Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 22, 2021 at 2:48 PM
    TacoBoone
    TacoBoone Well-Known Member
    Ontario, CA
    2016 Toyota Tacoma TRD SPORT
    This is true! I just called em and they verified that the spacing is different on the rear bolts closest to the tailgate
    DannyBFresco[QUOTED] likes this.
  2. Feb 22, 2021 at 2:56 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Anyone had an axle shaft failure yet?
    ovrlndkull likes this.
  3. Feb 22, 2021 at 3:10 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    @MonkeyProof sheared a shaft a couple years ago.
  4. Feb 22, 2021 at 3:23 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Well, there goes that lol
  5. Feb 22, 2021 at 3:28 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Do you run the diff drop with your DK kit? Just curious. What were the circumstances when it gave up the ghost?
  6. Feb 22, 2021 at 3:43 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    When'd ya do that. I broke one this weekend too. Sheered it right at the tulip on the inner joint. Those are just stock length aftermarket axles.
  7. Feb 22, 2021 at 3:46 PM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    No diff drop. But I'm strapped before it binds and at ride height cv axles are perfectly parallel. But I was climbing a decent ledge and can only assume the 37s with throttle pinned and a weird bounce caused it. But typically I blow up the outers. Just weird coincidence. Not upset about it and dirtking hooked me up with a slight discount on the new shaft. Just curious if it had happened before.
    Tacoma1192 likes this.
  8. Feb 22, 2021 at 3:48 PM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Last November I believe... 4130 chromoly shaft. And that's the outer side
    ovrlndkull[QUOTED] likes this.
  9. Feb 22, 2021 at 4:16 PM
    TacoBoone
    Ontario, CA
    Swing and a miss haha
  10. Feb 22, 2021 at 4:22 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It sounds like it's a ways away, but check out Dirt King, DMZ, and JD Fab's spring under kits simply because a couple guys on here have had less than good results with the Camburg spring under despite them making good parts for other applications. Dirt King has a few guys on instagram that have some good videos. @snowsk8air2 has the DMZ kit.
  11. Feb 22, 2021 at 4:31 PM
    TacoBoone
    Ontario, CA
    and this is why I joined the thread that is good to know! I was going to go with DK for my LT arms until I seen the 4.5 lt arms which I like just that much more ill definitely go check them out rn :thumbsup:
    BEAR_KNIFE_FIGHT likes this.
  12. Feb 22, 2021 at 5:33 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I snapped 2 of the dk shafts on 35’s. Both seemed odd circumstances for my failures. Both right at the outer cv for me. Ended up going to RCV’s and hope that will limit failures in the future.
  13. Feb 22, 2021 at 5:37 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I’ve been super happy with my DK kit and DMZ out back. Used and abused for a few years now. Only issue up front I’ve had were a few snapped axles from playing in the rocks, and then bent shackle hangers in the rear again from rocks. I’m getting 15” travel up front and just shy of 17” out back. That said, the JD fab stuff is looking very promising.
    Arcticelf and ovrlndkull like this.
  14. Feb 22, 2021 at 7:25 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  15. Feb 23, 2021 at 4:11 AM
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Makes me feel better. Wonder if they had a bad run of axles. I am still nervous to go with rcv. But I say by next year year it will happen.
  16. Feb 23, 2021 at 5:18 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I have yet to really test them in the rocks and since I probably won’t be 4wd again until late summer it will be a while for that to happen anyways. That said they are significantly larger with the added benefit of being made from 300m instead of 4130
  17. Feb 23, 2021 at 5:56 AM
    kzrpk5
    kzrpk5 Well-Known Member
    Wisonsin
    2016 Tacoma
    TC Long Travel, SUA, Bed Cage, Fiberglass, 38", JD Fab LCA mounts, roll cage, manual hub conversion + Stickers!
    I know when you have the wheel cranked hard and there is a lot of torque on the hubs like when you are rock climbing or whatever, that is when axles/hubs are at their weakest. Not sure if this is was the case. Better the axles snaps off clean as opposed to something more$$ and harder to get at. That's what worries me about RCV axles, if they don't give, something up the line may go. Now if I snapped an axle on the trail, no big deal, just unlock the hubs and head back.frontshocks2.jpg
  18. Feb 23, 2021 at 5:58 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    What set up are you running to get locking hubs?
    MI-FLoffroader likes this.
  19. Feb 23, 2021 at 8:15 AM
    TacoBoone
    Ontario, CA
    Oh okay, Yeah i think right now its between dk and btf for my LT kit. On the plus side im 2wd so I don't have to worry about my axles snapping up front. Big sad for you :confused: but Yeah i was checking out that DMZ Kit I really like it and even better theyre like 10-15 minutes from my house !! haha
    snowsk8air2[QUOTED] likes this.
  20. Feb 23, 2021 at 9:23 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Tim and Kelly are nice guys and awesome to talk to about your plans for your truck too.
    snowsk8air2 likes this.
