Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 11, 2019 at 4:56 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Dmz sells them, you just have to order them separately. You could call Tim and get them on order, but any axle perches should work.
  2. Feb 11, 2019 at 4:37 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Im running the total chaos SUA with the HD pack on my truck, I have a heavy camper. It sits perfectly unloaded, but when I load up with another couple hundred pounds in the bed it sags a couple inches. Is it possible to run an AAL with these springs? Is there a specific one I need?
  3. Feb 11, 2019 at 4:53 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Custom springs by dealer.
    Need to call them. Tell them your truck setup. Figure out how much rear axle weight you have and they will make it.
    excorcist[QUOTED] and tacomgee like this.
  4. Feb 11, 2019 at 4:55 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Deaver can make you a custom pack or maybe even make a AAL for your current pack
    excorcist[QUOTED] likes this.
  5. Feb 11, 2019 at 5:27 PM
    excorcist
    Reno, NV
    Yeah, was trying to avoid having to order a whole new spring pack as these are fairly new and Im assuming a custom pack would be around 1k$? Ill give them a call and see what they say about an AAL.
    Thanks!
  6. Feb 12, 2019 at 10:11 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    what rims should i get for the 4runner?
  7. Feb 12, 2019 at 10:13 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I like the second option with the thinner spokes, but thats just my taste. I thought you were saving up to fix the taco? $800 can go a long way man, not to C-block your idea.
  8. Feb 12, 2019 at 10:15 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    i know haha !!! i need to fix the damm truck
    Coot83[QUOTED] likes this.
  9. Feb 12, 2019 at 10:19 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Yep...atleast I would do that. I havnt dumped anything into my truck in a min, but first thing will be some gusseting reinforcement when I get some money built up.
    dillonk1602[QUOTED] likes this.
  10. Feb 12, 2019 at 11:40 AM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    NV all day
  11. Feb 13, 2019 at 7:23 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Well, maybe it was meant to be with the DMZ kit. Finally got around to mounting the hangars last night. When all four hangers were snugged up against the frame I had about a 1/2" difference between the front and rears. Fortunately I was able to space them off the frame a little to eliminate that gap. But it means that had I gone with the bolt on kit I would have had leaf springs that were slightly on a skew and probably went through a ton of bushings.
    Tango Bravo, taco_tallua and Coot83 like this.
  12. Feb 13, 2019 at 11:03 AM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Sounds familiar :thumbsup:
  13. Feb 13, 2019 at 1:07 PM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    Grumble grumble... haha
    Hawk373[QUOTED] likes this.
  14. Feb 13, 2019 at 6:05 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I know this isn’t necessarily LT but...anyone else see the FB post about Jerry f/ BAMF and @jberry813 winning the Pelfry assets auction for $130k with the intention of getting the merch to the people that were fkd by Pelfry !?
  15. Feb 13, 2019 at 7:10 PM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Yes, and they are both awsome guys, I have met,wheeled, camped ,and bought a few things from Jerry @BAMF, great guy makes great stuff.
    BEAR_KNIFE_FIGHT likes this.
  16. Feb 13, 2019 at 7:22 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Hadn't heard that, but it's cool of them. Now how many people will try to take advantage of/ abuse their good intentions.
  17. Feb 13, 2019 at 8:13 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Yeah some stand up mofos right there
    tyfoon11 and tacomgee like this.
  18. Feb 13, 2019 at 8:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Super bad ass.
    Be cool if Jerry also got the plans for everything and started making bumpers too
    tacomgee likes this.
  19. Feb 13, 2019 at 9:15 PM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    There way to hip for that read the fine print.
  20. Feb 13, 2019 at 11:49 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Daaanngggg.
    Jason and Jerry are the guys! I’ve done business with both and they have been nothing but truthful and honest, and aside from being good business men, seem like good fellas.
    Speedo likes this.
