Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 6, 2011 at 11:44 AM
    #6761
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    agreed! I have so much scrap metal that It'd be free for me :D
  2. Oct 6, 2011 at 12:16 PM
    #6762
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    even cheaper..get a paint pen. after you have an alignment make a mark on each tab. then you know right where to put them back too if you knock them out. easy to do out on the trail too if you know you just took a good hit.
  3. Oct 6, 2011 at 12:17 PM
    #6763
    linked2002
    linked2002 Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    or a lil tack weld works as well.
  4. Oct 6, 2011 at 12:36 PM
    #6764
    dirty dangler
    adam
    simi valley,ca
    until you knock it out on the trail...then its a pain in the ass
  5. Oct 6, 2011 at 1:03 PM
    #6765
    linked2002
    san diego
    if you have the ability to break a good strong tack with a hard hit, something far more is broken then your alignment cams. i would be looking for the other half of my truck. ive welded every one of the cams on my trucks and have never smashed it hard enough to break that tack... and there are a few people on here that will be more than happy to tell you how abusive i was to those things.
  6. Oct 6, 2011 at 1:11 PM
    #6766
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    do you just do a couple tack welds or like a small bead?
  7. Oct 6, 2011 at 1:29 PM
    #6767
    dirty dangler
    adam
    simi valley,ca
    seriously? lol
  8. Oct 6, 2011 at 1:37 PM
    #6768
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  9. Oct 6, 2011 at 1:44 PM
    #6769
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    I didn't think there was much if any difference between tc and burg ucas....getting closer to being ready to put the LT on :D
    Adam u up for an install and a lil welding, for the right $ and I'd like to help. I'll be the gopher and beer getter lol.
  10. Oct 6, 2011 at 1:50 PM
    #6770
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    MJP has the Burg kit and TC coil buckets. Granted it's a second gen, but it's the same "disclaimer" on TC's website.
    If you don't want the TC bucket gussets, Solo Motorsports makes a multi piece gusset kit that is supposed to work with any LT kit.
    FWIW, plan on grinding/fitting for fucking hours to get them to fit correctly. My coil buckets took me 9 hours to do...and I had no engine in my truck at the time.
  11. Oct 6, 2011 at 1:53 PM
    #6771
    DIRT YOTA
    Cory
    Camarillo, CA
    :eek:
  12. Oct 6, 2011 at 1:55 PM
    #6772
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    The Solomotorsports UCA Gussets took about 10min a side to mock up properly, then time for welding, overall about 2hrs to do both sides Maybe it's cause they're 4-pieces per-side instead of 2.
  13. Oct 6, 2011 at 1:57 PM
    #6773
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    FYI for second gens the Kyle Green Kit doesnt work with aftermarket control arms...not without modifying it. The actual coil bucket gusset plates (with the dimple die) need to be located inward (toward the engine) about 1/4". This mean that you need to make all new double shear plates to use that are 1/4" wider as well. Sucked balls but worked out ok.
    Picture during installation:
    And the install woulda been way easier with the engine pulled, but with the proper weld preparation/penetration they can be installed just as strong with welding only on the wheel well side.
  14. Oct 6, 2011 at 1:59 PM
    #6774
    dirty dangler
    adam
    simi valley,ca
    always..I have my rear to finish. matt's truck is going in around mid november and alex's truck as soon as anthony gets that kit to him. so we will have to squeeze you in between but it shouldn't be an issue
  15. Oct 6, 2011 at 2:20 PM
    #6775
    linked2002
    san diego
    yep
    i actually do one at the 12 o clock, one between 4 and 5 o clock position, and one between 7-8 position. have yet to break one tack that way. end up taking a cut off wheel to the truck to get them loose again.
  16. Oct 6, 2011 at 2:21 PM
    #6776
    97yota4wd
    Eric
    Mesa, AZ
    okay thanks thats what i wanted to know
  17. Oct 6, 2011 at 2:24 PM
    #6777
    linked2002
    san diego
    no prob. i guess other people have other ways of doing it, or they may not believe in the tack welding method... but it hasnt served me wrong and i lost a tranny brace, and both engine mounts all in one oops in the desert, and the tack welds did what they were supposed to do... so ill say that tacking it is more than good enough.
  18. Oct 6, 2011 at 2:25 PM
    #6778
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Sounds like an oh fuck, not an oops.
  19. Oct 6, 2011 at 2:29 PM
    #6779
    linked2002
    san diego
    well yes.. it was... travisfab can tell you all about that oops... had a buddy in the truck with me that hadnt ridden in it after the v8 swap. asked me to floor it on a night ride at about 10 pm. hit a hole that was 3 feet deep by about 5 feet wide at 98 mph (yes gps speed so that is no bullshit). took out more than its fair share of shit including a tranny crossmember, both engine mounts, a driveshaft, and my bias controllers for the front and rear of my truck. there are pictures floating around somewhere of that night... if the tack welded alignment cams lasted through that, then ill stick with what i know. ill tack them.
  20. Oct 6, 2011 at 2:35 PM
    #6780
    dirty dangler
    adam
    simi valley,ca
    im not saying a tack on the cams wont work....of coarse they will as long as the tack penetrates. How many people on here even have a welder? i was merely giving another option...i have ran tacks and prefer the paint pen..just my 2 cents for what its worth
