Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 11, 2020 at 11:56 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i feel like i need to pre-cursor this whenever someone asks me about them.
    I only did these because i have the upper arm adjustability. If i did not, i would be nervous to run the lock tabs because it could not let me dial the alignment in properly/as easy. Just remember that if you dont have upper arm adjustability.
  2. Feb 11, 2020 at 12:00 PM
    su.b.rat
    su.b.rat broken truck
    m00seNUckLEz likes this.
  3. Feb 11, 2020 at 12:01 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
  4. Feb 11, 2020 at 12:21 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    yeah these would be a major pita if you didn’t have adjustable uppers. You’d be better to make your own post alignment if you’re running bushing uppers.
    Arcticelf and LTDSC[QUOTED] like this.
  5. Feb 11, 2020 at 12:43 PM
    su.b.rat
    LTDSC[QUOTED] likes this.
  6. Feb 11, 2020 at 1:08 PM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    $100 for 4 bolts and 8 plates seems a bit pricey. I would like to have the plates without holes to lock my alignment where it is now. But it's a great idea. I'll look for Poly sales or coupons. I have heim upper arms.
  7. Feb 11, 2020 at 1:47 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    set it once and forget it. $100 isnt much anymore these days.
    3pooches likes this.
  8. Feb 11, 2020 at 1:50 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    If it would take you more than an hour to make its well worth the $100
  9. Feb 11, 2020 at 2:53 PM
    Cam2010taco
    Cam2010taco IG: Blvcktaco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Gas mileage sucks on the second gen, and it’s starting to make me want to get something more efficient now that I haul dirt bikes like every weekend. Do you guys think a valance would help a little to push the air around the flares? I have a bumper already so I would just need to put one on, so maybe it would help get me past like 9mpg...
  10. Feb 11, 2020 at 3:31 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It'll make your truck into a prius :thumbsup:
    That said if trophy trucks are able to go faster at high speeds with them, the CD is reduced.
    Cam2010taco likes this.
  11. Feb 11, 2020 at 4:14 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    9mpg is low. My truck is extremely inefficient and I get like 13.5.
    Do you have a check engine light on. Do you have a bad O2 sensor?
    Gunshot-6A likes this.
  12. Feb 11, 2020 at 4:20 PM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    No just all the flares, LT, tires, and the prerunner bumper do it I think. I plugged in my obdII and nothing came up and I cleaned out my maf and replaced air filters and all
  13. Feb 11, 2020 at 4:58 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I'm with @desertjunkie760 , I get about 13.5-14 depending on how much highway I drive. Check your plugs for carbon fouling, if you're running rich you should see it on the plugs. Besides the MAF, the O2 sensors could be a culprit. That reminds me, I wanna replace mine since I don't think they've ever been touched. Is your truck 2wd?
  14. Feb 11, 2020 at 5:33 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yeah 9 is extremely low unless you’re hauling ass all the time. Even I get around 13 with a s/c and 37’s. Are you calculating for larger tires?
  15. Feb 11, 2020 at 9:03 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
  16. Feb 11, 2020 at 10:59 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Not stoked for mpgs I’ll probably be getting in the prerunner - my 08 gets 18 in LA traffic.
  17. Feb 12, 2020 at 4:34 AM
    Y2kbaja
    Sacramento
    Total Chaos
    If I’m towing my race car (1600lbs) I get under 9 mpg and that’s not getting on the gas. Unloaded on the freeway it varies depending on which tank of gas it is. Going from Sacramento to Baja the first tank will get 12, then 15, then 18 by the time I roll into San Diego. It’s the computer learning my driving habit making the adjustment from commute to highway driving.
    t.hornstra, Gunshot-6A and LukeCC like this.
  18. Feb 12, 2020 at 11:16 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    @Cam2010taco
    2wd & With about 5” of Lift, 33’s, and glass, I get around 14-15 mixed normally.
    99% freeway and cruising at 65mph I can get over 18 though.
    I’ve found that strictly keeping Rpm’s under 2200 and going no faster than the speed limit will bump my mpg up ~2-3 when compared to even “normal” acceleration and going 70-75 on fwys.
  19. Feb 12, 2020 at 11:32 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I made my own before these were available, with an angle grinder and hand drill, and took several hours all said and done. The bolts alone were $30-$50 iirc, being metric, I would have gladly paid $100 for them. I did drill mine the way I wanted though.
  20. Feb 12, 2020 at 6:52 PM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Yeah I actually miscalculated a lot I was getting around 13-14 going like 75 with 2 dirt bikes in the back haha so I guess it’s better than I thought but I do a lot of highway miles anyways cause I haul my dirt bikes so much now so does anyone think a valance would help at all for mpgs? I’m thinking it would help flow air to the side of my truck not letting it parachute the flares so much and deflect wind under the truck rather than just letting the air smack the front with 100% resistance haha
