Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 27, 2018 at 2:27 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    The bolt holding my uniball adapter to my LCA continually comes loose. I am using a grade ten bolt with a nylon locking nut torqued as tight as I can get it.
    Would using a second nut / jammer nut be appropriate? Any other ideas on how to keep this thing tight?
  2. Oct 27, 2018 at 2:36 PM
    Tbasch
    Tbasch Well-Known Member
    Tanner
    Orange County, California/ Forth worth, Texas
    2008 DCSB Tacoma
    If you haven't tried lock tight I would I used blue Locktight on mine and it hasn't moved. If you have tried lock tight maybe you might need a new locking nut?:notsure:
    Arcticelf likes this.
  3. Oct 27, 2018 at 2:42 PM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Tack it on? Or maybe 1/16” drill bit and some safety wire?
    tubbsisland and Tango Bravo like this.
  4. Oct 27, 2018 at 3:58 PM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Try searching around for aviation hardware like this site or A&P techs at a local airport might have something for you.
    http://aircraftproducts.wicksaircraft.com/viewitems/aircraft-nuts/drilled-jam-nut
  5. Oct 27, 2018 at 4:09 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    A jam nut is a good idea, do not use loctite on nylocks it breaks down the nylon. If you want to try loctite use a regular but.
    Tango Bravo likes this.
  6. Oct 27, 2018 at 4:13 PM
    tacticaloverland
    tacticaloverland Well-Known Member
    Nick
    Fort Worth, TX
    2012 LT Tacoma TRD
    Long Travel on Kings & Camburg
    QUESTION:
    Super loud squeaking/creaking coming from both sides of my front suspension. I am running camburg LT kit with kings. I bought new uniballs as well as new bushings for the UCA. Does anyone think thatll do the trick or could i possibly be dealing with something else? The noise appears to be coming from the top of the suspension but could very well be coming from the lower control arm. Any other replacement suggestions?
    Thanks
  7. Oct 27, 2018 at 6:38 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Use a stover nut. Its a metal locking nut . No nylon
  8. Oct 28, 2018 at 2:25 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Squeak and creak sounds like a uni-ball.
    Get some tri-flow dry lube on Amazon and pour a bunch on. If the noise goes away you've found the source.
    The fix is a new uni-ball or a louder radio. I lean towards the latter.
  9. Oct 28, 2018 at 4:57 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    Ordered a 2" spacer to put my old 35s on my 3rd gen...... I hate stupid ideas
  10. Oct 28, 2018 at 8:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Actually it's best not to spray it with anything and just wash them with high pressure water. Lube will just attract contaminates and destroy the Teflon liner.
    Plus every uni ball I've lubed just makes more noise later. The ones I leave alone stay silent
    tacomgee likes this.
  11. Oct 29, 2018 at 5:25 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    x2. even when i installed those mcm uppers they squeaked constantly when i tried using lube. stopped and all was good
  12. Oct 29, 2018 at 6:40 AM
    Arcticelf
    Gladiator
    Absolutely leave them alone. I just wash with a hose and ignore. but once the noise starts lube is the only way to make it stop, other than new uni-balls.
    ETA: I'm running uni-ball suspension in the north east, where we have road salt and sand all winter. So half the year its like I'm driving on on dirt every day.
    Hawk373 likes this.
  13. Oct 29, 2018 at 11:56 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Garage goals engaged....Finished up my garage and wanted to share something different.
    What a difference some DIY magic went a long way. Floor to ceiling caulk, patch, and paint. 4 led shop lights, led motion lights, new Ryobi wifi belt drive opener with fan and parking lasers, and security devices. Epoxied floor grey with flakes and a polycuramide clear top coat. New Era cabinets, custom backsplash, under cabinet lighting, and BT subwoofer system. It's not the best garage with a fleet of Ferraris in it and lifts but I did it my self and I'm enjoying every bit of work put in. I spend more time out there in the man cave than I do the living room.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  14. Oct 29, 2018 at 4:52 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    interesting...Mine were squeaking like crazy after cleaning them up when doing my bushings. Lubed them up and they shut the fuck up.
    but I don't have LT....I just browse in here
    Also, I envy dudes garage....I think Im going to demo mine and start fresh. that motivated me
    Speedo and j0shu4 like this.
  15. Oct 29, 2018 at 7:15 PM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Go back to nor cal bs thread you noob.
    Jk.
    But mine were being loud as fuck until I spent the weekend on the sand and dirt..
    Now there quite.
    It's just part of the uni ball game. Just remember replace every other yr before they get to bad.
    Fernando[QUOTED] and Arcticelf like this.
  16. Oct 30, 2018 at 3:38 AM
    Arcticelf
    Gladiator
    I'm pretty convinced it's truck (read driver and geography) dependent on what makes them shut up and what doesn't.
    I only wish I could get 2 years out of a set...
  17. Oct 30, 2018 at 3:26 PM
    Chepepe
    Chepepe Well-Known Member
    Jose
    Im also concidering going with btf. Just a regular LT kit. Would you know if they offer shock tower guccets and rear leaf spring kits?
  18. Oct 30, 2018 at 3:48 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Dry Teflon lubricants like Triflow do not contain heavy oils and do not leave a residue that will attract dust or dirt. Spraying it into a uniball refreshes the Teflon liner and will reduce noise and in milder applications can extend the life of the uniball itself. Very common practice.
  19. Oct 30, 2018 at 4:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've never had good luck with any spray lube. :notsure:
  20. Oct 30, 2018 at 4:25 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Since everyone else overlooked it: HOLY FUCK that looks amazing!!! Perfect set of toys to have in there as well. :drool::drool::drool::drool::drool::drool: That CTS-V Coupe looks like a monster.
    And just because:
    Look at this guy with his floor to ceiling caulk :jerkoff: :D
