Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 3, 2019 at 11:11 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I can def see that. I got some LCA gussets I still need to install from dirt designs that are braced around my cam tabs. I like the gusseting design of this though to where I wouldnt mind developing something homemade to achieve similar.
  2. Jun 3, 2019 at 12:07 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    I remember talking to a couple of guys that said quite quickly with heavy romping off-road those LCA ears start to tear from the frame so these seem super intelligent design and upgrade imo
  3. Jun 3, 2019 at 12:12 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I got the idea for the need from the infamous tan first gen with his gusseted LCA cam tabs and figured that would be needed for the long haul at some point.
    Caboose117[QUOTED] likes this.
  4. Jun 3, 2019 at 12:19 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I got my idea after smashing the front lca tab.
    Bobby18 and Caboose117 like this.
  5. Jun 3, 2019 at 12:20 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I dont think the Marlin crawler will fit with other tab kits so if you factory tabs a bent you either need to bend them back or go with another option. See in the image below how the Marlin kit wraps around the factory tabs
    Tango Bravo, whatstcp and Coot83 like this.
  6. Jun 3, 2019 at 12:33 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    What if I already have aftermarket Cam Tab Gussets?
    If you already have aftermarket 1/4" thick cam tab gussets installed, then simply shave 1/8" off our Uprights and install to your frame like normal.
    Bobby18 and whatstcp like this.
  7. Jun 3, 2019 at 12:53 PM
    zscott
    Zach
    Utah
    Sure you can grind or cut just about anything to make it fit. They definitely didn't design it to accommodate pre-installed gussets though. Per Marlin Crawler:
    "That's it! No grinding required. No jack stands required. No suspension disassembly required. Just weld-on and go!"
  8. Jun 3, 2019 at 1:26 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Both of our quotes came from the same person.
    The point is
    If you have factory
    Or modified cam tabs
    This kit can still be useful and beneficial to anyone procifient enough to use a grinder and a welder
  9. Jun 3, 2019 at 1:39 PM
    jAndyMendo
    jAndyMendo i eat samiches
    Andy
    San Diego, CA
    2014 TRD 4x4 OR 2016 4Runner fake-TRAIL Edition
    who here has damaged anything other than the the tabs? why do we need such a crazy kit.
    If you have the current gussets just run with them, why add this contraption to them? if you dont, now you have options.
    we keep adding weight to our trucks that then requires adding more weight to support that weight that will in turn require more weight to support that and next thing you know you will be chopping your truck in half and sitting it in a shop for two years trying to put a dana80 in the back :anonymous:
    tacomgee, Gply, DannyBFresco and 6 others like this.
  10. Jun 3, 2019 at 1:43 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I know of some guys who have cracks down in the LCA areas before they did some additional gusseting. Takes the right kind of wheeling for these to take place, but with the recommended gussets...whats another 5-10 pounds in metal?
  11. Jun 3, 2019 at 1:44 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I mean... all of the cool kids are doing it... :burp::gossip:
    LukeCC and jAndyMendo[QUOTED] like this.
  12. Jun 3, 2019 at 1:45 PM
    Y2kbaja
    Sacramento
    Total Chaos
    With 3 in my family off roading we carry more in make-up, underwear and snack than the weight of these gussets will add. Well worth the protection. I've smacked that front lower tab directly before and have added a gusset to that area. I'll be cutting those off and going with this laser cut 1/4" gusset.
    Bobby18 likes this.
  13. Jun 3, 2019 at 1:51 PM
    zscott
    Zach
    Utah
    I got a crack in one of mine and I know I don't push my truck as hard as some. I now have reinforcements from dirt designs that support the LCA mounts. Not the same as the Marlin kit but similar idea.
    Coot83[QUOTED] likes this.
  14. Jun 3, 2019 at 1:51 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I think that @MonkeyProof or @tetten both can show you why you may want this. Think they both used the dirt design gussets.
    MonkeyProof likes this.
  15. Jun 3, 2019 at 1:53 PM
    desertjunkie760
    Shane
    Check My Sig.
    Do you have any additional details on the Dirt Designs kit?
  16. Jun 3, 2019 at 1:55 PM
    zscott
    Zach
    Utah
    Its funny I saw Dirt Designs post in the Marlin thread they other day. Looks like a lot of Marlins patented stuff (LCA brace and RCHDLT kit) are heavily based on stuff dirt designs gussets and LT kit.
  17. Jun 3, 2019 at 1:55 PM
    zscott
    Zach
    Utah
    I will take some pictures tonight.
    Edit:
    Here is a pic from his thread where you can kind of see what it does. His just supports the LCA mounts, not the tabs. It connects the top edge of the mount back to the frame:
  18. Jun 3, 2019 at 2:01 PM
    desertjunkie760
    Shane
    Check My Sig.
    Thanks,
    Being someone who already has the TC gussets, the Dirt Designs kit seems to make more sense. Can't seem to find their website though.
  19. Jun 3, 2019 at 2:08 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I had to PM them about it as they dont always have them around. I dont know if they have a jig to replicate the kit now, but they had to wait for a tacoma to be worked on before they could shape mine gussets.
  20. Jun 3, 2019 at 2:12 PM
    desertjunkie760
    Shane
    Check My Sig.
    Sounds like something I can do with a plasma cutter, some cardboard, a 12 pack of silver bullets, and a jar of KY. :anonymous::jellydance:
