Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 24, 2019 at 12:20 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    play is between the shackle and the white slide plate
  2. Jun 24, 2019 at 12:24 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I'd say your hunch is likely pretty good...
    But whats in the gusseted joint between frame and shackle?
  3. Jun 24, 2019 at 12:44 PM
    Y2kbaja
    Sacramento
    Total Chaos
    Anyone know where to get delrin or similar leaf spring bushings? My truck had them on originally and they just wore out. Maybe the Poly are flexing too much.
    Speedo likes this.
  4. Jun 24, 2019 at 1:21 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Kartec has a good selection, but you might have to get them custom made.
  5. Jun 24, 2019 at 1:28 PM
    Y2kbaja
    Sacramento
    Total Chaos
    Thank you. The leaf spring bushings are standard size, I'm sure something in there will work. I'm going to replace both upper and lower shackle bushings with these Delrin to see if it helps. In addition to the slide plate.
  6. Jun 24, 2019 at 7:06 PM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    Do you swap your bedsides depending on the activity?
    LukeCC likes this.
  7. Jun 24, 2019 at 7:46 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Haha yes sometimes.
    I swap to my stock bedsides if it is potentially going to be a tougher rock crawling trail. Other than that I’ll leave the glass on. They’re on now since the truck went back together within a few weeks of me heading to the rubicon next month.
    Tango Bravo[QUOTED] likes this.
  8. Jun 24, 2019 at 9:08 PM
    Gatordawg
    Gatordawg Well-Known Member
    Devin
    Santa Cruz
    Hey, if anyone happens to know the best place for getting a good price on total chaos parts let a dawg know thanks!
  9. Jun 24, 2019 at 9:52 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    @glorifiedwelder
    whatstcp, LukeCC and Tyler07 like this.
  10. Jun 25, 2019 at 5:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    SDHQ won't have in state tax too.
    Tango Bravo and LukeCC like this.
  11. Jun 25, 2019 at 11:38 AM
    Tango Bravo
    Thomas
    SoCal
    Well I guess after the first few times, you would have it down to a science. Or you just leave half the bolts out haha. Such a pain in the ass the first time you do it...
  12. Jun 25, 2019 at 11:59 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    new rims!
    snowsk8air2 likes this.
  13. Jun 25, 2019 at 12:00 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah I can swap them in 15-20min. And this last time I made some tail light mounts and trimmed both sets of bedsides so I don’t even have to pull the tail lights now to swap them.
  14. Jun 25, 2019 at 12:26 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    What is your trick for getting to the bolts at the front right behind the cab. Those take me forever to get (at least the top two) because I can't fit my hands in there, and I dont have big hands at all.
  15. Jun 25, 2019 at 12:34 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Who has done cutting brakes on the rear? Need to do a line lock since I'm loosing the e brake and figured since i have to run brake lines it wouldn't be that much more work to put a set of cutting brakes behind the line lock. Would be using in a low speed aspect with a selectable rear locker. Sounds like it'll help with turning if i lock the inside rear wheel with the rear unlocked to kind of drag around corners and help with turning or am i missing something.
  16. Jun 25, 2019 at 12:35 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    cute van :anonymous:
  17. Jun 25, 2019 at 12:44 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Don’t use them lol. I have a bracket going to the two bolts on the inside of the fender well that goes down to the lower front outside corner of the bedside. I don’t have any of the bolts that were on the front of the bedside between the bed and cab
    Tango Bravo likes this.
  18. Jun 25, 2019 at 1:58 PM
    zscott
    Zach
    Utah
    I wondered if thats what you were doing. I will probably switch to that soon. Not that I take my bedsides off much but those bolts are a pain to get to.
  19. Jun 25, 2019 at 2:01 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah mine come off and on with the bed rail bolts and the 4 inside the wheel wells now.
  20. Jun 25, 2019 at 9:08 PM
    erok81
    erok81 Well-Known Member
    Imposter
    I wish someone would make something like this. I’d love to ditch my number for a tube like bumper. More so high clearance too. Looks good.
    Tango Bravo and Sterling_vH111 like this.
