Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 20, 2017 at 7:01 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    1st gen. 03 with drive by wire and cable throttle body.
    Have any of you guy had a issue with the throttle body sticking closed. I already cleaned it out and made sure everything was smooth inside but I still get a code after I gun it, let off and try for to get going again the truck will stall. I would have to pull over and restart the truck again to get going.
  2. Dec 20, 2017 at 10:30 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Frankenstein has done that before multiple times.
    Not a normal thing but does happen.
    It started for me once I opened up the exhaust. Never got a CEL
  3. Dec 20, 2017 at 11:23 AM
    Canks
    Canks Well-Known Member
    San Diego
    08 DCSB in pieces; 04 Tundra Access cab also in pieces
    That is super depressing, for some reason I was under the impression his Albins was a sequential with a clutch.... I must have been projecting my own dream on to the situation....
  4. Dec 20, 2017 at 2:27 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Ok. It’s starting to happen more often now. To early in the winter to have to buy a 1000 throttle body. Needs to last until spring when hrs pick up again. I would go used but I don’t want to chance it. Rather get new.
  5. Dec 20, 2017 at 5:13 PM
    J.Maynard
    J.Maynard Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    Can someone tell me what gear oil to use for a t100 axle with the TRD limited slip?
  6. Dec 20, 2017 at 6:44 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    Think I would be riding nutts, if I went with the h70s. With a rear Swingout.... + a 33x12.50. Or wouldn't be bad... I would prob have my rack and tent on too most of the time prob around 100-120 rack+tent
  7. Dec 21, 2017 at 8:18 AM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    ECGS suggests Lucas non-synthetic 85W-140
    J.Maynard[QUOTED] and Speedo like this.
  8. Dec 21, 2017 at 8:22 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Bummer I had a drive by wire throttle body that I sold for cheap recently
    SilverGhost[QUOTED] likes this.
  9. Dec 21, 2017 at 8:45 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I know very little about these kinds of things, just going on what he said during an interview. But I think he does still have a clutch, he said they run torque converter with manual valve bodies so its not a direct shock. My take would be its like the auto/stick cars but with a clutch too, like an auto that you tell when to shift, with a clutch ? Seems like everything in baja is super secret so who knows
  10. Dec 21, 2017 at 9:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well idk if it's a tb. Frank's is only mechanical..
  11. Dec 21, 2017 at 9:05 AM
    Canks
    San Diego
    Auto trans with reverse manual valve body is the ideal set up for 99.99% of all live axle rear desert race/prerunner "trucks". Its basically an auto tranny that you manually shift in to each gear. The #1 tranny used 100 times more than anything else is a TH400 (Turbo 400)..... The torque converter absorbs the repeated shock loads like you were mentioning, allowing the tranny to live. Outside of the TH400 there are a few high end (read: Trophy truck)teams that run custom very high dollar gear boxes, but not many, and they are still auto trannies.
    I was under the impression Robby had cracked the code and was running a true "manual"/clutch tranny, but I haven't paid nearly as much attention to the rumor mill on RDC in the last couple years to stay up to date. Its entirely possible that he has a sequential tranny with a torque converter.
  12. Dec 21, 2017 at 9:56 AM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Any of you third gen guys who put on bedsides have a stock passenger side bedside preferably Grey you’d be willing to part with?
    Asking for a buddy
  13. Dec 21, 2017 at 10:21 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Long or short?
    How good of condition does it have to be?
    I have my long bed ones. Dark Metallic gray. But they are trimmed and I had flared them out a little but you can undo that. You just can’t undo the cutting.
    If those work he has to take both and they are free. They are in San Jose.
    txmxer[QUOTED] likes this.
  14. Dec 21, 2017 at 10:56 AM
    txmxer
    06 dc tacoma
    Sorry need short bed!
    erok81 likes this.
  15. Dec 21, 2017 at 11:42 AM
    jtanner21
    Anyone running 2" spacers in their rear axle ? I'll have to run the shocks outboard the frame for SUA, I guess we ran I to some problems with the charcoal canisters mounting them inboard. I'll have to upgrade to a bigger axle down the road but would I be stupid to trust that big of a spacer? I have .75s in the front already (to clear calipers on 15s) but would buy 4 to get a equal wheel base around all 4 corners. ... here's the stance currently IMG_2611.jpg
  16. Dec 21, 2017 at 11:44 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i have +2" spacers on the rear on mine to even it out.
    jtanner21 likes this.
  17. Dec 21, 2017 at 11:45 AM
    jtanner21
    Nice, do you have rear glass too? I'm only MT in the front so I'll have 2" on all 4 corners
  18. Dec 21, 2017 at 11:46 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    no rear glass for the runners unless i want to spenda shit load for some from japan.
    kinda see it here.
  19. Dec 21, 2017 at 11:48 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    but the Japanese one
  20. Dec 21, 2017 at 11:49 AM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Hawt.
    LTDSC[QUOTED] likes this.
