Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 14, 2019 at 12:05 AM
    Spvrtan
    Spvrtan "Your assembly required."
    Kris
    San Diego (North County)
    SC'd '14 Tundra; 5.5" lift w/ +2.5 LT; 40s on 17s; 4.88s
    I didn't get to work on my Camburg LT install as much as I wanted this weekend and when I did find time I ran into stupid non-LT kit problems but here's the current status..
    Radarninja, Bot_Chu and Dalandser like this.
  2. May 14, 2019 at 12:09 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How much extra did they charge for the custom blue wrap?
    Also this is a sweet bed setup - me gusta
  3. May 14, 2019 at 10:20 AM
    Cam2010taco
    Cam2010taco IG: Blvcktaco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Solo said they got my truck aligned at a shop but man I can’t help but feel like I shouldn’t have positive camber... especially on the passenger side
    LukeCC likes this.
  4. May 14, 2019 at 1:31 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Why don’t you ask them for the print out the shop gave them?
    Caboose117 likes this.
  5. May 14, 2019 at 4:34 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Doesn’t look too bad, sometimes uneven ground will do that but you also have a ton of adjustment left in those cams to move that LCA out so I wouldn’t sweat it
  6. May 14, 2019 at 4:41 PM
    2002 tacoma s/c LT
    2002 tacoma s/c LT Well-Known Member
    Travis
    Carson ,CA
    2003 4DR 4WD Taco
    Someone else's build with my touch
    I was against buying a used off road truck but the situation I was put in didn't really help. I was just extremely lucky that my truck now was up for sale and followed it from the beginning of the build pretty much.cost me a lot less than it would have been to redo my last build that I got screwed on from fab work. But I came out on top I'd say:rofl:
  7. May 14, 2019 at 4:50 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Not gonna lie, an LT first gen has been a dream of mine from the moment I saw your cement monster in this thread.
  8. May 14, 2019 at 4:52 PM
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Bad ass truck
    And that thing never even saw dirt..... Right Mac ? :poking:
  9. May 14, 2019 at 5:25 PM
    2002 tacoma s/c LT
    Travis
    Carson ,CA
    2003 4DR 4WD Taco
    Correct sir. Next season it'll be used since it'll be where I wanted it
    Lol thanks man
  10. May 15, 2019 at 5:30 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Did you back it into that spot? Sometimes that will pull the camber in.
  11. May 15, 2019 at 6:17 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Very little about this place is practical :)
  12. May 15, 2019 at 6:44 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Anyone running 14” coilovers, short course style in the rear? Trying to get a baseline for spring rates
  13. May 15, 2019 at 7:47 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I’d get a firestone lifetime alignment, it’s like maybe $150 and you can go back to any firestone and get alignment everyday if you wanted for $0.00 as long as you have the truck.
    I’ve like the one off of el toro and the 5. They’ve have no problem aligning my truck and also seen other LT trucks there too.
    sicki and jamesepoop like this.
  14. May 15, 2019 at 7:50 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Negative, the fine print says every 6 months or 6,000 miles
    whatstcp, Gunshot-6A and Bentrodder like this.
  15. May 15, 2019 at 7:53 AM
    Sterling_vH111
    Sterling
    socal
    Huh. I explicitly asked a manager, and have had no problem for two years.
    I went in to the same one on a Friday, bashed in ocotillo wells all weekend, and then went back Monday. Didn’t even clean the dust off the truck, and they had no problem doing it.
    Guess it may depend on the firestone
  16. May 15, 2019 at 7:54 AM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Yeah you might have got a cool place
  17. May 15, 2019 at 7:58 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I've never had an issue at multiple Firestones. If they will take a modified truck, they are already bending the "rules" and every place I talk to knows my truck will hit the trails and come back the next week.
  18. May 15, 2019 at 8:00 AM
    desertjunkie760
    Shane
    Check My Sig.
    What are you all doing as a safety device when you relocate your battery? I was thinking of finding a circuit breaker or switch that will serve the purpose if a short occurs. Most breakers I see will run a 150-175 constant draw but a winch will draw 400ish AMPs under max load.
  19. May 15, 2019 at 8:10 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I use a blue sea switch for my winch. No issues.
    Arcticelf likes this.
  20. May 15, 2019 at 8:15 AM
    desertjunkie760
    Shane
    Check My Sig.
