Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 27, 2021 at 12:02 PM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    I don’t disagree
    But
    Also no real issues when high horse power either
  2. Apr 27, 2021 at 12:04 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Isn't there about a 100lb weight difference just in the blocks between iron and aluminum ?
    TireFire likes this.
  3. Apr 27, 2021 at 1:19 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Yes
    But that motor is also spec’d to start at 700hp and go to 1200 depending on the build spec you chose
    doing so with aluminum (from my research, so subject to error)
    Is a higher cost for the same parts to make sure it plays correctly at higher HP and temp with the expansion/contraction of the block
  4. Apr 27, 2021 at 2:11 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    The Geiser luxury prerunners based off the raptor would be turn key and probably would be around the same price in the long run. 50 gal fuel cell is pretty big as far as range, really really big as far as proportion to the truck. You're acting like there's multiple options where to put it when realistically it's more like pick the front side or the back side of the bed - fuel cell goes there, everything else on the other side. If you really wanted to go nuts with a custom tank i guess you could get a real big flat one and make that the whole bottom of the bed or under the raised section at the back of the floor if double cab but those would be kinda dangerous even with the bottom well plated
    Edit: i'm not sure i understand your budget either. Seems you're constantly dropping thousands on parts then trying to resell them here like a month later but you don't got the money for a built prerunner or even a down payment/collateral on a fancy loan for one??
  5. Apr 27, 2021 at 2:47 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you've spent enough on a Taco prerunner to be able to afford a tube chassis race truck you've done something far more egregious in the build of your truck than we are aware of
  6. Apr 27, 2021 at 5:09 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Yeah my taco build even with all my wrong choice parts is still in the 125k or less
    in response to @not_nick
    I have only had 2 parts I needed to flip
    1 set of tig welded trailing arms from the camburg race truck that I “thought” would work on my truck
    I was wrong
    So parts need to be sold
    then I bought links from Steve at dirt designs
    Gangster links and I like them a lot
    the person who is going to finish my truck wanted tig links and a different length,
    He knows a ton more than me and as a friend I trust his judgement
    Thus....
    Dirt designs links gotta get sold
    seems pretty straight forward
    And in total only 4500$ between both sets of parts
    so still far short of 200k+
    And to be clear
    Cause it seems to be somehow important to you how much I make....
    I make 50k a year
    may I see your truck?
    I’d love to see where your build is at
    Edit:
    I have a build thread here nick
    Why don’t you look at it. You can determine how much money is in my truck and let us all know if the trophy truck would have been cheaper
    jamesepoop likes this.
  7. Apr 27, 2021 at 6:07 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Good :fistbump: yeah with all the “learning experiences” and parts list you’ve shown it’s not cheap but I would definitely say nowhere near $125k. I can barely afford my stupid driveway ornament too lol.
  8. Apr 27, 2021 at 6:11 PM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I’m sure you saw the results of the last “cage” if that’s what they wanted to call it
    But that really devastated my budget
    And then the second half of 2020 covid added insult to injury
    If it hadn’t been for those two hiccups I’d likely have been done and driving by now
  9. Apr 27, 2021 at 6:14 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Similar to this truck. Didn’t even have good welds on the half of the tubes that actually were welded. It’s the worst way to find out a shop sucks besides getting killed in a roll over.
    https://www.instagram.com/p/B9XTmrqBBaZ/?igshid=1rp9vb3otykl4
    Caboose117[QUOTED] likes this.
  10. Apr 28, 2021 at 5:53 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Nah bro u want 2 K swap it.
    Yeah at this point from when it originally needed work, I've upped my space, equipment and software enough to where I could build the whole truck at my version of @beertimecontinuum DYF
  11. Apr 28, 2021 at 7:49 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I hope you know how ignorant of a post this is.
    You do realize that the Geiser luxury prerunner approaches 1 mil in price, right? Even if @Caboose117 was into his truck $125, which I have no idea if he is or isn't, that wouldn't cover the maintenance & fuel cost alone of a tube chassis truck.
    Who cares if he buys and sells parts. It's his project. It's his money. Let him make those decisions.
  12. Apr 28, 2021 at 8:09 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    And the great White Knight comes to the rescue!!
    @Caboose117 did a fine job defending himself. Your rant is no better than the first.
  13. Apr 28, 2021 at 8:12 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    On a different note
    How are you?
    How’s the build?
    nudavinci64 and Airdog[QUOTED] like this.
  14. Apr 28, 2021 at 8:19 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    I’m well.
    The build is Never ending to say the least. Waiting on King to get my shocks to me like the rest of the country. Then install the front +4 LT by JDfab. Who knows from there.... probably a Ford 9 axle. As you know it never stops.
  15. Apr 28, 2021 at 8:24 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Do you have a pic of how it’s sitting right now?
    I know mine looks like scrap metal :bananadead:
  16. Apr 28, 2021 at 8:39 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Speaking of $100-$200k spent on a truck....
    this truck
    ....and they had a reserve higher than the 71K it was bid to.
    AND no Bypass shocks in the rear???
  17. Apr 28, 2021 at 8:44 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Lol smp fab selling his truck huh?
  18. Apr 28, 2021 at 9:40 AM
    desertjunkie760
    Shane
    Check My Sig.
    What's your current kit up front and your plans for the rear?
  19. Apr 28, 2021 at 9:52 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Current front is this bastardized setup
    upload_2021-4-28_9-45-38.jpg Rear is currently DMZ SUA....the Rear plan is to try to get a full float 9 inch. But it depends on getting a rear speed sensor signal back to the trucks computers. Being 2wd I lose my speedometer and supposedly speed sensor info for the tranny. Plan is to try and tap the signal from the front sensors into the rear sensor wires and see how it behaves. Obviously I will completely disable the ABS system to keep it from trying actuate the brakes on the wrong wheels. I have a wire harness built up. Just gotta tap into the existing wires and see what happens.
    jamesepoop, Dalandser and Caboose117 like this.
  20. Apr 28, 2021 at 10:04 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    That whole complicated mess with the speedo was a major thought in my plans
    And is honestly what was the first reason I started debating the motor swap in my plans a few years ago.
    It just ended up being more financially sound to just find a junk 6.0 or buy a 6.0 and run Holley stuff just so you could use the right drivetrain parts like the beefy housings
    I’ve got a camburg 3.5 for mine
    But have debated selling it since the person building the truck REAAAAALY wants me to have a tig blitz housing :bananadead::boink:
    every time we talk he’s like
    Sooooo.... mig stufff is okay but tig:deadhorse:
    Lol
    Oh wait
    I forgot I’m not supposed to sell stuff
    edit: every time it’s moved in the last few years
    It seems someone would like to build it a bit different for one reason or another based on their experience
    Like fuel cell against the back of the cab or in the booty
    And shocks outside of the cab vs inside the cab
    And still accommodating 4 seats
    malburg114 and Airdog[QUOTED] like this.
