Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 13, 2019 at 5:39 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Those of you, if I’m not certain all of you, running bypasses, how much of a chore or pain is it to adjust your tubes? ADS bypasses here with bout 3k miles on them. About 2k ago I adjusted my 2nd compression tube by loosening the 9/16” nylock nut, loosened the 1/4” stud, and then retightened the lock nut. Now, 2k miles later I’ve added a bumper and want to close the tubes a little for the weight, they are unbelievably tight. After cutting more wheel liner I muscled the rebound tube tighter about 3 turns. When I went to do the compression they wouldn’t budge. I tried with the truck jacked up and on the ground to no avail. The 9/16” lock nut was tight as well I stopped when one began to round. Is it supposed to be this much trouble?
  2. Jun 13, 2019 at 6:31 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Jacked up or not shouldn’t matter. Make sure the lock nut is very loose. Use a 6 point socket or wrench to minimize the chance of rounding. With the lock nut loose, the “stud” should move quite easily.
    Dalandser and Supra4x4[QUOTED] like this.
  3. Jun 14, 2019 at 12:06 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Want to get some powerful, but small-ish lights. Been looking at the KC flex - already have 2 baja design squadron sports for fogs, a couple knock off pods and a 20" KC dual row but I may not use the 20" since it's bigger than a lot of newer lights w/ the same or better output. Don't want to spend $400, just depends on the light I guess.
  4. Jun 14, 2019 at 12:17 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
  5. Jun 14, 2019 at 12:18 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Any goals you want the lights to achieve? Like flood, spot, distance, driving? I wonder if rigid would have something although I mainly run baja stuff.
    Dalandser[QUOTED] likes this.
  6. Jun 14, 2019 at 12:42 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    So I have the squadron sports in amber / flood down where fog lights would be normally, so basically illuminating far head and sides of the trail.
  7. Jun 14, 2019 at 12:44 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ha thats funny man I got the LP6 Pros in the spot config for that exact purpose although I know those are a little out of your budget. I think Rigid makes some side shooter ones that could work well for your application...I think they even come in white.
  8. Jun 14, 2019 at 12:47 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I actually have those extra cubes I can point to the side so I guess yeah just distance. I also want small lights I can mount in / behind my grill since theft is not unlikely where I live - even still I plan on at least using torx bolts for attaching the light to the bracket and tack welding the bolts that mount the bracket to the truck. I'm also into the style that I see on the big luxo builds where all the lights are smoothly fit into the bumper and grill. Just being 100 haha
  9. Jun 14, 2019 at 2:34 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Have you looked at the KC Garage Sale thread? They have 1st gen dual light, spot pattern FLEXs for $90, so $180 for a pair. They're about halfway down the first post.
    Post 76 is where they were added to the garage sale, and @Taylor@KC HiLiTES mentioned that they'd do a 20% discount on the wiring harness if you ordered a pair of them. Deals on ditch light brackets was also mentioned if you order everything together.
  10. Jun 14, 2019 at 2:35 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol guess what page I was viewing just now. Looking at the flex lights - I think that's all I'll need either in 10" or dual pods.
  11. Jun 14, 2019 at 2:36 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    And here I am struggling to fill half a 44" HF box.
  12. Jun 14, 2019 at 2:38 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My tools have about 6 HF tool bags that they live in since my truck is in my neighbor's driveway and there's no garage to store tools in lol
  13. Jun 14, 2019 at 2:41 PM
    Gunshot-6A
    Conner
    Everett, WA
    Well, I just got the keys to this Wednesday, so I feel your struggle. #apartmentfab is tricky
  14. Jun 14, 2019 at 2:45 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Amazing house brother - friggen gorgeous. Looks like you found a winner. Awesome, so many trees.
    Gunshot-6A[QUOTED] likes this.
  15. Jun 14, 2019 at 5:53 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    What are you guys using to extend the fuel filler necks with glass bedsides?
  16. Jun 14, 2019 at 6:32 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That's on 2nd / 3rd gens. Nice clean fix for sure. I think the last guy before @MESO was asking about a 1st gen w/ 7-8" bedsides though.
    @RedManRocket I worked on my neighbor's Chevy the other day replacing the fuel pump and this is what I think should work on ours if we cut the filler neck in half somewhere that makes sense to.
    jeff b[QUOTED] likes this.
  17. Jun 14, 2019 at 6:34 PM
    MESO
    State of Jefferson
    Perfect thanks
  18. Jun 14, 2019 at 7:19 PM
    Gunshot-6A
    Conner
    Everett, WA
    Thanks man. I caught the market sleeping and somehow scored a winner.
    Back yard is equally baller, and has a 2 car garage with a 3 car driveway. Plenty of room for new projects
  19. Jun 14, 2019 at 11:05 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    By using the 4 runner hose? What's the picture of exactly
  20. Jun 15, 2019 at 12:33 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just some fuel hose going from the fill door to the gas tank held on with hose clamps in a Suburban. If it works for GM in an 03 it works for me lol. Napa should have all the sizes you'd possibly need to fit around the neck and evap if there's one.
