Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 11, 2018 at 11:45 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Wow so what the actual fuck. I've been dealing with this single Uniball trapped in a Camburg UCA for like 3 weeks now. 12 ton press-nope. 20 ton press- nope. Put it back on the truck currently have ball join press cups attached with a bolt through the whole thing and its just laughing at me. I'm actually kindof scared its gonna snap the Ball join press cup or something as I keep cranking on it >_<. Don't currently have a torch I can take to it, but soaked it in PB blaster for about a week straight.
  2. Jun 11, 2018 at 11:51 AM
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    That doesn't seem right. Have you tried contacting Camburg and see what's their take on it? If I remember correctly, you had a bolt fail previously? If it was you, maybe when the truck slammed to the ground the cup got out of round? Also, how rusty was the snap ring?
  3. Jun 11, 2018 at 11:55 AM
    VolcomTacoma
    Jeff
    NorCal
    Contacted Camburg, they said try to press it out. I inquired about just sending it to them so they can fix it so I don't damage it, they said that's an option as well. Bolt failed on LCA Adapter on the other side, I decide to replace uniballs and bolts on the other side that didn't need a CV boot replacement. Sigh. Snap ring was pretty rusty, ended up having to use a screw driver to pry it out while holding it with snap ring pliers.
    I'm gonna crank a little more on it. But I'm getting to the point where im gonna say F it and just ship it to Camburg and let it be their headache.
  4. Jun 11, 2018 at 11:57 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    i had to use a 20ton press, torch, and pb blaster to break mine out.
  5. Jun 11, 2018 at 11:57 AM
    VolcomTacoma
    Jeff
    NorCal
    Yeah I have a feeling that's what I'm gonna need as well. Regret not getting the 20 ton now.
  6. Jun 11, 2018 at 12:25 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Get some aero kroil and soak it overnight. It’s the best penatrant I’ve ever used. I’ve used it on huge bolts and bearing torqued to thousands of pounds and have been successful using it when half a dozen other brands wouldn’t get them to budge.
    VolcomTacoma[QUOTED] likes this.
  7. Jun 11, 2018 at 12:29 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    this? both my lower shock bolts are frozen and id like to get them out reasonably without resorting to drilling.
    https://smile.amazon.com/Aero-Kroil...ting+spray&dpPl=1&dpID=41eZ225wluL&ref=plSrch
  8. Jun 11, 2018 at 12:32 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    huh. Well hope it works out. The low torqure from those gears is epic. I know im a 1st gen but god DAMN I love the 5.29s. Plus I added a blower and man...so damn fun now in the dirt.
    Lol that sucks.
    Why put on huge 37s to crawl the mall? Seems like a lot of money for tires..
    Well...im not gonna say hell no to that. LS would be sweet.
    Between you and @dirt addiction trucks..im not sure if I should pour the money into mine or just wait for one of you to sell and start saving :laugh:
    Coot83, Arcticelf and snowsk8air2 like this.
  9. Jun 11, 2018 at 12:52 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    another 1-2 hundred. not that much. havent fully decided.
  10. Jun 11, 2018 at 1:01 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    Sacrifice[QUOTED] likes this.
  11. Jun 11, 2018 at 1:06 PM
    VolcomTacoma
    Jeff
    NorCal
    Ordered a 13OZ can. Will blow through the rest of the PB Blaster this week I guess and see if that does anything until the kroil shows up. We use the green can Kroil at work to lube valves with.
  12. Jun 11, 2018 at 1:08 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Using heat is key, also maybe its slightly angled? You really want to press it out evenly. Might be worth a try to press it back in and then try uniformly pressing it back out making sure no side is being pushed out higher than the other.
    Heat really does help though
  13. Jun 11, 2018 at 1:37 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Alright suspension question for the gurus out there. Not tacoma related but for a T4R. Getting ready to put the metaltech LT springs in on our 5th gen and am in the process of building adjustable links and panhard to be able to fine tune things with the added height and droop the springs will likely provide.
    As I do my research I am finding that some people's opinion is that just being able to adjust the panhard is sufficient while others believe that a panhard drop or lift bracket is better to keep the panhard as level as possible and reduce sway.
    So looking at joints last night I come accross the offset heims that Barnes4wd sells (http://www.barnes4wd.com/Offset-Heat-Treated-Chromoly-78-14-X-34-Heim-Joint-_p_696.html) and get to thinking that if I used an offset joint on each end of the panhard (one offset up and one offset down) I could essentially replicate a panhard drop and lift while also getting adjustability. The offset heims are about a 1" offset from the center axis so 1" offset down on the upper bracket and 1" offset up on the lower bracket and my panhard should be about where it needs to be for the ~2" of lift I should get with the springs.
    Am I missing something? Overthinking it?
  14. Jun 11, 2018 at 2:08 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    I don't think the offset hiems will help because your not changing the actual pivot locations, and those joints will put a bit more sheer force on the hem shank since that's what the Panhard is for( side to side axle force)
    stumbles likes this.
  15. Jun 11, 2018 at 2:15 PM
    zscott
    Zach
    Utah
    Yeah the extra forces were one concern I had. However, compared to the factory panhard they still may be stronger with a 3/4" shank.
  16. Jun 11, 2018 at 2:23 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i have lower links, 3" LT Metal Tech springs and i was able to dial in my droop locations better with the adjustable links. I still need to adjustable panhard as my axle when drooped out is slightly to the right because it needs to be extended a touch.
  17. Jun 11, 2018 at 2:27 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Kroil..................don't know why, but it always comes in last in these online tests. Maybe that's because nothing at all is better than anything? I dunno......but there's a good chance Kroil ain't worth the extra you pay.
    You be the judge:
    https://www.youtube.com/watch?v=xUEob2oAKVs
    https://www.youtube.com/watch?v=YeTNXbDbHcM
    bravelilshitposter likes this.
  18. Jun 11, 2018 at 2:30 PM
    VolcomTacoma
    Jeff
    NorCal
    Honestly I'll keep spending money on sprays for now before I snap something or break something that costs waaaaay more.
    Coot83 likes this.
  19. Jun 11, 2018 at 2:31 PM
    Stocklocker
    17TRDORDCSBAT
    I am with you there, but have come to the conclusion the dime-store variety of sprays is likely as good as the top-shelf products like Kroil. Who knows? Good to keep an open mind.
  20. Jun 11, 2018 at 2:32 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    If the Kroil doesn't work, I'd just send it in to Camburg if you can swing not having the arms for a bit, that way if they break something in the process of getting it out, they might cover it. I mean you've been using the right tool for the job and elbow grease and it's still not budging.
