Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 20, 2018 at 9:28 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Yes I’m shooting for top of and upper side of frame on the lower part of the “c” pillar. I ran that lower tube across the bottom because I might have to raise the floor to the tube for the up travel of the upper links. I don’t understand what a single nobe is. No rear seats. Converting to storage. Yes I’m adding tube to the roof. Didn’t mock it up because I’m still driving the truck and don’t want shot falling on me.
  2. Mar 20, 2018 at 9:53 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Here is what I did, has the added benefit of clearing up space for compressor / battery / whatever. And also acts as a sort of snorkel as water and dust don't get in that area very easily... and it is still a cold air intake
    I used this:
    https://www.summitracing.com/nv/parts/spe-9751/overview/
    plus a 4'' hole saw, took 10 minutes, just need to get some proper clamps now
    Also used aluminum tape to cover factory intake hole
    Bentrodder and LTDSC like this.
  3. Mar 20, 2018 at 10:56 AM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    drift cars and offroad trucks are polar opposites..
    SilverGhost likes this.
  4. Mar 20, 2018 at 11:46 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Without back seats the structure on the C pillar is overkill. Without back seats you're 3 tubes away from a race legal cage. Which is a plus.
    SilverGhost[QUOTED] likes this.
  5. Mar 20, 2018 at 11:52 AM
    Y2kbaja
    Sacramento
    Total Chaos
    My buddys 1st gen back seat with 2 levels of storage.
    18951430_10211531369217094_5878695951799_0dac14078a92d7660815c38ee6aebb3f44ec37ab.jpg
    sytfu510, SilverGhost and Cr250jumper like this.
  6. Mar 20, 2018 at 11:59 AM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
  7. Mar 20, 2018 at 12:14 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  8. Mar 20, 2018 at 12:43 PM
    dwphoto
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Roll out !... Not sure if I'll be dragging the pop up out with the Tacoma or if I am going to take the prerunner.
    MadTaco461[QUOTED] likes this.
  9. Mar 20, 2018 at 1:20 PM
    2002 tacoma s/c LT
    2002 tacoma s/c LT Well-Known Member
    Travis
    Carson ,CA
    2003 4DR 4WD Taco
    Someone else's build with my touch
    Dropped my new to me truck off at solo for some work on this beast
    Truck really didn't fit on the trailer.... But it worked
  10. Mar 20, 2018 at 3:23 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    That is an awesome set up. Kind of what I was thinking. Thanks for the pic. I rather be a little over kill then not doing it right. I was just thinking that the more strength to the "C" will help with the bed cage for coilover and bypasses.
  11. Mar 20, 2018 at 4:15 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
  12. Mar 20, 2018 at 6:28 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Doesn't run?
  13. Mar 20, 2018 at 6:29 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    To whoever was complaining about trying to get king bumps out of their mounts a few weeks ago...yeah they're a sob. Luckily I sprayed some lube in and let it soak for a little while. IMG_2087.jpg
    And whoever suggested antiseize when they go back in, I'm definitely going to try that. This is after only 4 months
    sytfu510, ls1 prerunner and Coot83 like this.
  14. Mar 20, 2018 at 6:31 PM
    2002 tacoma s/c LT
    Travis
    Carson ,CA
    2003 4DR 4WD Taco
    No it does. But my last build was there so had to pick that up to swap places. Shop is full. So I towed it out to be able to drop it off and use the trailer for the other truck which is a giant paper weight.......
    image.jpgso swapping my good parts for the front of the new truck...
    Dalandser likes this.
  15. Mar 20, 2018 at 7:48 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    dwphoto[QUOTED] and DMCtacoma like this.
  16. Mar 20, 2018 at 8:04 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    That was me lol
    Mine look disgusting
    When I put mine back on I'm gonna fill the holes at the top of the can with hot glue to seal out the dirt and grime and if I need it I'll just peel it off
  17. Mar 20, 2018 at 8:07 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Not a bad little thought on that. The gf does have a hot glue gun
    Caboose117[QUOTED] likes this.
  18. Mar 20, 2018 at 8:12 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I'm no professional by any means and you can't put a price on your own safety so if it makes you feel better to have the inside completely filled with steel by all means go for it.
    A small tidbit I've heard him say is no one tube should have more bends in it than what adds up to 120 degrees, I believe that was the figure. I didn't see that in your mockup but I was more amazed at the spiderweb of supports.
    As for the supports themselves, again, I'm sure someone in this thread is more educated and experienced than myself in cage building but a simple X on tbe rear bulkhead and a single / slant in the middle should suffice.
    Then you could get dimple plates to gusset the joints for added strength without adding hardly any weight.
    Lastly when welding the halo you cut the floor in the body to allow the entire cage to drop down then pick it back up when done and weld in plates to the floor to support the cage and tie it into the body to prevent the uprights from punching through the sheet metal in the event of a rollover and to keep the cage in place.
    Again though I am not the professional cage builder so please take my opinions with a grain of salt.
    :thumbsup:
  19. Mar 20, 2018 at 8:24 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I vote getting a coral pink trip going. Closer to us at least
  20. Mar 20, 2018 at 11:59 PM
    Babyjake16
    Babyjake16 @project_traitor
    Jake
    Utah
    2008 Super White Tacoma
    33" Nitto Trail Grapplers 17" TRD Matte Black Wheels ICON Stage 5 w/ differential drop 30% Tint 2 - Pioneer 12" Shallow Mount Subs Focal Speakers Pioneer Head Unit 2 - Pioneer Amps Custom Stickers/Badges Paracord Grab Handles Painted Interior (all panels, headliner and carpet) Clazzio Leather Seat Covers with leather arm rests Ditch Lights 3 - 8" HieseLight Bars in bumper Rock Lights - Cali Raised LED Custom Fabricated Front Bumper - Blackout Fabrication Rock Sliders - DOSECC Fabrication Bushwacker Fender Flares (color matched) Morimoto LED Fog Lights
    Hey bros and bras. I require you’re knowledge. What does everyone think about the 63 Chevy leaf swap? Good bad? Recommendations on which other way to go if bad? I’ll probably be going with some 14” icons. But the rears a whole new bread. Thanks!
