Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 4, 2018 at 11:33 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
  2. Oct 5, 2018 at 12:26 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Unfortunately rear end is still stock but I got bedsides to put on. And then the tundra axle..
    Dalandser[QUOTED] likes this.
  3. Oct 5, 2018 at 12:38 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    4.5 right? U fit em on ur truck?
  4. Oct 5, 2018 at 3:30 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Yeah, I had a 3 way call with Ryan at raceline and Bobby at solo.
    Ryan spec’d The wheel and Bobby verified the fitment.
    Ryan basically asked him what the minimum positive spacing it needed to clear the spindle/brakes
  5. Oct 5, 2018 at 6:25 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nice! Dialed
    Not bad for stock @RedManRocket
  6. Oct 5, 2018 at 6:37 AM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    I get told that nearly every day it seems like. It looks steep because it is so tight to the body beneath the grille, not spaced off the body. So instead of my bumper having a leading edge to dig into stuff, it just never actually hits the ground. I have offroaded it pretty hard and my bumper never touched anything. So I think I will keep it.
  7. Oct 5, 2018 at 6:47 AM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    its because he didn't cut out the old bumper support deal. so it goes down under that first because it sticks out so far that why it gives it the flat front end. cut it out and redo the bumper to get the correct angel so if you do see air and land nose first its not gonna make you go end over end but itll push your back end down.
  8. Oct 5, 2018 at 6:50 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Ouch yea I totally see that happening. I think even mine is possibly a little too steep should I see air after moving back out west.
    Tango Bravo likes this.
  9. Oct 5, 2018 at 6:54 AM
    FlapJack935
    Jack
    Abq New Mexico
  10. Oct 5, 2018 at 7:05 AM
    TrapComa
    Mason
    Cedar Park, TX
    I AM NOT CHANGING MY BUMPER. It works well for what I use it for, I am not a dumbass and don't face plant my truck, and also this would work better if I did, because its flat and would land on the plate, not leading with a tube like most bumpers. I am sorry that my bumper doesn't follow what the rest of the world aspires to see in a bumper. If you don't like it, please buy it from me and fix it.
    Y2kbaja likes this.
  11. Oct 5, 2018 at 7:07 AM
    TrapComa
    Mason
    Cedar Park, TX
    My truck has been in the air multiple times. We are probably nearing hundreds of times at this point. The bumper has never once touched the ground. I didn't design it to save me from being a dumbass, I designed it because I know how to drive and didn't want my bumper getting torn of from being used as a skid plate.
    Also I am unsure how you think your bumper is any better?
  12. Oct 5, 2018 at 7:21 AM
    TrapComa
    Mason
    Cedar Park, TX
    You literally have a hacked carbon fiber hood, an oil cooler hanging out of your grille, and literally no other mods to your truck. the title of your build thread is "title". Get outta here stray dog, no food in here
  13. Oct 5, 2018 at 7:21 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    here ya go
  14. Oct 5, 2018 at 7:28 AM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Yeah it's pretty clean. I got it from SDHQ but @mesojdm makes a better full-replacement part with switch-pro integration as well as other buttons. I just already had the SDHQ one and it's kind of an inconvenience to pull apart. I do wish all the buttons matched though and his allows for that.
    Caboose117 likes this.
  15. Oct 5, 2018 at 7:29 AM
    TrapComa
    Mason
    Cedar Park, TX
    [​IMG]People on this forum are feeble minded enough to thing that a bumper like this would be more effective in a nose div than mine with a big flat plate.. Plz tell me what part of this bumper is going to hit the ground first. And if you think its the plate plz don't ever mention me again
    LTDSC likes this.
  16. Oct 5, 2018 at 7:35 AM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    It looks good to me. Cant see any reason for you to hate on it. It dose have a good approach angle, cant argue that.
    LTDSC and jeff b like this.
  17. Oct 5, 2018 at 7:43 AM
    Basikbiker
    Trav
    Ok close fitting bumpers are great and all until you actually use it as bumper (intentional or not) when they're tucked real close usually they smash your headlights,grill, wrinkle your hood, push your core support far enough to where your fan pops a hole in the radiator, etc. How do I know? I've done it a couple times, I'm on my 4th bumper on my truck.
    Personally it would look better if the front plate tapered more \ / , it would get rid of that boxy look to it. Cutting the crossmember out and tapering it back helps alot with approach angle if your 4 wheelin(didnt see if your 4wd?) If you ever go hit sand dunes that crossmember not being there helps a ton and keeps your bumper from shoveling a dune face.
    Reguardless anyway bolt on bumpers fold up and smash everything in their path when you get in a wreck.
  18. Oct 5, 2018 at 7:44 AM
    Basikbiker
    Trav
    That's not a picture of his truck
  19. Oct 5, 2018 at 7:51 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Not sure I agree with the bolt on bumpers fold up and smash everything when you get in a wreck. Poorly designed ones might. I rearended someone with my bumper and the entire bed of the truck I hit crumpled up, frame bent, bumper was toast etc. All I had was a scuff on my winch fairlead and my shackle mount.
    It also is possible to get a decent angle without sticking out too far while keeping the the cross member. I have never done dunes so I could see how it would pick up sand like a plow though since it hangs so low.
    LTDSC likes this.
  20. Oct 5, 2018 at 7:56 AM
    TrapComa
    Mason
    Cedar Park, TX
    Fortunately I don't plow sand in the dunes either, because I live in Texas. People fail to read the license plate when they are hate masturbating to my bumper lol.
    Also people fail to realize that I have far better approach angle that most trucks on here because my truck has lift spindles, although everyone on here doesn't have the fortitude to admit that they didn't think of that
    Shmellmopwho likes this.
