Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 25, 2017 at 6:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Toyota's ABS systems should be named "Anti-braking System" - I've almost been in a couple of accidents due to the system coming on ridiculously early. So glad my first gen doesn't have it. Saves me the work of having to remove it :)
    Speedo[QUOTED] likes this.
  2. Dec 25, 2017 at 6:56 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    It's part of this new thankless driving
    Too many people wanting their vehicle to drive for them.
    Every real driver I know says the same thing
    Abs will get you into more wrecks or get you killed than it will ever save you from.
    Not to mention in the 3rd gen it works in unison with the traction control to steal away the motors power to the wheels when you need to get out of the way of another vehicle and it deems you don't have 100% traction
    Dalandser[QUOTED] likes this.
  3. Dec 25, 2017 at 8:22 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    Swapped in a Ford 9" on mine, ripped out the ABS. Only get a light and if I pull the fuse pretty sure the light will go away..
    Dalandser, Caboose117 and malburg114 like this.
  4. Dec 26, 2017 at 7:10 AM
    SanClemTaco
    SanClemTaco Well-Known Member
    Sean
    San Clemente
    01 Prerunner on 37's
    Solo Motorsports XLT Kit, Giant 64
    Pull the light bulb out of the dash, the fuse doesnt cut it.
    Dalandser, Caboose117 and Cr250jumper like this.
  5. Dec 26, 2017 at 10:05 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Well...on a second gen if you unplug just one speed sensor though your speedo and tac die so having an ABS kill switch vs no signal coming from the device to the ECU is two different stories right ? I have an ABS disable switch too and it works great but my gauges are not affected by it...but if I unplug just one speed sensor gauges die.
    Dalandser and Caboose117 like this.
  6. Dec 26, 2017 at 12:04 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    There are 2 wires going to my left abs sensor. I cut one of the wires and ran it thru a switch in the dash, essentially breaking the circuit to that abs sensor. Flip the switch, cut the circuit and the abs is disabled. Everything works fine. ABS light is on but no other lights. Trans shifts properly. I used to pull the abs fuse prior to the switch and got the same results. It was a pain in the ass to pop the hood every time though.
  7. Dec 26, 2017 at 1:13 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Depending on year and model there are a few different ways of wiring up the ABS bypass switch, you and I are lucky because the 05-06 has zero traction control shit so the bypass is easier. There is a write up here on TW for how to do it that I used, it was all under the dash.
    Speedo and Caboose117 like this.
  8. Dec 26, 2017 at 2:35 PM
    Y2kbaja
    Sacramento
    Total Chaos
    copy. forgot about the traction control models.
  9. Dec 26, 2017 at 8:52 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Nope no ABS. I have the factory ABS housing (the shaft even has that ring gear on it) but just a block off plate.
  10. Dec 26, 2017 at 9:04 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    My first 2nd gen the abs was terrible and always going off. This truck it never goes off surprisingly. Haven’t needed the kill switch yet lol
    Dalandser likes this.
  11. Dec 26, 2017 at 9:08 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    Well guys... found a tundra axle. Getting a solid deal for it. Anyone have tips on the Install? Am going to try to tackle it myself. Getting the truck back from Jeff Friday. Will have to take off the shock mounts off the stock axle. That might be the only grey area for me welding lol... but I guess it's time to learn. Sucks I couldn't do the tundra axle in the 1st place but ... you live and learn :rolleyes:
    RedManRocket likes this.
  12. Dec 26, 2017 at 9:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Gonna have to cut off the leaf perches and weld on new ones. Thats about all there is too it. and your shock tabs.
  13. Dec 26, 2017 at 9:12 PM
    jtanner21
    The guy already cut em off !:) the whole axle is clean. Ready to be welded on. So basically the mounts that were welded on my stock axle outboard the frame... will relatively be welded in the same place on the new axle correct ? The axle will just be wider pushing the tires out obviously
  14. Dec 26, 2017 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not exactly. It'll be more inboard of the tundra. But realtive to the diff it'll be the same distance from center line.
    Can't measure from the drums.
    You'll want to buy all new perches too. Low Range offroad and Allpro sell them and so does Kartek
    Dalandser and jtanner21[QUOTED] like this.
  15. Dec 26, 2017 at 9:17 PM
    jtanner21
    That makes sense, didn't know if changing the axle would throw the whole geometry of things off and the bedcage and such. So same location from center diff. And then finding the pinion angle is huge right ? Something I have not the slightest clue about lol. This should be interesting. Have all the tools to get it done though, and the internet at my fingertips !
  16. Dec 26, 2017 at 9:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    been talked about in here a lot. Quick search should merit the way to do that.
    Geometry won't change really. you'll likely have to cut your fenders as the tires will smash into them possibly depending on how much up travel you have and tire size.
    Also, they are gonna stick out super far so plan on glass bed sides soon.
    jtanner21[QUOTED] likes this.
  17. Dec 26, 2017 at 9:25 PM
    jtanner21
    Cool man thanks for the info! Helped a lot! Yea , I have some glass on the way!
    Blackdawg[QUOTED] likes this.
  18. Dec 26, 2017 at 9:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    And i should clarify, your suspension geometry won't change, if you get the shock mounts as they were to the T. But your wheel travel will change slightly, just the flex travel. Because your axle is wide, it makes it longer from the pivot point. So you'll gain some there. But thats it. Vertical travel is unaffected.
  19. Dec 26, 2017 at 9:28 PM
    jtanner21
    Okay, cool. Thanks for clarifying! That's what I was worried about. Hopefully they won't be smashing through the bed lol
  20. Dec 26, 2017 at 9:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Be too far from the bed now haha
