Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 26, 2017 at 11:24 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yeah mine are all 3/16 steel and takes the floor jack to put on my rear skid. Front I can manage to hold up with my knees and feet
  2. Oct 26, 2017 at 11:49 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Cut 3/8" off the barrel(female end of the extension, or trim the outer tie rod down if you can
    Dalandser[QUOTED] likes this.
  3. Oct 26, 2017 at 3:18 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
  4. Oct 26, 2017 at 3:20 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    *Bliss*
  5. Oct 26, 2017 at 11:08 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Make sure to gusset your frame where the bumper mounts. I used to have a plate bumper / winch and jumped too. Got lucky the bumper didn't completely break off; one broke cleanly and the other bent when I caught it. Pulled the bumper off, welded the mount back together, and cut out a 1/4" template of the mount, which I then welded to the mount to beef it up.
    Radarninja[QUOTED] and Dalandser like this.
  6. Oct 27, 2017 at 2:53 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    What grade aluminum are you using?
  7. Oct 27, 2017 at 3:46 AM
    Radarninja
    Northern California
    06 taco
    I'm 12 hrs into long travel and already need more gussets! Beef!
    tacomgee and 916TacoTruck like this.
  8. Oct 27, 2017 at 5:13 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I would not attach the bananna to the resi, the resi gets super hot and it will spoil the banana. I would suggest keeping the bananna in one of your door panels or center console.
  9. Oct 27, 2017 at 5:28 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    For a full setup, front to back, the weight diff from AL to steel was about 60lbs. Most people probably have more than that in their cage and gussetts.
    nfs257 and Speedo like this.
  10. Oct 27, 2017 at 6:44 AM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Hes just getting old lol,@Y2kbaja Plus he comes from a racing background. shave weight here ever you can.
    Dalandser, Airdog and jamesepoop like this.
  11. Oct 27, 2017 at 6:48 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Just because I have 60lbs of beverage in the ice chest doesn't mean I need 60 lbs of under carriage protection
    nfs257, Dalandser, jamesepoop and 3 others like this.
  12. Oct 27, 2017 at 6:54 AM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I would frame plate behind the resi. that area is a crumple zone
    Dalandser and 916TacoTruck like this.
  13. Oct 27, 2017 at 9:01 AM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    Um, when you’re done figuring out your gussets, can I have the banana?
    Asking for a friend.
    tacomgee, SilverGhost, Speedo and 3 others like this.
  14. Oct 27, 2017 at 9:21 AM
    jamesepoop
    California
    2007 Fj Cruiser
    Sure hope "your friend" likes flambe banana.
  15. Oct 27, 2017 at 9:25 AM
    916TacoTruck
    Inyo mom
    2019 Rapturd
    Who doesn’t!
  16. Oct 27, 2017 at 10:44 AM
    Basikbiker
    Trav
    Anyone know what size and type of fitting is on the brake line screwed in the caliper? Is it 10mm inverted flare? I'm so close to deleting all the automotive shitty flare stuff in my brake system.... rest is all an3
    Dalandser likes this.
  17. Oct 27, 2017 at 11:01 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    10mm inverted
    Dalandser and Basikbiker[QUOTED] like this.
  18. Oct 27, 2017 at 12:07 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
    I've got 1st gen taco brakes on my truck so assuming they use the same inverted line size, this is what you need. If not Kartek has tons of other thread pitches. They work great for me, all my brake and fuel lines are converted to AN.
    https://www.kartek.com/parts/fragol...le-steel-straight-brake-adapter-fittings.html
  19. Oct 27, 2017 at 1:19 PM
    Radarninja
    Northern California
    06 taco
    Oh ill give you the banana alright
  20. Oct 27, 2017 at 1:21 PM
    anthony250f
    Anthony
    San Diego, CA
