Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 8, 2019 at 9:04 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Self lubricating lol, and they are in there kinda tight
  2. Jan 8, 2019 at 9:10 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Speaking of XLT kits
    Who is running one still now that the Dutchman sold his rig?
    And if so
    Do you guys have any pictures when you were chopping off your shock towers to install the hoops?
  3. Jan 8, 2019 at 9:12 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    I see nothing has changed here... only forum in the world that 80% of the posts are about long travel squeaking.
  4. Jan 8, 2019 at 9:12 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Didn’t realize he sold although he had been back and forth about letting it go. Maybe I will get to see it down in southern az now.
    Dalandser likes this.
  5. Jan 8, 2019 at 9:24 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Are you moving down there?
    Coot83[QUOTED] likes this.
  6. Jan 8, 2019 at 9:25 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Solo has a green 2nd gen in their shop with it. Maybe they can show you what you want to see?
  7. Jan 8, 2019 at 9:33 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    Of all the ucas I've installed they were the easiest and perfect gap alignment for the shock towers, you're with lsk right? I always get people confused on here lol
  8. Jan 8, 2019 at 9:41 PM
    Anthony250
    Anthony
    Rialto CA
    Good to hear, I was not anymore.
  9. Jan 8, 2019 at 9:50 PM
    Cam2010taco
    Cam2010taco IG: Blvcktaco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Only the upper bags went off so I just cut em out bc it’s almost the same price for a cage to get them reinstalled, and for now I’ve done all the work myself!
    ya I was thinking it could be those too, I’ll do a good check on those! And thank you!
    I did actually check that and all of the mounting points seem to be fine and not rubbing so I think that should be good!
    I’m gonna check about the cab mounts sometime soon, how much is it to replace them cause I don’t got anything big enough to lift a cab haha!
  10. Jan 9, 2019 at 12:47 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    They do
    And I have asked a slurry of questions and taken a million pictures of that truck.
    But since I have the Baja shits shock tower on there from my +2 kit I have to cut more and I was hoping to find a picture of someone’s install when the shock hoops was ready to go on after all the cutting.
    Just trying to form a better mental picture before I cut into it
  11. Jan 9, 2019 at 12:49 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I know it’s redundant but humor me, take it completely off and take a drive around,
    Also check the blocks on your crush bar if you still have it, if those got wrapped or crushed they squeak
    Cam2010taco[QUOTED] likes this.
  12. Jan 9, 2019 at 12:50 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Who's that dude with the brown linked truck - I thought I remembered some pics of his hoops.
  13. Jan 9, 2019 at 12:57 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    No impact no idea... not sure I’ve seen it.
    I’ve talked to Irish sully as well, and Chris with the black truck
    Nobody happened to have pictures of what I was hoping for.
    I’m probably just being picky.
    Maybe I can just take a super nice picture of mine, print it out and take it to Bobby and have him make marks so I have a better idea/mental template
  14. Jan 9, 2019 at 5:29 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Once you loosen the bolts you can lift the cab with the OE jack, and support it with a 2x4
  15. Jan 9, 2019 at 5:55 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Are you talking about just cutting the coil bucket or all the other things that need to get moved or clearanced - are you using their shock hoops?
    Sett your main hoop for the longer shocks and bolt the coilover into your lower arm uncharged with a main spring on it and your shock tabs bolted to the top. The coilover will tell you where you need to cut when it's at full droop when you can slide the main spring all the way up to the spring retainer.
  16. Jan 9, 2019 at 6:04 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Im already in the southern AZ/phoenix area!
    Dalandser[QUOTED] likes this.
  17. Jan 9, 2019 at 6:19 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I got their shock hoops
    Figured their kit, their shock hoops.
    As far as clearancing the sheet metal I was just gonna put the UCA on and push it up to the top and chalk a like and cut there.
    Cause if the UCA clears the hoops will too.
    I just want to make sure that I cut all the right stuff at the right height for these new hoops so everything meshes well...
    Just being picky/ OCD
  18. Jan 9, 2019 at 6:43 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you want all the up travel you can get that's a good way to do it - you could bolt the rest of the kit on as well to make sure everything fits before you get too far into it and have to wait for parts or something.
  19. Jan 9, 2019 at 6:48 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nice - I took a ride out there two years ago in December. Nice place. Quite a few first gen guys out there too - @Speedytech7
  20. Jan 9, 2019 at 6:51 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Thats awesome man! Im looking forward to seeing the socal peeps hopefully somewhat soon. If you ever roll this way let me know!
