Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Nov 17, 2017 at 11:56 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well...thats no good.
  2. Nov 17, 2017 at 12:26 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I’m working on a more permanent LBJ delete currently.
  3. Nov 17, 2017 at 12:38 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    It does taper slightly FYI.
  4. Nov 17, 2017 at 12:41 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Yea I just needed a general measurement, for a chase light , want to squeeze the biggest one I can between my rollcage tubes
    Tbasch likes this.
  5. Nov 17, 2017 at 12:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What does that entail?
    Like the guy whole welded in a uniball into OEM ones?
  6. Nov 17, 2017 at 1:07 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    No fuck that haha. Orientation is still in correct. Ballistic Uniball and my boxed lower control arm. Heim steering required though
    atvlifestyle likes this.
  7. Nov 17, 2017 at 2:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    so youre making a custom LCA and modifying the spindle?
  8. Nov 17, 2017 at 2:19 PM
    Camerond05
    Camerond05 Well-Known Member
    Cameron
    Missouri
    2020 Tacoma DCSB
    Wish that XLT kit was on sale..
    Coot83 likes this.
  9. Nov 17, 2017 at 2:54 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    It's on sale but only a few hundred off. I wish they were doing the 20% off on it.
    Camerond05[QUOTED] and Dalandser like this.
  10. Nov 17, 2017 at 3:18 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The second gen xlt is, just not 20%
    Camerond05[QUOTED] likes this.
  11. Nov 17, 2017 at 3:20 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    There would be a few more trucks on here with it if it was lol
  12. Nov 17, 2017 at 3:27 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Worked on a Chevy a few weeks back. Customer used a "steel it" knock off coating and I'm a fan now!
    He'll be back in January for bumpers and front LT install.
  13. Nov 17, 2017 at 3:28 PM
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Yeah for real. I’d be buying that now if it were 20% off
    Dalandser likes this.
  14. Nov 17, 2017 at 3:35 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    Is that a 2500??:p
  15. Nov 17, 2017 at 4:29 PM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Yes and kind of. We’ll see if it works. It’s just a Solidworks model currently
    MadTaco461 likes this.
  16. Nov 17, 2017 at 5:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    2 or 4 wheel drive? Wonder if it would make a difference. Maybe their design's changed
    After adding uniball conversion and spindles to Solo's regular lt kit, there's only a $200 difference in the xlt kit with axles. Can't justify going the first route when things seem simpler and obviously more travel with the xlt kit.
  17. Nov 17, 2017 at 5:27 PM
    Basikbiker
    Trav
    Just build it it’ll be fine
  18. Nov 17, 2017 at 7:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    How are they simpler?
    You don't gain much travel unless you use a 10" shocks....which mean custom hoops and hacking the fenders. Even with solos wiy kit.
    Then you have a truck thats 2" wider over all. Need big fiber glass too.
    Then at least to me..you should do an engine cage while you do shock hoops. Then roll cage..and then you might as well tie into a nice bed cage with a fuel cell a 4 link and 9" rear end to pull at least 24" travel to justify 17 up front.
    Not so simple
  19. Nov 17, 2017 at 7:15 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Anyone ever have issues with their tires rubbing the crap out of their rear bypasses on hard turns?
    I'm already running spacers and they don't touch any other time than when I whip the truck hard left or right.
    I'm asking cause I am getting a Currie rear end built and want to make my rear track width wide enough
  20. Nov 17, 2017 at 8:09 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Depends on your bypass orientation. Right to left sliding around is gonna flex the suspension similar to rock crawling. I have all my bypasses tubes forward and flexing like this IMG_1510.jpg with wheel 2" wheel spacers I didn't rub the shocks at all. You might need to notch the frame and move your shock mounts inward if you can't fix it otherwise.
    Tbasch likes this.
