Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 8, 2017 at 8:33 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Point noted. No offense taken. I'm not having a shop do it. I'll figure it out...even if it's the hard way.
    This is a learning experience for me, don't think I'll learn much by having someone else do it.
  2. Oct 8, 2017 at 8:52 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Buy a digital angle finder. harbor freight actually has a decent one. Jberry someone on Tw has a good post about using it to find the correct angles.
    Totally agree. Glad you are willing to do it yourself and take advice from others. A lot of people now days don't lol
  3. Oct 8, 2017 at 9:10 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    https://www.instagram.com/p/BSF1uLhBvK_/
    I used this to double check my driveshaft angle and it was pretty easy.
    https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/
  4. Oct 8, 2017 at 9:55 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Dalandser[QUOTED] likes this.
  5. Oct 8, 2017 at 10:02 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Hmmm I heard metal on metal.
    Coot83[QUOTED] likes this.
  6. Oct 8, 2017 at 10:51 AM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    I would probably assume over half of the long travel trucks for sale have been jumped or beat on at some point the other half are hardly even used (like mine when I sold it to be honest).
    jeff b and Dalandser like this.
  7. Oct 8, 2017 at 12:06 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
  8. Oct 8, 2017 at 12:16 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Not sure what would of felt worse that basically stock rear suspension landing or the airbags blowing up in their faces
  9. Oct 8, 2017 at 1:14 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'm impressed he jumped it with a rtt on top of a shell. I'd never do that for fear of flipping
  10. Oct 8, 2017 at 2:02 PM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    That RTT was to counterbalance the weight of the engine :rofl:
    Coot83, Dalandser and Falldownhard like this.
  11. Oct 8, 2017 at 7:09 PM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    I mean, I don't see how or why you'd skip that part. You have to weld on the axle perches, might as well set them up at the pinion angle you want. A shim would create and even larger space between the leaves and the axle decreasing lift.
    One thing there's no shortage of is opinions and theory about what angle will work. I just went with Tim's suggestion and the test drive went fine.
    Dalandser and Radarninja[QUOTED] like this.
  12. Oct 8, 2017 at 7:13 PM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    I just finished my rear today. I gots the vibes. I set everything as it was and matched the angle to .10. I think I need a new CB cause there is a lot of play in it. Also where do I get my bypasses charged?
    I'll shim it next week
    Coot83 likes this.
  13. Oct 8, 2017 at 7:28 PM
    Radarninja
    Northern California
    06 taco
    What did tim say?
  14. Oct 8, 2017 at 9:29 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Not enough. He needed his old lady sleeping in there.
    Coot83 likes this.
  15. Oct 9, 2017 at 3:58 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    You guys are getting me all pumped up man with all these LT rears going off! Looking to get my kit this December after some more funds come in!
    Dalandser, jamesepoop and Hawk373 like this.
  16. Oct 9, 2017 at 6:29 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    I lined the pinion up with the shaft to be parallel. No vibes that I've noticed up to 100 MPH and no dead carrier bearings with 64k miles and about 16k being on long travel. My brother set his Ranger up differently and no vibes either, I don't recall what angle he used but it worked also.
    Radarninja and Dalandser like this.
  17. Oct 9, 2017 at 8:11 AM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Any experienced fabricators looking for a job? We are hiring at the company I’m with in Phoenix.
  18. Oct 9, 2017 at 10:06 AM
    Tacomoto23
    Tacomoto23 Well-Known Member
    Carey
    Torrance,CA
    21’ TRD 4x4
    I followed this method when setting up my pinion angle for my DMZ kit and it worked quite well. No vibrations and for my 2WD I had set the pinion flange to -2 degrees so that it would come more level under load.
    A good read to gain some knowledge and familiarize oneself of pinion angles: http://www.hotrod.com/articles/91758/
    Hawk373[QUOTED] and Radarninja like this.
  19. Oct 9, 2017 at 12:14 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Except that logic is designed for trucks that have a double cardan CV driveshaft, not a conventional driveshaft. First gens had a double cardan, second gens do not. If your truck doesn't have a CV driveshaft (factory second gens), the pinon angle is supposed to match the working angle of the u-joint after the carrier bearing (or the output flange of the transmission/xfer case for those with a single cab). With 2 piece driveshafts with conventional u joints (second gens except single cab), you can get the working angle by measuring the first piece of the driveshaft and subtract the difference of the output flange of the transmission/transfer case.
    With a double cardan, I always set the pinon angle 2* down from straitline to combat axle wrap.
  20. Oct 9, 2017 at 5:34 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I got real lucky finding this tundra rear on Craigslist for 95.00 in Denver. It's in pretty good condition too.
