Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 27, 2018 at 4:28 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I spent way to much time trying to figure out what you ordered from Revzilla for your truck before I realized it was just a paint box LOL
  2. Jun 27, 2018 at 4:34 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Tc mid travel sua revived.
    dillonk1602 likes this.
  3. Jun 27, 2018 at 5:16 PM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
  4. Jun 27, 2018 at 5:22 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Regardless of shock length, due to the confines of stock hangers the Mac the leafs can cycle is 12 inches of travel without being wider. Partly why the dmz kit and other LT sua kits are wider as they need it to House a wider pack to get bigger travel numbers.
    Caboose117 likes this.
  5. Jun 27, 2018 at 6:35 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Longer?
    dillonk1602 and LTDSC like this.
  6. Jun 27, 2018 at 9:47 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    thicker
    Dalandser, dillonk1602 and LTDSC like this.
  7. Jun 27, 2018 at 10:41 PM
    TacomaQuadRacer
    TacomaQuadRacer Golden_TRD
    Hunter
    Boulder Creek, CA
    01 Tacoma SR5 Pre-Runner Double Cab
    Front: Solo XLT Kit w/Kings. Rear: Fox 2.0’s and adjustable shackle.
    If you’ve still got it all I’d be interested, PM me
    Dalandser likes this.
  8. Jun 28, 2018 at 5:54 AM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Sent a pm
  9. Jun 28, 2018 at 9:27 AM
    wheelCAD
    wheelCAD Wheel Designer
    C
    Orange County, CA
    2012 LT 4x4
    Raceline Wheels, King, Falken Tire, Baja designs, Atlas Springs, McNeil Fiberglass, TC LT +2"
    Question for you guys. I want to run my theory by TW on my alignment.
    Alignment shop just did my LT alignment twice ($$) and we still can not get the camber or caster dialed in to TC's specs using the recommended procedure.
    My Theory is my heavy steel bumper and winch along with King springs might not be set up for the weight thus sagging the front of the truck. Thoughts?
  10. Jun 28, 2018 at 9:45 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    What are your current alignment numbers?
    LTDSC likes this.
  11. Jun 28, 2018 at 9:48 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    What are the specs you are trying to get and what specs are you getting?
  12. Jun 28, 2018 at 9:51 AM
    zscott
    Zach
    Utah
    Also, what size/rate springs are you running?
  13. Jun 28, 2018 at 10:16 AM
    wheelCAD
    C
    Orange County, CA
    2012 LT 4x4
    So TC recommends 3.5 to 6.0 Degrees of Caster and -1.0 to +1.0 Camber and this is where I am at:
    King 3.16.600 Springs
  14. Jun 28, 2018 at 10:49 AM
    zscott
    Zach
    Utah
    It is going to be tough to get more than 3 degrees of caster while keeping your camber between 0 and -1. If you drop your caster a little on both sides down to the 3-3.5 range I bet you will have the adjustment needed to get the camber right. You aren't too far off and to be honest there are plenty of people that run up to -2 degrees camber on Long travel rigs, just have to watch your tire wear.
    Airdog likes this.
  15. Jun 28, 2018 at 11:02 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Are heimed UCAs worth the upgrade cost? I'm putting together my spreadsheet to scare my bank account.
    dillonk1602 and Dalandser like this.
  16. Jun 28, 2018 at 11:03 AM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    unless your really gonna be using it and beating it id say no... personal preference though.
  17. Jun 28, 2018 at 11:04 AM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    nice. sounds like more money to spend on shocks then.
  18. Jun 28, 2018 at 11:10 AM
    zscott
    Zach
    Utah
    They do give you a little more option to mess with your alignment. I am in the process of modifying my uppers to have heims because I am out of adjustment on the alignment and would like a bit more caster.
  19. Jun 28, 2018 at 11:11 AM
    FlapJack935
    Jack
    Abq New Mexico
    exactly lol
  20. Jun 28, 2018 at 11:13 AM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Hmm, I suppose I won't know my adjustment range until I install them. That's tricky then.
