Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 5, 2019 at 12:52 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I can only get one small zip tie in and it's not resolving my complaint. Thinking about throwing some tack welds on the rives to see if I can minimize the play.
  2. Aug 5, 2019 at 12:57 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    What’s the issue you are having? If I remember correctly the symptom that the zip tie fix is for is excess play in that joint. I would hit a bump slightly not square on and you could hear a loud bang as that joint slammed from one side to the other
  3. Aug 5, 2019 at 1:03 PM
    desertjunkie760
    Shane
    Check My Sig.
    That’s it. It’s a nuisance more than anything but I do feel like it’s progressively getting worst so I keep thinking I’m going to loose steering at some point.
  4. Aug 5, 2019 at 1:05 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    just expensive, front sump oil pan is close to 500$
  5. Aug 5, 2019 at 1:08 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have many zip ties in my steering joint lol
    Dalandser likes this.
  6. Aug 5, 2019 at 1:10 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’m noticing a trend haha
    FlapJack935[QUOTED] likes this.
  7. Aug 5, 2019 at 1:15 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I wish I could remember why I got rid of the welded joint and went back to one with zip ties, but I’d recommend trying to get as many in there as possible before resorting to the welder. $1 worth of zip ties vs $80 or whatever that section of shaft costs if you don’t like it.
  8. Aug 5, 2019 at 1:19 PM
    desertjunkie760
    Shane
    Check My Sig.
    Where did you weld? Did you weld the rivets or?
  9. Aug 5, 2019 at 1:27 PM
    FlapJack935
    Jack
    Abq New Mexico
    do an LS they said, itll be cheap they said
    Dalandser[QUOTED] and Basikbiker like this.
  10. Aug 5, 2019 at 1:28 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
  11. Aug 5, 2019 at 2:10 PM
    desertjunkie760
    Shane
    Check My Sig.
  12. Aug 5, 2019 at 2:16 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I remember it was successful in getting rid of the clunk. You did get a lot more road feedback at the wheel, but that’s not why I got rid of that one and replaced it. I really don’t remember what I didn’t like/ why I ended up getting a new one instead of keeping running the welded setup
  13. Aug 7, 2019 at 9:40 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    anyone know of a good frame shop in San Diego? by 92109
    Caboose117 likes this.
  14. Aug 8, 2019 at 2:14 PM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    Besides cutting off the shackle hanger and replacing it, what are thoughts on bending it back just welding the seam? I will of course remove the shackle and bushings.
    I reached out to Tim at DMZ and he is going to send me a new one for free. Let me tell you, he has excellent customer service. And I am apparently the first person to break a part of his kit.
    I am not sure how I broke this. I mainly just do a lot of wheelin. I may have caught it on a rock ? I have not heard any loud pops on my recent trips and I am usually pretty good at inspecting my rig after outings.
    I feel like I should just cut off the old hanger. But I know it will be a major pain.
    If I do cut off the old one, do I have to break apart my spring pack and cycle the suspension again? Or can I just take some good measurements and then weld it on.
  15. Aug 8, 2019 at 2:16 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    impressive
  16. Aug 8, 2019 at 2:18 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You could get a solid round or all thread bar through the other side and use an angle finder to locate it. I imagine you could be close to original. Never hurts to break apart the spring pack and cycle though.
  17. Aug 8, 2019 at 2:22 PM
    concentric_killa
    Luckily I am on a work trip for the next month. It will give me time to ponder. I may fix it right and cut it off. I think I should be able to get it close if I measure the otherside.
    Arcticelf and Dalandser[QUOTED] like this.
  18. Aug 8, 2019 at 2:25 PM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    you could always use this as a good reason to link it, instead
  19. Aug 8, 2019 at 2:27 PM
    concentric_killa
    Haha thought about it. But I have a basement project to finish this fall.
    Arcticelf likes this.
  20. Aug 8, 2019 at 2:31 PM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    I'm mostly just sowing seeds of chaos. That's a pretty interesting place to break though.
