cure over night just finger tight and torque it down to Toyota specs.
    PapaBear[QUOTED] and Dalandser like this.
  16. Sep 3, 2017 at 7:42 AM
    jeffz0rz
    san diego
    applicable to literally any situation in life. try my free introductory system. first give up is free. each additional give up is only 19.95. dont wait, act now.
    nfs257, erok81, Basikbiker and 2 others like this.
  17. Sep 3, 2017 at 10:09 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    It's pretty simple, if you are not using the OE wires you just ground the input side of the switch so your switched source is ground. If you are using the OE wires just do the same connect the neg wire where you would usually connect the power. Only prob is that your rocker switch will not illuminate correctly but if you contact Blitzpro they will build you rockers that will illuminate properly using that OE neg switched set up.
    PapaBear likes this.
  18. Sep 3, 2017 at 10:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm giving up on your plan after the first one :)
    jubei and PapaBear like this.
  19. Sep 3, 2017 at 10:48 AM
    PapaBear
    Austin
    SIN CITY
    Yep factory seal kit. I look into that, I know Honda bond is good but I didn't want to use it, thought I could stick with Toyota and do it right.
    Felpro's just a simple universal gasket? I'll look at that. How do you guys torque down everybolt, I can torque down all but one, one interferes with the crossmemeber when I try to torque it properly. Also every diagram I look at shows in. lbs, not ft lbs... I did rough conversions and torqued it down properly, just asking.
  20. Sep 3, 2017 at 11:32 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Got to drool over the beast in person yeasterday and hop in for a quick blast through some whoops. If my truck ends up halfway between my mid travel setup and this thing when I'm done I will be very happy. Can't wait to get my dmz rear kit installed and be able to really put my front to the test. Thanks @dirt addiction for the ride
    nfs257, chulsey4, jubei and 7 others like this.
