Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Nov 23, 2020 at 6:15 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Calling so soon after the baja 1000 you probably got the part time sales guy's lil cousin at all those places lol
    FlapJack935 and whatstcp like this.
  2. Nov 23, 2020 at 8:11 PM
    brandonstocool
    brandonstocool Well-Known Member
    Brandon
    California
    2001 Silver Tacoma Double Cab TRD
    Camburg LT Kit King 2.5 8" Coilover Mcneil Fiberglass 6"&Hood Billstein 5100 OME Leaf Spring Fiberwerx 4.5" Bedside
    Was wanting to put 750LB spring rate on my 8" kings to help raise the ride height. Any opinions? Will it be a noticable difference?
  3. Nov 23, 2020 at 8:21 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    What front setup are you running? What springs are you running?
    750 is pretty heavy. I have a heavy setup and only run 700’s. Most people run 600 or 650’s
  4. Nov 23, 2020 at 8:37 PM
    brandonstocool
    Brandon
    California
    i have Cambur LT kit with the 2.5 King 8" coilover. I have the trailgear rock defense low profile front bumper and my front didnt get raised at all when i put the LT kit on. I am unsure what spring rate is on them right now. I got them from camburg. Wasnt sure about what i should go to, i chose the heaviest they have.
  5. Nov 24, 2020 at 5:35 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    There should be a marking on the spring somewhere if you look. Something written on the side like 3.00.600.16. Try to find it and see what they say. I bed they’re just 600lb springs. At which rate you can get 650 from eibach or 700 from king. But first you can see what you have and see about just trying to adjust preload.
  6. Nov 24, 2020 at 6:07 AM
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    I am running the camburg kit as well, but running 500lb 18" springs per Accutune, but I like my truck sitting lower (maybe 2" above stock ride height). I have a steel skid, tube bumper, and winch...strong believer in damping. If you ordered everything from Camburg, the coilovers most likely came with a 600lb 16" spring. I recommend talking with Accutune and they can recommend the right spring by weight and desired ride height. If you don't like it, you can swap springs and try again at no charge. My guess is they will most likely recommend 600 or 650 18" springs. 18" have more travel thus more adjustability before coil bind.
  7. Nov 26, 2020 at 3:49 AM
    brandonstocool
    Brandon
    California
    Thanks, sounds like I was going to get a coil that was way too stiff for my application. I will definitely give them a call
    Adventure4x4[QUOTED] likes this.
  8. Nov 26, 2020 at 3:50 AM
    brandonstocool
    Brandon
    California
    Appreciate the response, I will definitely look at my coils in the morning and go from there.
  9. Nov 26, 2020 at 7:00 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Any 1st gen guys have experience going from a 3.5 over front kit to the Solo XLT kit? Is the added travel a huge difference or at least enough to make the change worth it? I guess 2nd gen experience would probably apply also.
  10. Nov 26, 2020 at 7:39 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Can’t say I’ve gone from 3.5 to xlt but I’m strapped at 16” before cutting out sheet metal - probably could eek out 1-1.5 more inches if I deleted the inner fender.
  11. Nov 26, 2020 at 11:14 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Got her strapped up at just shy of 14.5 in of travel. Now just need to get my reservoirs mounted and set ride height.
  12. Nov 27, 2020 at 5:49 AM
    atvlifestyle
    Michigan
    01 trd tacoma
    I guess the real problem I run into is that the truck is currently bumped with the skid on the ground. So is the XLT additional travel useable if you do the work to pull the full 17" to 18" claimed. I understand its wider so there will be more droop also. I am probably just expecting to much jumping a 4x4 truck.
    https://www.instagram.com/p/CHEMfjeBbSH/
    https://www.instagram.com/p/CHJi-bAB5sC/
  13. Nov 27, 2020 at 5:54 AM
    MI-FLoffroader
    MI-FLoffroader Brett
    Brett
    Merritt Island, FL
    12' T4R LE/2003 SR5 SPORT V8/1988 DLX 22RE AUTO
    2012 T4R LE -Shoreline Blue Pearl 2003 T4R SR5 Sport V8 -Stratosphere Mica
    Hello Gentlemen, Happy Black Friday. - 03' T4R V8 - TC Standard Length Dual set up -
    Odd question here and your page is the only opinion I would trust just by the sheer volume of experienced fab guys on here. I'm looking at Dirt Kings BF sale and wondered if their LT bypass specs would work with a TC dual hoop that is already installed on my 4Runner.
    We welded the top hat bolt sleeves of the hoop to the bucket to make sure they would stay solid, so removing them and replacing with the DKs would suck.
    The TC hoop has an odd angle compared to the DK straight forward design, but it looks to me that the two top shock mounting bolts are close to the same orientation and maybe I could get away with relocating and shortening the tabs and using longer top hat bolts to accommodate the DK LT CO set up to work with the different top hat design of the TC hoop.
    I've included two pics, one of the DK and one of mine when we welded it up for comparison. I'm sure there is no positive way of knowing without mocking it up, but I thought I'd ask what you guys thought about it. And yes I shoulda gone +3.5" to start with lol.
    Thanks and hope your T-Day was a good one.
    Apex Fab 2.jpg TacomaLTKit_1400x_9590a4b6-da65-4019-891f-c3b7da86a601_1400x.jpg
    malburg114 likes this.
  14. Nov 27, 2020 at 7:17 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Probably not since yours is stock width and running stock length shocks. (6”)
    I mean technically yes I’m sure you could make them work by moving the upper shock mount but your bypass zones would be in the wrong spot. Best would be to get the correct length shocks for your application
    Sterling_vH111 likes this.
  15. Nov 27, 2020 at 7:19 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    You silver lake guys go big lol. I’d say yes there will be a benefit, and just go bigger tires so you can bump out higher up
  16. Nov 27, 2020 at 8:14 AM
    atvlifestyle
    Michigan
    01 trd tacoma
    Silver Lake isn't that big so we make the best of the space i guess.
    Unfortunately clearing 37's on a 1st gen takes alot if you still want to be able to cycle any travel. Probably just time to start building the next truck just have to finish some other projects first.
  17. Nov 27, 2020 at 8:31 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    What size are you running now? Look small to be 35’s. But clearancing for bigger tires on a truck that’s caged and already has a ton of work into it doesn’t seem like a deal breaker. Pretty sure the xlt kit pushes the tire forward as well to help. Or just stiffen up the valving to handle the bigger sends and keep enjoying what you got.
  18. Nov 27, 2020 at 10:01 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    It’s not that bad. But I keep popping front CV’s which is annoying more than anything else. Front diff has held up well so far
  19. Nov 27, 2020 at 10:14 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’d fit a 8” or Tundra 9” up front if you’re redoing the whole front - then you can rock 37’s like @snowsk8air2
    https://www.tacomaworld.com/threads/04-tacoma-turned-buggy.165208/page-10#post-21517499
    snowsk8air2 likes this.
  20. Nov 27, 2020 at 10:43 AM
    atvlifestyle
    Michigan
    01 trd tacoma
    I have run "35's". My current are 295's but only measure 3/4" smaller than my 35's did. Didn't really make much difference when you consider we run our tires at 6 to 8psi. On 295's I don't go thru cv's and less weight helps pull 4th gear in the soft sand. I also hope I will not go thru as many transmissions but time will tell.
    I am going to move my bumps to the upper. So was wondering if the XLT kit is some huge upgrade I should do so I don't have to do that work twice. In the end trying to keep up with beamed and linked v8 trucks I will always be at a big disadvantage. I am not allowed to build another truck until my wife's Bug is done but making changes to the taco is ok because im just fixing stuff lol.
    snowsk8air2[QUOTED] likes this.
