Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 3, 2019 at 5:57 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Sitting at the brewery waiting for my ride. Figured I’d share. Been collecting parts for this for awhile now. Very excited. :yay:
  2. Jul 3, 2019 at 6:45 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    What’s going down?
  3. Jul 3, 2019 at 7:28 PM
    desertjunkie760
    Shane
    Check My Sig.
    New valving, adding adjusters, re-did the finish on the shock body. A few other small details that I’m hoping add big changes to the ride quality.
    Coot83[QUOTED] likes this.
  4. Jul 4, 2019 at 6:55 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Hey nice brake light:D
  5. Jul 4, 2019 at 8:18 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Love that thing. One of my favorite additions. Finally have a cargo light for the bed
  6. Jul 4, 2019 at 2:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Pro tip on the Raptor liner.
    If you mix in paint thinner to thin it out and use a real paint gun, you can make it look more like paint and not bed liner. AKA not a textured.
    This is my plan. The main reason is the texture captures dust more so it pretty much impossible to keep clean I've read.
    If you thin it out though it'll spray like paint. Might take a bit more time to get a good layer sprayed but should work nice.
    Tango Bravo likes this.
  7. Jul 4, 2019 at 4:23 PM
    Cam2010taco
    Cam2010taco IG: Blvcktaco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
  8. Jul 4, 2019 at 4:38 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Time for some bigger tires
  9. Jul 4, 2019 at 5:12 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I think it would just look like a really bad orange peel paint job without the texture ?
    Bobby18 likes this.
  10. Jul 4, 2019 at 5:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not sure I haven't tested it yet. But I bet if done right you could eliminate most of the texture. Because if it's thin enough you can spray it at a high psi which would give it more of a mist and the air pressure and nozzle has a bigger effect on the texture than anything.
  11. Jul 4, 2019 at 5:33 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Nice work! Very clean.
    Cam2010taco[QUOTED] likes this.
  12. Jul 4, 2019 at 5:50 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’m planning on tinting my raptor liner the color of the earth so I can be looking good at work even if I rolled up right after an off-road trip - still it’ll be second favorite choice to a mellow blue but I guess I’ll see what you guys do since I’m sure I’ll be doing my truck later in a year or two.
  13. Jul 4, 2019 at 7:37 PM
    zscott
    Zach
    Utah
    I like the textured look as long as it is a fine texture and not big goopy globs like some. I am fully expecting the cleaning issue though.
  14. Jul 5, 2019 at 1:00 AM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Hey hey hey woah woah don’t let my girlfriend hear :eek:
    snowsk8air2[QUOTED] likes this.
  15. Jul 5, 2019 at 1:15 AM
    alexplb
    alexplb Well-Known Member
    Just wanted to share this little project That I’m working with shop on. E1457B9A-C50D-4C29-93DE-0C5A16486E6C.jpg
    3pooches, anomalyTRD, Jrgymie and 2 others like this.
  16. Jul 5, 2019 at 6:08 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    All that good stuff and you’re keeping the sway bar?o_O
    Pull that off now while you’re in there and throw it in the trash. You won’t regret it
  17. Jul 5, 2019 at 6:20 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    X2
    I couldn’t tell any difference when I had a +2 kit on my 08.
    snowsk8air2 likes this.
  18. Jul 5, 2019 at 7:48 AM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    For me that is somewhat a concern. I have line-x on my bedsides and quarter panels. The dealer sprayed color matched paint over the line-x when I had it done years ago. I thought they were using a tintable line-x that they were mixing the color match into. Thus, the texture isnt as 'deep' as it normally would be. From a dirt stand point, I honestly just hose it off and it comes clean. I hope raptor liner on the rest of the truck will perform the same way.
    I was reading that when using the shultz gun, if you increase the gun pressure to 60psi and then spray closer you will get a finer texture. I think this makes sense since the raptor liner has less time to 'airate' before it gets to its final surface. I may just buy a 1L kit of raptor and then spray some test piece at different pressures/ distances and see what I like before I go ballz deep into turning the truck into that Toyota Cement color.
    Dalandser likes this.
  19. Jul 5, 2019 at 7:57 AM
    concentric_killa
    I went down the raptor liner hole the other day. I think I have settled on getting the Toyota Cement Toner (1H5) mixed as my new color. It is slightly cheaper than the $20/ 3oz bottles of toner on Amazon. I plan on buying 12 bottles of raptor and harder from amazon and then 3 pints of toner at $75 ea. It still will be significantly cheaper than getting the rest of the truck done in more line-x.
    Ill probably do this in august depending on work schedule and my basement project.
    Dalandser[QUOTED] likes this.
  20. Jul 5, 2019 at 8:08 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Soo tundra rack mod stuff...almost gunna install it into my truck....
    And for anyone wanting to upgrade thier steering, once I got mine in and tested I think I'm gunna offer like mod services to do this to a rack.
    Like you buy a tundra rack, disassemble it(really easy to do) send me the rack and pinion gears and I'll machine em for you then send em back, or I overhaul some racks,mod em and sell em to you guys...yes itll be cheaper than solos or Marlins when it comes out...thinking like 4-500 to do the machining and around 900-1000 for a assembled rebuilt rack...
    Still just a thought...wanna see if there's interest?
    In addition my dad and I will be making a youtube video documenting dissassembly,reassembly and of course the mod
    What u dudes think?
