Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 5, 2017 at 6:55 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
  2. Dec 5, 2017 at 7:00 PM
    J.Maynard
    J.Maynard Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    might be selling mine soon painted white look pretty good but i need wider cause im dropping a t100 axle
    jtanner21[QUOTED] likes this.
  3. Dec 5, 2017 at 7:08 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    Pm incoming
    J.Maynard[QUOTED] likes this.
  4. Dec 5, 2017 at 7:10 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Yeah they’re next along with cam tab. Coil bucket will probably be down the road since it’s not really a go-fast rig right now
  5. Dec 5, 2017 at 7:14 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Did you get the text / info from USPS?
  6. Dec 5, 2017 at 7:18 PM
    jtanner21
    Yes just text ya back! Sorry didn't see it until now
    Dalandser[QUOTED] likes this.
  7. Dec 5, 2017 at 7:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    fawk no. I never be able to go anywhere. Breaks down too much haha
  8. Dec 5, 2017 at 9:24 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    MrCrowntown likes this.
  9. Dec 6, 2017 at 5:57 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Can someone explain semi float and full floater rear ends to me? Or direct me to somewhere I can read up on it?
    Not pulling much with my google-fu
  10. Dec 6, 2017 at 6:39 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  11. Dec 6, 2017 at 8:04 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Most important difference
    Semi float, the axle shafts have to support the weight of your truck and deal with the twisting forces from the wheels. If you break an axle shaft you normally loose the wheel/brakes
    Full float, all the weight is on the hubs and the axle shafts are only dealing with twisting forces, plus if one breaks you don’t loose the whole wheel
    Basically a full float is Similar to a front 4wd setup, except with a solid axle.
  12. Dec 6, 2017 at 2:07 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I still have to drill the holes which won’t really matter for another month, but I “steeled” the cage and bolted it in. Just ordered my king triples from dsm which luckily they had two sets left in stock so I don’t have to wait 7 weeks! Just need the dmz kit and I’m ready to install!
  13. Dec 6, 2017 at 4:52 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    The texture comes entirely from how the product is applied any of them can be smooth or rough. Air pressure and technique determine the texture with sprayed on liners and with the rolled on liners they way you roll it and how long into its curing you roll it determines the amount of texture.
  14. Dec 6, 2017 at 4:57 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Good point. That's true within limits in my experience when comparing different products like bed liners I've seen different substrate materials mixed in. I've had some paint samples of monstaliner and their substrate is not similar to the line x and rhinoliner. Theirs are more like pebbles while monstaliner is like chips or flakes. It really feels less like stucco than the other kinds. More like knocked down orange peel texture you'd see in a restroom. :notsure:
  15. Dec 6, 2017 at 5:08 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I have owned Linex and Linex premium, premium is a completely different product. I have sprayed the premium myself and applied about 600 sq ft of monstaliner recently on some obstacle course props. Monstaliner rolled on can absolutely be the most severely textured product if you hit it with the special texture roller once it starts to kick. You can make that shit turn into 2 grit sandpaper. The liners look really shitty when the texture is not right or uneven, it takes some practice to make it look good.
  16. Dec 6, 2017 at 5:10 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    For sure. I was going off of samples and my first gen's bed that's covered in rhinoliner or line x - previous owner didn't remember which one it was. I'd rather go with a more durable feeling coating than monstaliner for high build applications - the paint doesn't seem to cure as hard as some others. I could almost put a mark in it with my fingernail. Maybe they didn't mix their samples the same way you mixed your stuff. The amount of hardener can make a difference I'm sure.
    What do you prefer between line x and line x pro vs monstaliner if you were painting your truck?
  17. Dec 7, 2017 at 11:37 AM
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    Hi :wave: I like long travel and BS..
    Anyone have first hand experience using stock fuel system (pump, fuel level sender, etc) with a fuel cell?
    I don't wanna brick my truck because of smog and evap error codes
  18. Dec 7, 2017 at 11:43 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    First gen but I have 100% OEM stuff in my cell. No check engine light, no codes, even my gas gauge works
    jubei and jjhitchen[QUOTED] like this.
  19. Dec 7, 2017 at 11:45 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    :anonymous:
    Basikbiker and jjhitchen[QUOTED] like this.
  20. Dec 7, 2017 at 11:46 AM
    DannyBFresco
    Danny
    :drool:
    Coot83 likes this.
