Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 2, 2019 at 11:01 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Yea I just shrug...and go "probs be fine" and keep smashin lol
  2. Aug 2, 2019 at 11:07 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    A wise man once told me: Race trucks make race noises!
    Then promptly put a coilover, shock mount, and resi through the hood when the welds gave way. #TooPinned
  3. Aug 2, 2019 at 12:17 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    A different style of data point for how bad they are is I just did almost 2k miles in my truck, which is also caged, with my fiancé and she didn’t call off the wedding. The noise means everything is working how it should.
    Coot83, anomalyTRD, Dalandser and 3 others like this.
  4. Aug 2, 2019 at 12:59 PM
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
  5. Aug 2, 2019 at 1:22 PM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    THATS what that noise is?!!! I just thought it was my shackles and leaf pack getting bucked around.
    Meh. Either way wasnt gonna worry bout it.
  6. Aug 2, 2019 at 1:43 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    LOL....So did I. thats why I just turn the tunes up all the time.
  7. Aug 2, 2019 at 1:59 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    What setup do you use for nitrogen charge?
  8. Aug 2, 2019 at 2:07 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
  9. Aug 2, 2019 at 2:13 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I personally don’t have a setup. Working on it though.
    But the better quality the regulator, the more accurate your fills will be. Then it’s up to you to use a no loss chuck or not. Again, with one you will be more precise. But your average Joe, myself included, isn’t going to be able to tell the difference between a shock filled to 190 when they wanted 200.
    Rakso[QUOTED] likes this.
  10. Aug 2, 2019 at 2:16 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Get Fox's, they don't click. Kings are loud!
  11. Aug 2, 2019 at 2:17 PM
    jjhitchen
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
  12. Aug 2, 2019 at 2:17 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
  13. Aug 2, 2019 at 2:19 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
  14. Aug 2, 2019 at 2:22 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Cool I guess I only need the hose and regulator.
  15. Aug 2, 2019 at 2:28 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    If a place is willing to fill your C02 with nitrogen then the answer is yes....provided you have a hose and regulator
  16. Aug 2, 2019 at 2:38 PM
    Y2kbaja
    Sacramento
    Total Chaos
    I sourced all my cheap stuff from Amazon: hose, regulator and chuck. The pressure drop is so minimal if you release the chuck right. I went to the local airgas company and bought (rented?) a small tank. When it's empty I'll get the next size up. I've done a couple dozen or more shocks and still have more than half a bottle.
  17. Aug 2, 2019 at 3:53 PM
    Canks
    Canks Well-Known Member
    San Diego
    08 DCSB in pieces; 04 Tundra Access cab also in pieces
    Unfortunately this is not true. CGA (Compressed Gas Association) has setup very specific rules to keep dummies like us safe. Your CO2 cylinder will have CGA320 valve where as your Nitrogen cylinder will have CGA580. Valves are specified by gas type so that we do not blow ourselves up. there are lots of stories of people in the gas world blowing themselves up.
    A C02 cylinder will require a specific regulator for a CGA 320 that is different than a Nitrogen valve that has a CGA580.
    CGA320
    [​IMG] https://www.google.com/url?sa=i&sou...aw3Ksey9qm1VrDm_MGCNVE1O&ust=1564872589658516
    CGA580
    [​IMG] https://www.google.com/url?sa=i&sou...aw0PDDDwiWytlg2vTrO7o5xW&ust=1564872616276389
    Furthermore a fill location (Airgas) will not fill Nitrogen in to a C02, or vice versa. Governing bodies (like the DOT) will fine them upwards of $10k for such an offense.
  18. Aug 2, 2019 at 3:56 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Good info thanks.
  19. Aug 2, 2019 at 3:56 PM
    Canks
    San Diego
    I should add: In most cases (I stress most) the cylinder itself between the two types of gas is the same. A cylinder is a cylinder and they are all made out of steel (or aluminum, or composite etc. whatever).... If you want nitrogen and you have a co2 cylinder it is as simple as changing the valve.... Unfortunately most Airgases or similar will most likely want you to swap tanks with them and charge you for it
  20. Aug 2, 2019 at 4:12 PM
    Basikbiker
    Trav
    Uhhh I use the argon off my welder...with a nitrogen regulator.....:anonymous:
    tyfoon11, Arcticelf, Speedo and 4 others like this.
