Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 19, 2018 at 12:54 PM
    dira1987
    dira1987 Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    I didnt know about this stuff it looks like it would work great. Which style do you recommend for the battery cables? The standard flex wrap or the high heat one? Thanks for the info!
  2. Jan 19, 2018 at 1:34 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    it does. Use it all the time.
    Id just use the standard for the cables. If you wanted to sleeve them together with high heat that couldn't hurt. Especially if you plan on running them by any exhaust.
  3. Jan 20, 2018 at 6:46 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    On bedcages has anyone used 1 1/2 Inch or does everyone use 1 3/4 ?
    MadTaco461 likes this.
  4. Jan 20, 2018 at 6:57 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  5. Jan 21, 2018 at 8:19 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    1.5” will be just fine for a sua setup. It’s just holding shocks while preventing the frame from twisting too much. Good geometry is the most important part. Most people go larger because it looks good when it comes to a play truck. I’ve even seen 2” with 1.75-1.5” secondary support bars.
    Dalandser likes this.
  6. Jan 21, 2018 at 12:54 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    You want your rear to outperform your front. If I were you, I'd go straight to SUA.
    Dalandser and Coot83 like this.
  7. Jan 21, 2018 at 12:58 PM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    You can do the DMZ SUA with a shock hoop and not cut thru the bed like @Jerez.
    Jerez and jeff b[QUOTED] like this.
  8. Jan 21, 2018 at 1:23 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Some LT left overs.
    Custom Icon 4 Tube 3.0x16" Bypasses (25" Collapsed 41" Extended) 15" Oversized Resi, Brand new, never Run. Valved for the back of linked Mid size truck. Have sat on my garage shelf for 4 years so probably wouldn't hurt to open them up.
    $1600 Firm
    Blackdawg and jeff b like this.
  9. Jan 21, 2018 at 1:26 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Camburg makes a 'bolt on' SUA kit as well. That's what I'll be installing on mine. I've got 2.5x14 shocks and the Archive Garage rear shock towers, so I don't have to cut holes in my bed.
    jeff b[QUOTED] likes this.
  10. Jan 21, 2018 at 1:28 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Make dmz the top of your list. Me and I think a few others here wasted our time with the tc kit. Dmz kit only has potential for things...tc not so much.
    tfeltz73 and jeff b[QUOTED] like this.
  11. Jan 21, 2018 at 1:31 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Talk about a unicorn right there! I have only seen icon two tube bypasses up to this point!
  12. Jan 21, 2018 at 1:34 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I would hope one day to have some back up shocks just in case, but I prefer the blue.
  13. Jan 21, 2018 at 3:07 PM
    tubbsisland
    Cliff
    Arizona
    SOLD!!!
    Dalandser, Coot83 and Hawk373 like this.
  14. Jan 21, 2018 at 4:07 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Yup. He made it work with 12 in. Triple bypasses...cycles about 13.5-14 in last I saw...good enough for cruising (this is not a race truck...)
    What he said. Tim’s suppose to eventually sell it as a weld on kit like his now bolt on bed cages
    Coot83[QUOTED] and jeff b like this.
  15. Jan 22, 2018 at 5:02 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    whos got a link to a jaz oval blank plate? i know goat has them but mine is only 16 bolt not 24
  16. Jan 22, 2018 at 5:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Jd does @Cr250jumper
  17. Jan 22, 2018 at 5:10 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    That’s the 24 bolt. I have the same one.
  18. Jan 22, 2018 at 5:14 PM
    FlapJack935
    Jack
    Abq New Mexico
    mine might be an RCI cell, i could get one cut but better just to be done so i can cut it up lol
  19. Jan 22, 2018 at 7:18 PM
    J.Maynard
    J.Maynard Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    Screen Shot 2018-01-21 at 6.35.53 PM.jpg Screen Shot 2018-01-21 at 6.36.33 PM.jpg Screen Shot 2018-01-21 at 6.36.59 PM.jpg Screen Shot 2018-01-21 at 6.37.19 PM.jpg Screen Shot 2018-01-21 at 6.37.49 PM.jpg
    Well 2 weekends ago i pulled the trigger and decided to finish the rear end of my truck on my own since i couldnt pay someone lol. Had a blast out in Ocotillo this past weekend. Truck felt a little stiff in the rear may need some leafs removed and possibly some shock valving.
  20. Jan 22, 2018 at 7:43 PM
    Vasqu3zk
    Vasqu3zk Well-Known Member
    Kyle
    Bullhead City ARIZONA
    2006 Tacoma pre runner
    MCM fab UCA, ADS 2.5 extended coils front pushing 3”, fox2.0 rear.
    What tires are those?
