Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 19, 2018 at 4:57 PM
    tfeltz73
    tfeltz73 That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    F that, I had to wait to long. Also I have spindle gussets but I’m sick of working on the truck and just want to drive the it. Once I can drive it for a bit I’ll weld in the gussets. I’ll look into uca gussets.
    BikerinBlak909 likes this.
  2. Apr 19, 2018 at 5:31 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    My fenders are from Advanced. Measuring inside the lip for how far the clip would push on without starting to spread and climb the curve of the corner, it's about 1/2". The flat outside portion of the lip is about 3/4". The lip measures a bit over 0.1".
    Dalandser likes this.
  3. Apr 20, 2018 at 7:47 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    happy Friday everyone ! post a pic of your ride my truck has came a long way it taken me about 3 years to build and still not done DMZ kit will be next
    p.s build not bought and no help for mom and dad its all me working my ass off to have nice things
  4. Apr 20, 2018 at 7:59 AM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Nice lookin truck. :cool:
    dillonk1602[QUOTED] likes this.
  5. Apr 20, 2018 at 9:16 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    This^^
  6. Apr 20, 2018 at 9:23 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    @Caboose117
    "Dude why do you drive like that?"
    "cause race truck"
    now that's just awesome :headbang:
    Arcticelf and Caboose117 like this.
  7. Apr 20, 2018 at 9:25 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  8. Apr 20, 2018 at 9:26 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    It makes all the TW guys in Kentucky mad haha
  9. Apr 20, 2018 at 9:26 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    hahah hell ya
  10. Apr 20, 2018 at 9:38 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    So contrary to what almost everyone on here will say but I would start with 63" chevy springs under axle and a 12" shock. then mount the shock on a long mount on the axle then lay the shock back and build a mount there. It won't be vertical and optimal but it will work ok. I did this on my 4Runner and it worked good. Again, it wasn't ideal but it worked.
  11. Apr 20, 2018 at 10:08 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    For those with DMZ SUA kit, what is the angle on your diff and how do you measure it?
  12. Apr 20, 2018 at 10:24 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    If you don’t have any vibrations currently, measure your current pinion angle at ride height and match it when you install the new perches. It’s pretty simple. Just make sure the truck is setting at the same height it was when you took your preliminary measurements.
    Otherwise you’ll need to set the pinion to your own truck by setting all your driveline angles. I wouldn’t use someone’s else’s measurement. No guarantees their truck is setup just like yours
    Rakso[QUOTED] likes this.
  13. Apr 20, 2018 at 10:30 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    TRDZILA and Rakso[QUOTED] like this.
  14. Apr 20, 2018 at 10:32 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    If you read the install instructions it’s very straight forward
  15. Apr 20, 2018 at 11:20 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I doubt he has them since this is a redo of the original install
  16. Apr 20, 2018 at 11:26 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I do have them and nowhere it says how to do it. Do you have a copy you can snap a pic?
  17. Apr 20, 2018 at 11:28 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
  18. Apr 20, 2018 at 11:48 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Yeah I had a talk with Tim yesterday, I got the perches and shock mounts from him. He was talking around 5° but then again to be sure some driving has to be involved plus it varies from truck to truck. Not to mention slip yoke is needed. Gotta call driveline shop.
  19. Apr 20, 2018 at 12:05 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Ah yeah if you need to add the skip yoke then it may be a little different.
  20. Apr 20, 2018 at 12:10 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    If you can’t follow Tim’s instructions on this you probably shouldn’t be doing a lot of things. His instructions give you step by step and pictures. No math involved.
