Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 13, 2018 at 8:50 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    That's his race rig for KOH coming up. Pretty sure he made the bumper himself.
    And an update on me. Went out to scratch my itch to drive the truck just now. Almost two weeks not driving it and I am forgetting how it handles. Drive great, I just wasn't as confident as I used to be. Also hit a tree root and knocked the damn alignment out, again. It may be time over winter break to learn how to do alignments at home and solid mount/ gusset the lowers.
  2. Dec 13, 2018 at 10:19 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I know exactly what you mean, I daily my truck a whole three miles to work during the week...but on the weekends we always roll in my girls stock Xterra. I always think something is loose on my front end when I first drive into the office.
    snowsk8air2[QUOTED] likes this.
  3. Dec 13, 2018 at 3:38 PM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
  4. Dec 13, 2018 at 8:23 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    ugh making a new carrier bearing crossmember to hold the "wookie" bearing/pillow block.....kinda sucks...overhead welding is something I truly do not enjoy lol
    Tacomoto23 likes this.
  5. Dec 14, 2018 at 7:16 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Overhead is the worst welding. Try not to set yourself on fire.
    Basikbiker[QUOTED] likes this.
  6. Dec 14, 2018 at 7:46 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    90% of the welding I do on my truck is on my back overhead.
    Basikbiker and Arcticelf like this.
  7. Dec 14, 2018 at 7:56 PM
    Arcticelf
    Gladiator
    I've gotten smarter about that, now that I have a better shop, but it's still too much.
  8. Dec 14, 2018 at 8:01 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Just need a lift
    Arcticelf[QUOTED] likes this.
  9. Dec 14, 2018 at 9:36 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That just means you're standing up instead of laying down..easier to lay down haha
    Arcticelf likes this.
  10. Dec 14, 2018 at 9:39 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Not when a bead rolls down your shirt :rofl: . No personal experience but some buddies in the Navy showed me some scars on their chest (no homo) from when a bead fell into their shirt and burned its way down their chest. Ouch.
  11. Dec 14, 2018 at 10:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haven't done that..done the croch though..and foot..chest would suck
  12. Dec 14, 2018 at 11:10 PM
    Basikbiker
    Trav
    I've literally caught my shirts on fire multiple times...caught my pants on fire lol
  13. Dec 15, 2018 at 6:32 AM
    Arcticelf
    Gladiator
    I do.
    Bur it does mean you can adjust the height a little so it's not half way in between.
    Bentrodder likes this.
  14. Dec 16, 2018 at 11:32 AM
    Basikbiker
    Trav
    Crossmember shenanigans done and whoop tested....mint!!
  15. Dec 16, 2018 at 11:36 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    What pillow block is that? I've seen some other posts on the forum that mentioned using a pillow block for the center bearing but nothing that says what people have used. I've looked at specs for some, but all of the ones that I've looked at with the correct bearing ID had too low of an RPM limit.
  16. Dec 16, 2018 at 12:42 PM
    Basikbiker
    Trav
    It's a McMaster carr part number....1.5" I'd bearing...its for the "wookie strength" carrier mod....works fine no vibes at 85-90mph 4:88's on little 37s...thru whoops too
  17. Dec 16, 2018 at 1:51 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I have a used one with very low miles I can sell if you want to try it out but be aware that you must build a custom crossmember for it like @Basikbiker did for it to be positioned correctly. It makes your driveline feel so solid BUT it’s harsh for a daily driver because you no longer have any dampening in your driveline. I ended up doing a double Cardon one piece shaft.
    Caboose117 likes this.
  18. Dec 16, 2018 at 1:53 PM
    Basikbiker
    Trav
    I was gunna do the one piece but I'd have to redo my upper link and I really dont want to...its not bad on the vibe road noise if you rubber mount it like I did on the ends with bushings...I even drilled a couple holes in the rubber bushings to make em a lil squishier
    buyobuyo likes this.
  19. Dec 16, 2018 at 3:51 PM
    Babyjake16
    Babyjake16 @project_traitor
    Jake
    Utah
    2008 Super White Tacoma
    33" Nitto Trail Grapplers 17" TRD Matte Black Wheels ICON Stage 5 w/ differential drop 30% Tint 2 - Pioneer 12" Shallow Mount Subs Focal Speakers Pioneer Head Unit 2 - Pioneer Amps Custom Stickers/Badges Paracord Grab Handles Painted Interior (all panels, headliner and carpet) Clazzio Leather Seat Covers with leather arm rests Ditch Lights 3 - 8" HieseLight Bars in bumper Rock Lights - Cali Raised LED Custom Fabricated Front Bumper - Blackout Fabrication Rock Sliders - DOSECC Fabrication Bushwacker Fender Flares (color matched) Morimoto LED Fog Lights
    Question! For glass bedsides, where are you all getting your fuel breather hoses? I know the 4runner filler hose works like magic, but I’m unsure what size/length/where to purchase the breather hoses
  20. Dec 16, 2018 at 3:51 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Thanks for the info. Any reason for running a 1.5" ID bearing vs a 30mm (1.181") ID bearing, like the stock bearing?
    Thanks for the offer. I'm currently running the IEDL poly Ford Ranger bearing, so I'm good for now.
