Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 12, 2018 at 2:03 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Just have a shop fix the 3rd and be done with It and go enjoy your truck
    Couple hundred max
    ls1 prerunner likes this.
  2. Jan 12, 2018 at 2:04 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Who do you guys get driveshafts from?
    I need a new one
    With hopefully better u-joint angles
  3. Jan 12, 2018 at 2:07 PM
    anthony250f
    Anthony
    San Diego, CA
    I’m pretty sure most people have I.T shortened and a skip yoke added....that’s what I did?
    Why do you need better angles for your u joints ? And why a completely new shaft ?
  4. Jan 12, 2018 at 2:07 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Way bigger if an issue than that now
    "Supposedly"
    They drained my diff and found no damage (even though I feel differently)
    So
    Next common sense part to be broken would be the axels
    Then the driveshaft
    Then so on and so forth
    And I just don't see the point of replacing and buying new parts one at a time to chase an issue that can't currently be found
    Because
    It's winter here and I don't have a garage lol
  5. Jan 12, 2018 at 2:09 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Again out of the mouth of Toyota "they said all my driveshaft joints are shot and binding... I call bullshit but I don't seen a driveshaft being to expensive for the sake of piece of mind moving forward
  6. Jan 12, 2018 at 2:09 PM
    anthony250f
    Anthony
    San Diego, CA
    I mean if you have the money then why not go big lol. I would pull the 3rd and check it out, but I live in SoCal and it’s 70* outside lol
    Dalandser likes this.
  7. Jan 12, 2018 at 2:09 PM
    anthony250f
    Anthony
    San Diego, CA
    That’s bullshit for sure, your truck is new! Your u joints are fine. Just a excuse from Toyota!
  8. Jan 12, 2018 at 2:12 PM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Uhhhh pull the diff out? You have to pull axles out anyway to get the diff out....
    30 mins worth of work.
    Bobber Bill likes this.
  9. Jan 12, 2018 at 2:15 PM
    anthony250f
    Anthony
    San Diego, CA
    Yeah I had to pull the diff about 5 times. Got real good at that lol
  10. Jan 12, 2018 at 2:18 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I'm dying here.
  11. Jan 12, 2018 at 2:19 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Well die quietly :rofl:
  12. Jan 12, 2018 at 2:22 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    It's been 30 degrees or lower for the past month
    And it's either been raining or snowing the same duration of time.
    I do not have the interest in being soaked and freezing to try and hunt for a problem part that I am honestly not experienced enough to locate and repair.
    I don't trust mechanics here in Kentucky as far as I can throw them.
    So
    In my eyes
    It leaves me a couple options as to not blindly piss money down the drain
    Send it to griffin fab and pay kibbetech prices
    Or send it to Cali and have way more options like moore fabrication, envy Motorsports or tt Motorsports If he hasn't moved to AZ already
  13. Jan 12, 2018 at 2:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Changing out your drive shaft won't change your u joint angle..
    Airdog likes this.
  14. Jan 12, 2018 at 2:30 PM
    anthony250f
    Anthony
    San Diego, CA
    If you have a garage and are up for It I can walk you through it and help you find the problem if you want. There’s gotta be a local member though? I’m sure it’s the ring or pinion gear.
    Caboose117[QUOTED] likes this.
  15. Jan 12, 2018 at 2:45 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I agree
    I was more so asking if there were driveshafts that I could get that have better u joint angles
    As in, more range of motion and less likely to become impinged
  16. Jan 12, 2018 at 3:00 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    A u joint is a u joint. If your angles are wrong a bigger one won't help
    Bobber Bill and tubbsisland like this.
  17. Jan 12, 2018 at 3:19 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Well guess I learned something today
    I had been under the impression there were "better" driveshafts with more range of motion so they could move more without impingement
    Now I know
  18. Jan 12, 2018 at 3:54 PM
    erok81
    erok81 Well-Known Member
    Imposter
    My 37’s cycle without hitting anything.
    ...as long as they are straight. :anonymous:
  19. Jan 12, 2018 at 3:57 PM
    erok81
    Imposter
    FYI...I have more rear travel than you and my driveshaft is fine. No vibrations at all. Who setup the rear of yours? Your fav guy or the other place?
  20. Jan 12, 2018 at 4:02 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Erik set it up, and cycled it, and then it was checked again for my peace of mind by 3 other shops including envy, TTmotorsports and kibbetech
