Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 25, 2019 at 9:36 PM
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
  2. Jun 25, 2019 at 9:49 PM
    Gatordawg
    Gatordawg Well-Known Member
    Devin
    Santa Cruz
    I hit that dude up but he couldn’t give me a straight answer about anything
  3. Jun 26, 2019 at 8:16 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Cutting brakes no but I did a handbrake...works great for tight turns when ur goin too fast. Any brake u put in just plumb it past the porportioning valve
    malburg114[QUOTED] likes this.
  4. Jun 26, 2019 at 9:49 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Truck is a little long and front heavy for cutting brakes to work well.
    A rip stick just to rotate would work better imo.
  5. Jun 26, 2019 at 1:32 PM
    Basikbiker
    Trav
    And indeed she will rotate full 180 in the width of a fire road no problemo lol
  6. Jun 26, 2019 at 1:37 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I can get you TW member pricing on Tc parts as well as other brands
    Dalandser and whatstcp like this.
  7. Jun 26, 2019 at 2:05 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I believe a demonstration is in order
  8. Jun 26, 2019 at 2:06 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Do you have a writeup on the install in your build? I have been looking for info on handbrake setups.
  9. Jun 26, 2019 at 3:18 PM
    Basikbiker
    Trav
    No I dont it's pretty simple tho one line from after your porportioning valve goes to the inlet of the handbrake then the outlet ties back to your axle...that's it
    Bandido likes this.
  10. Jun 26, 2019 at 3:30 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Put in a two handle cutting break. Then you can lock one or both wheels. My buddy did it for snow wheeling in his taco to aid in wheel spin
  11. Jun 26, 2019 at 3:39 PM
    Basikbiker
    Trav
    Just buy one and plumb it in...its not hard to do at all
    jeff b[QUOTED] likes this.
  12. Jun 26, 2019 at 3:55 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    So from the master go proportioning valve, line lock, then cutting/hand brake and back to the rear axle?
    Rip stick meaning a hand brake? I can't do front digs (Front wheel drive only) so not sure locking the rear would let me pull the front around. Think it would just put a ton of stress on the rear 3rd and shafts no?
    Link to said 2 handle? Kind of what i was thinking. Lock the inside rear tire to turn sharper since it'll drag around.
    Essentially what I'm trying to do is lock the inside rear tire to help me turn tighter since the truck is so long. I know its not high speed lt stuff but figured you guys were the ones to use them if anyone on this forum lol. Thanks for the help. Keep the info coming.
  13. Jun 26, 2019 at 4:40 PM
    Gatordawg
    Devin
    Santa Cruz
    Right on thanks, I ended up going through Yotamasters and got a nice discount and free shipping
  14. Jun 26, 2019 at 4:43 PM
    Basikbiker
    Trav
    coorect...and yea 2 handle cutting brake...look on kartek they sell like all sorts of versions
  15. Jun 26, 2019 at 6:33 PM
    malburg114
    Las Vegas, NV
  16. Jun 26, 2019 at 8:56 PM
    Basikbiker
    Trav
  17. Jun 27, 2019 at 4:54 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Now that I see you are SAS'd, I'm not really sure a cutting brake or a hydraulic E brake (rip stik) are suitible for your application... I had assumed you were in a pre-runner...
    Cutting brakes are mostly for rear engined buggies and the like to compensate for understeer.
    A hydraulic E-brake is what is used in most ice racing, rally, and drift applications to lock the rear end and initiate over-steer, this can move the center of rotation within the vehicle.
    Looking at your build, you might actually want to consider rear-steer if you need more low speed maneuverability.
    If you are trying to replicate A-trac however...
    Gunshot-6A likes this.
  18. Jun 27, 2019 at 5:59 AM
    malburg114
    Las Vegas, NV
    Sweet thanks. Already have a selectable locker.
  19. Jun 27, 2019 at 6:05 AM
    malburg114
    Las Vegas, NV
    Just posted in figuring more people in here had them then elsewhere on the forum.
    I understand how they work and the benefits and that there won’t be a lot of weight over the rear but thinking with the tire grabbing and most likely hooking on a rock or something else I may benefit from the added pressure and help with tighter steering in more technical applications.
    Lol still a full bodied rig. This rig and probably none of my future builds will see rear steer. It’s not that I need the extra mobility. It would just be nice sometimes to not make 5 point turns were others make 1 or 2 lol.
    This was just something I was considering since I’m already running brake lines into the cab and thought it may be a worthwhile investment. I’ll do some more looking and see what the crawler people say.
    Not trying to replicate a-trac. That’s why lockers were made lol
    Bandido[QUOTED] likes this.
  20. Jun 27, 2019 at 7:01 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I think the style of lever you linked will be perfect for what you’re trying to do. Be cleaner than a twin stick as well unless you saw the need to be able to lock up both rears and attempt a front dig.
