Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 16, 2017 at 11:59 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Depending on the severity and how long you've had the vibrations, your joints may be good. Again, there's no reason you should be getting vibrations. Tons of guys on here have had sua installs with no problems. A slip yoke just makes sure your driveshaft doesn't poke into your transmission or transfercase if you're 4x4. If the pinion angle's wrong then all the drive line work in the world won't correct it.
    Did you ask Geoff what he thought about this? I'm curious to hear what he has to say since the only 2nd gens I've seen this kit installed on were regular cabs or access cabs - so only long beds. If the issue is that he didn't design the kit correctly for short beds and that's why you need to have the driveshaft shortened it would be interesting to see what he says about it.
  2. Oct 16, 2017 at 11:59 PM
    doyouquaxu
    doyouquaxu Well-Known Member
    Drivelines Inc. in Mission Viejo. They lengthened the one on my truck quickly. They also do drive shafts for past and present desert racers.
    jamesepoop likes this.
  3. Oct 17, 2017 at 12:02 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My neighbor had his front ds on his Jeep turned around in one day from this place delivered and picked up from his work in Costa Mesa because he works at a marine engine shop.
  4. Oct 17, 2017 at 6:18 AM
    Camerond05
    Camerond05 Well-Known Member
    Cameron
    Missouri
    2020 Tacoma DCSB
    B&W drivelines in auburn. The guy is super cool, he has a badass 85 Toyota crawler
    Dalandser likes this.
  5. Oct 17, 2017 at 1:59 PM
    TacoAC
    TacoAC Well-Known Member
    Cali
    DCSB In Progress
    How much did they charge you?
  6. Oct 17, 2017 at 6:18 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    Guess I'll re-post in a more appropriate place. Many ways to skin a cat.. :spy:
    Fuel tanks are in a getting hooked up, break lines are going in, bedside braces are being added to help the weight of the shell/RTT.
    Front differential got a full rebuild, new gears and ARB locker. :burnrubber:
  7. Oct 17, 2017 at 7:23 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    All in and buttoned up. Quick test drive tonight tells me I definitely need more ride height, front and rear, but especially in the front. And need to spend some time dialing in the bypasses. Hopefully get to do that this weekend. But already noticeably better than the previous setup and the rear is out performing the front as it should. IMG_1352.jpg
  8. Oct 17, 2017 at 7:37 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Shorten those bumps to 2". You'll thank me later. #leafspringproblems
    MojaveMadman, Coot83 and Dalandser like this.
  9. Oct 17, 2017 at 7:37 PM
    doyouquaxu
    Can't remember. I have my receipt somewhere but I lost the folder I put it in.
  10. Oct 17, 2017 at 7:44 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah I was curious about shortening them as well. Just don't have access to nitrogen to refill them yet, and no one in my town has any either. Hopefully going to acquire a tank in a few months or so and I'll shorten them an inch or two. First will be to get with deaver about an add a leaf because my rear bumper only allows for me to have 7" of up travel. I need to raise my rear end at least an inch or two
    Caboose117 and Dalandser like this.
  11. Oct 17, 2017 at 8:10 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Drop the bump psi to 60 and run it.
    ls1 prerunner and Dalandser like this.
  12. Oct 17, 2017 at 8:13 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Thanks for the advice. Would something like the ARB tire deflator be good enough to let some air out? I don't have any no loss chucks or anything like that. Like I said I'm planning on getting a nitrogen set up eventually, but since everything is brand new now, shouldn't be needing to rebuild anything for at least a little while
  13. Oct 17, 2017 at 8:15 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Don't bother with a deflater. You gotta be quick. The nitrogen cavity is so small, a half second and you are out of juice.
  14. Oct 17, 2017 at 8:28 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Gotcha. Any suggestions on how to drop it safely? Or don't until I have access to nitrogen with a no loss chuck?
  15. Oct 17, 2017 at 8:34 PM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    I should probably shorten mine also, running them at 100 PSI. Might try what you suggestes of 60 PSI. I shortened some the other day for another truck but haven't added oil yet, any idea how much oil I should remove if I shorten them 2"?
  16. Oct 17, 2017 at 9:10 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I don't know off hand in terms of volume. But you can just measure the oil level from the top before and match it after. Volume is volume. Doesn't matter if it's a liquid or solid.
  17. Oct 17, 2017 at 9:28 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    So much want............one day :thumbsup:
  18. Oct 17, 2017 at 9:30 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I haven't seen anyone build a 5 lug 2nd gen in a long time! :D
    5 Lug Fury[QUOTED] likes this.
  19. Oct 17, 2017 at 9:56 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Im working on making my own uca's now and then it'll be lift spindles. When I make my jig for my uca's I'm leaving room to make an extended set later. The rear I plan on doing chevy 63's and keep my sua set up paired with some nice shocks. Im graduating in December so I should be able to do more.
    Dalandser[QUOTED] likes this.
  20. Oct 17, 2017 at 9:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Probably seen this, post it for fun anyway:
    https://www.tacomaworld.com/threads/stupid-hurts-s-5-lugger-build.50387/
