Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 25, 2019 at 5:16 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Pretty good list, maybe just gusseted spindles. Points where limit straps attach to the frame. (Kartek or trailgear).
    And bumps stops.
    Honestly up front I spent more time with bracing and gussets than my LT kit.
    Spindle gussets
    Shock tower gussets
    Motor mount gussets
    Shock tower bracing(engine hoop)
    Cam tabs (are a must)
    That’s all I can think of right meow.
    I spent a lot of time on the truck welding all that shit in and you will never see it.
    People just see the kit.
  2. Apr 25, 2019 at 5:33 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    My Total Chaos kit turns 10 this year and trust me, I beat the crap out of it and don’t have issues. Yes, there is maintenance but that’s what will keep it going another 10 years. Do it once, tune it two or three times and enjoy the f out of it!
  3. Apr 25, 2019 at 6:59 AM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    That's a lot of work for "safety third" :rofl:
    Radarninja[QUOTED] likes this.
  4. Apr 25, 2019 at 10:34 AM
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
    For the guys that are running a fuel cell, what did you do with the line that runs from the Purge VSV (connects to intake and pulls fumes to burn from charcoal canister)? Did your truck run different without it? Is it worth building into new set up?
  5. Apr 25, 2019 at 11:06 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Arms can't be swapped. LCA bolts are different sizes. Fronts are bigger than the rear.
  6. Apr 25, 2019 at 1:13 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    If you move the sh
    no and no, your 8”CO’s will not work with a TC +2 kit you’ll have to go to a 3.5 kit
    Arcticelf likes this.
  7. Apr 25, 2019 at 1:18 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Tc +2 and +3.5 kits spec the same shocks
  8. Apr 25, 2019 at 1:22 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    8" COs don't work with TC +2?
  9. Apr 25, 2019 at 1:34 PM
    Y2kbaja
    Sacramento
    Total Chaos
    said the guy that does installs.
    Coot83 likes this.
  10. Apr 25, 2019 at 2:08 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    My Baja Kits +2 uses 8" COs
  11. Apr 25, 2019 at 3:36 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    8" works with the AllPro +2 Kit, the latest version. But not with the original +2 version.
  12. Apr 25, 2019 at 3:51 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Exactly, was cool to find this out from TC themselves that they designed their kits with this in mind in the event folks wanted to swap kits. The LCA has the difference developed to accomodate this.
  13. Apr 25, 2019 at 4:13 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    You guys can run whatever 8” coilovers you want if you place your own shock tabs.
    anomalyTRD likes this.
  14. Apr 25, 2019 at 4:39 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Nobody will want to cut correctly placed tabs and move them for this , nor do most know where to set them. Most kits dont come bare without tabs too. Just sayin
    MonkeyProof likes this.
  15. Apr 25, 2019 at 4:55 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    While this is true, most people trying to do this to save a few hundred dollars will spend a bunch of time trying to sort it out and will get mixed results. The one thing hopefully people are starting to see is, if you cut corners or try to save a few hundred dollars by using stuff that isn’t properly spec’d or was made by a sub par company you pay far more in your time investment and/or money spent fixing or paying people to fix the mess it has created.
  16. Apr 25, 2019 at 5:22 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Why couldnt you? With everything i measured you could, but youd lose travel in the droop unless you switched to a longer rod end.
    I had 25.5 inches at droop before bind and 19.75 inches at bump. Those were the numbers for shock travel.
  17. Apr 25, 2019 at 6:56 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Same shock spec as Jason said.
  18. Apr 25, 2019 at 7:01 PM
    MonkeyProof
    SoCal- SGV
    The design of the lower arms between the two versions are totally different. Version 1 stroke length is 7-5/8". You could take the extra spacer out and strap it no problem.
  19. Apr 25, 2019 at 7:56 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    J, let’s be very specific here - the TC spec’d CO for both kits is a standard 8” CO ? and the same configuration that he already has on his truck now ?
    I had this conversation with TC myself, sent them pics of my 8’s and was told it would not work with their +2 kit by TC.
  20. Apr 25, 2019 at 8:06 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    So your saying Solo is a sub par company ? I have the exact same kit as the person stirring this pot and I have none of the same problems...so is it Solo...or the end user ? I’m going to repeat what I said earlier - he bought a used kit with missing pieces, mixed in different brand bits, bought the wrong spec’d CO for a 4x4 and is not using the correct cv boots...how is that the kits fault ? seriously what am I missing here ?
