Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 2, 2018 at 1:21 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Thank you!
  2. May 2, 2018 at 1:25 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    since were on the topic of racks. My rack clicks going in/out on the driver side only. I pulled the boot back and its the steering rack that seems to either have play or makes noise. I first thought it was a loose inner TRE but those were tight.
    Is my rack on life support? No leaks just a click and slight movement. Bolts are tight as well.
  3. May 2, 2018 at 1:27 PM
    89ztrain
    89ztrain Well-Known Member
    North Carolina
    '11 TRD Sport 4x4
    Whitecloud and BikerinBlak909 like this.
  4. May 2, 2018 at 1:36 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I'm on my 2nd rack and will be needing a 3rd one soon, hopefully I can hold out for the MarRack..
    The "MarRack" in development by MarlinCrawler but looks promising none the less..
    https://www.tacomaworld.com/threads/bigmike’s-big-journey-new-2016-tacoma.427850/page-29#post-17719633
    you'll have to go back a few pages see how the spindles were modified for this new rack and other tidbits
  5. May 2, 2018 at 1:38 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    I want to keep my bed
  6. May 2, 2018 at 5:01 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    cut a series of 3/16ths plates for the inside of the frame to make it a fully boxed, then add several X cross members that go top to bottom, and at least 2 count 3" diameter tubes that go all the way through inner and outer frame walls, so you can see light through the truck.
    *The above based on inspection of frames for heavy and super duty trucks, not any knowledge of linked taco frames.
    Caboose117[QUOTED] and Dalandser like this.
  7. May 2, 2018 at 7:50 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Looks familiar :cool:
    Dalandser likes this.
  8. May 3, 2018 at 6:14 AM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    How's it holding up?
    Coot83 likes this.
  9. May 3, 2018 at 7:53 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    found some old pic thought you guy would like
  10. May 3, 2018 at 8:00 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    It's so cute and tiny
    MadTaco461 likes this.
  11. May 3, 2018 at 8:20 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    dat 6" fender with stock suspension look yo'
    edit - just a JK Dillon I know you have a full LT set up now :)
  12. May 3, 2018 at 8:27 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Lol was just running deliveries at work and saw a 2nd gen trd or, and thinking about this I thought there was something wrong with it. Nope it was just completely stock and looked small.
    Arcticelf likes this.
  13. May 3, 2018 at 8:34 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    One tab left :muscleflexing:
    dillonk1602, MadTaco461 and Dalandser like this.
  14. May 3, 2018 at 9:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  15. May 3, 2018 at 9:23 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nope and I'm assuming nope. You can always re-drill the driveshaft, but 2nd gen Tundras are way wider than the first gen Tundra axles that people usually use. It's what 2nd gen Tacoma guys with +6" kits use. Stick with first gen (00-06) Tundra axles - they'll most likely be less expensive too!
  16. May 3, 2018 at 10:30 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Anyone need a tundra or t100 axle. Got one of each
  17. May 4, 2018 at 7:18 AM
    Crash721
    Crash721 Well-Known Member
    Brandon
    2013 Tacoma PreRunner
    285/70/17 BFG KO2's 4" Maxtrac spindle lift kit. Caliraised 30" slim led bar
    Can someone tell me if my findings are correct or not? Factory wms-wms for a 2nd gen is 60.75" front and back correct???
  18. May 4, 2018 at 7:26 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    That's first gen rear axle width. 2nd gen is around 66".
  19. May 4, 2018 at 7:37 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    front wms to wms varies depending on how much lift you have too , as you lift the front end the front end pulls in narrower so if you need a precise measurement you should measure your own truck under load
  20. May 4, 2018 at 7:59 AM
    Crash721
    Brandon
    Well I do know that the lift I have gives me an extra 1.5 in overall width im just trying to double check what the straight from the factory width is.
