Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 6, 2020 at 2:51 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    +1 for Zuk!
    Nice guy and very honest.
  2. May 6, 2020 at 7:02 PM
    brandonstocool
    brandonstocool Well-Known Member
    Brandon
    California
    2001 Silver Tacoma Double Cab TRD
    Camburg LT Kit King 2.5 8" Coilover Mcneil Fiberglass 6"&Hood Billstein 5100 OME Leaf Spring Fiberwerx 4.5" Bedside
    Thanks for the insight, I’ll go with what you said and get a set from Toyota.
    motoxscott[QUOTED] and Dalandser like this.
  3. May 6, 2020 at 9:40 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Nobody in the IE with a spring compressor I can borrow?
  4. May 6, 2020 at 9:50 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    You didn't get the harbor freight ones when it was on coupon?
  5. May 7, 2020 at 4:28 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Recently my steering rack has been making a groaning sound at I think most all vehicle and steering turning speeds.
    At a standstill, pulling in and out of parking spots, and U-turns.
    Kinda sounds like someone rubbing their finger down a wet pane of glass.
    Is the rack near the end of its life? Clean the seals?
    Also I’m not 100% sure it’s the rack. It could be the oem ball joint on the tie rod, or the uniballs on the camburg kit. The uniballs are a little over 2 years old with most all street driving. Couple pismo trips, and a few desert trips. I’ve been cleaning and lubing them regularly.
    Don’t think the sound is there when the suspension cycles though, just when the wheels turn from lock To lock.
    Thanks for any input !
  6. May 7, 2020 at 4:31 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Wouldn't hurt to jack the front up and see if the sound's there when there's no pressure on the wheels.
    Sterling_vH111 likes this.
  7. May 7, 2020 at 5:26 PM
    pupdrew
    pupdrew Well-Known Member
    Andrew
    805 SLO- 951 Riverside
    04 4x4 Dbl Cab TRD
    working on it!
    Anyone have any 2.5 8" coilovers for sale ?
  8. May 7, 2020 at 5:51 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    @Supra4x4
  9. May 7, 2020 at 6:21 PM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    my camburg upper uniballs make tons of this noise when they need to be cleaned and need a new application of triflow. I’ll notice it more when it’s hot outside.
  10. May 8, 2020 at 8:43 AM
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    My truck occasionally does this. Your uniballs are probably dirty.
  11. May 9, 2020 at 3:27 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Recommendations on limit strap brand for some 20” straps anyone?
  12. May 9, 2020 at 6:49 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I’ve been happy with my kartek straps
  13. May 9, 2020 at 9:00 AM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    There some foxes i found for 400 but they arnt tacoma spec they are standard
  14. May 9, 2020 at 10:18 AM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    Been super happy with my karteks
  15. May 9, 2020 at 10:11 PM
    Sterling_vH111
    Sterling
    socal
    Ty all for the replies!
    Stiff plastic I’m assuming? Not metal wire.
  16. May 9, 2020 at 11:47 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Floss
  17. May 9, 2020 at 11:47 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Shit lot of vendors
  18. May 9, 2020 at 11:49 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Yotamasters suck ass. Worst in the history of the shit. They should be wiped out the map for good. Ass clowns 100%.
    tetten and Airdog[QUOTED] like this.
  19. May 10, 2020 at 9:16 AM
    Tango Bravo
    Thomas
    SoCal
    Do any of you bother with battery boxes for your main? Or is that just an overlander thing
  20. May 10, 2020 at 9:27 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I relocated mine to behind the back seat.
    Hawk373 likes this.
