Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 5, 2018 at 7:50 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Won’t the starter pull more than 150a ?
  2. Feb 5, 2018 at 8:04 AM
    dira1987
    dira1987 Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    Awesome. What did you do with the current ground in the engine bay? What did you do with those connections?
    Honestly I'm not sure, but I sure hope not now Im nervous. I read on DezertRangers a lot of guys running a 150a and they were ok, but I didnt even think about it. I called toyota and they said the stock alternator pulls 80 amps on a 2003 tacoma.
  3. Feb 5, 2018 at 9:49 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    CV boots are the worst fucking part of LT.
  4. Feb 5, 2018 at 9:59 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    side note, SDHQ's site sucks and wont add boots to the cart.
    Caboose117 likes this.
  5. Feb 5, 2018 at 10:05 AM
    anthony250f
    Anthony
    San Diego, CA
    Do any of your guys with trucks on 35s feel like you have no power steering while at idle and not moving ? Lol
    Coot83 likes this.
  6. Feb 5, 2018 at 10:24 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    fastest way to kill your rack is to steer it without moving. Just turn while rolling
    LTDSC likes this.
  7. Feb 5, 2018 at 10:27 AM
    anthony250f
    Anthony
    San Diego, CA
    Yeah it rarely happens but sometimes while parking I will notice it slightly lol
    So it’s normal ?
  8. Feb 5, 2018 at 10:29 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    mine feels normal :notsure:
    anthony250f[QUOTED] likes this.
  9. Feb 5, 2018 at 10:41 AM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Can confirm.
  10. Feb 5, 2018 at 10:42 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Not when it's aired up. But when off-road yeah, and it gets worse the more you air down too. 10psi or under forget about trying to turn while not moving.
  11. Feb 5, 2018 at 10:50 AM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    ditto.
  12. Feb 5, 2018 at 11:01 AM
    anthony250f
    Anthony
    San Diego, CA
    Happens to me full aired up
  13. Feb 5, 2018 at 11:16 AM
    tetten
    Andy
    Socal
    Interesting.... Maybe find someone nearby with 35s and compare how easy it is to turn on the same surface? Maybe a rack swap is in your near future.
  14. Feb 5, 2018 at 11:21 AM
    anthony250f
    Anthony
    San Diego, CA
    How would I know if it’s the rack or the pump? I have almost 200k on both lol
    tetten[QUOTED] likes this.
  15. Feb 5, 2018 at 11:24 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    200k? probably getting close to replacement especially after pushing big tires for a while.
    If i was a 2nd gen id be all over that tundra rack swap from Solo
    tetten likes this.
  16. Feb 5, 2018 at 11:25 AM
    anthony250f
    Anthony
    San Diego, CA
    Yeah I’m gonna run it till it goes. Only been pushing 35s for like 5k miles
  17. Feb 5, 2018 at 11:25 AM
    tetten
    Andy
    Socal
    I haven't had problems with mine yet, and I haven't ever had to trouble shoot a PS system. I'm sure someone with more wisdom can chime in or I'm sure if you Google around you can find ways to check to verify which is the cause of the issue. (If there is one to begin with)
  18. Feb 5, 2018 at 3:36 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can check for play in the tie rods and play in the rack - since it would presumably slip all the time if it can slip under high high loads from turning with no forward or rearward motion, I wouldn't expect the gears to be skipping / missing if they don't when you have the truck up in the air. You can flush the power steering system and see if there's a filter like there is on the first gens that gets loaded with gunk and inhibits flow...
    Ruben526 likes this.
  19. Feb 5, 2018 at 3:57 PM
    J.Maynard
    J.Maynard Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    does yours make cracking and popping sounds sometimes? Mine does and i have 33s
  20. Feb 5, 2018 at 4:23 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Check your uniballs. I thought my rack was going bad, did all sorts of trouble shooting based on creaking, popping, and all sorts of awful noise. Finally I swapped out my lower uniballs and the noises were gone.
