Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 24, 2018 at 3:44 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    your selling one? Hell yeah take that money and run.
    Dalandser likes this.
  2. Jan 24, 2018 at 3:47 PM
    J.Maynard
    J.Maynard Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    hell yea im stoked!!
    SilverGhost and Dalandser like this.
  3. Jan 24, 2018 at 4:27 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I've got a set on my MT build, and love them.
    I did a set if TC gussets, then got alignment done. Then measured the location of the cams and cut a set.of plates to put the bolts in the same locations. It's a bit of work to cut the plates and drill the holes, but otherwise a very easy install.
    Hawk373 likes this.
  4. Jan 24, 2018 at 4:54 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    2 hours? Dropping LCAs and removing the spindle (otherwise it just gets in the way). Drilling and air chiseling the old shit. Welding the new ones together. Grinding shit flat and cleaning metal. Welding. Paint. Far from a 2 hour project for me and I've done it 3 times. And even then, the only thing that has stopped the damn camber eccentrics on my rigs from rotating with spirited driving is spot welding the eccentrics to the cam tabs.
    Yes they work for those who don't have heimed uppers. Permanently Welding the eccentrics to the frame takes all of 5 minutes for those that have heimed uppers.
  5. Jan 24, 2018 at 5:04 PM
    Arcticelf
    Gladiator
    Has anyone tried welding th eccentrics with regular uppers? As long as alignment was good before welding it should work. I've only adjusted my heims once...
  6. Jan 24, 2018 at 5:04 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Ok it is more than a few hours lol. I would say it took me about 3 hours to do. The air chisel did most of the labor though lol. Welding them together does take up most of the time.
  7. Jan 24, 2018 at 5:05 PM
    Arcticelf
    Gladiator
    Hawk373 likes this.
  8. Jan 24, 2018 at 5:06 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Problem is IF you are a spirited driver and anything else gets tweaked, you'll have no way to adjust it back into spec
  9. Jan 24, 2018 at 5:06 PM
    Arcticelf
    Gladiator
    True. If anything but toe goes.out you're SOL.
    I dunno how hard you have to work for that level of "tweaked" though.
  10. Jan 24, 2018 at 5:07 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Works until you bend the frame, spindle, coil bucket, or LCA frame mounts. Then you're basically fucked.
    Arcticelf[QUOTED] and Hawk373 like this.
  11. Jan 24, 2018 at 5:12 PM
    anthony250f
    Anthony
    San Diego, CA
    My coil buckets and frame were so bent I had a permanent -4 camber lol
  12. Jan 24, 2018 at 5:13 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Not fucked fucked. You'd just need heim uppers then.
    jberry813[QUOTED] and Arcticelf like this.
  13. Jan 24, 2018 at 5:14 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    That was a conversation Jberry and I were having. I didn't do the heimed uppers or even put the TC gussets. I used the Moog camber caster bolts and havent had allignment issues. My pivots were pretty bent so I figured I would solid mount when I rebuilt them. It has yet to be a problem so I haven't worried about it.
    Dalandser[QUOTED] likes this.
  14. Jan 24, 2018 at 5:19 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yup. Which is why I say buy heimed to start with. $200 upgrade is a lot cheaper than buying new $800 uppers down the road leaving you with a non-heimed upper you can’t sell because you’re not selling paired lowers to go with it.
  15. Jan 24, 2018 at 7:45 PM
    Camerond05
    Camerond05 Well-Known Member
    Cameron
    Missouri
    2020 Tacoma DCSB
    Took me not even two hours..
  16. Jan 24, 2018 at 7:46 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ectrd and Speedo like this.
  17. Jan 24, 2018 at 9:25 PM
    doyouquaxu
    doyouquaxu Well-Known Member
    There's no general info thread on Switch-Pros that I could find that isn't in the 3rd gen or 2nd gen sections. But I just want to let you guys know what a stand up company they are. I just installed my 8100 unit that I bought through the guys at Camburg awhile ago, but just now installed it. I've been having issues trying to program it and sync to the iPhone app. After a few emails back and forth with Switch-Pros customer service, and trying some different trouble shooting methods I got a phone call from them today. They offered a full replacement/upgrade to their 9100 unit, shipped direct to me. I'm pretty blown away.
  18. Jan 24, 2018 at 10:56 PM
    Darth_taco
    Darth_taco Toyotagang_productions
    Bryan
    2012 tacoma trd sport dclb
    Ok so I have a 2012 dclb 4x4 I want opinions on a good long travel kit that isn’t over the top expensive. Or better yet just give opinions on any kit cheap or expensive.
  19. Jan 24, 2018 at 11:15 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If I was going to go out of the box for the front - straight bolt on, no fuss no muss 4x4 2nd gen I'd go Total Chaos race kit. Then there's always the regular Total Chaos kit, Camburg, Solo, Dirt King...
    There are no cheap kits - only expensive, more expensive, and f*cking expensive, even if you buy used :)
    To really answer your question about the cheap(est) kit, catch Solo on a 20% off event they have occasionally (Black Friday and Christmas recently).
    For the rear there's DMZ, Giant, Total Chaos, and Camburg; the first two are real long travel spring under kits. The second two are spring under, but don't perform as well...
  20. Jan 25, 2018 at 1:03 AM
    Darth_taco
    Bryan
    Thanks for the input I have looked at the Camburg setup with all the goodies I would want and they are proud of their shit all together 7g before tax and shipping... but I will keep looking.
