Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 1, 2021 at 1:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just took my first trip out with heimed tie rod ends and I felt a lot more feedback through the steering wheel, some harsh. Is it correct to say that they transfer more energy into the steering rack?
    If so, does that cause more stress on the stock rack leading to premature failure?
    I’m just curious for the sake of conversation as I decided on the tundra rack which I’m sure can handle the additional stress. I just want to make sure I know what I’m talking about if someone asks me for my opinion on heimed TRE on a stock rack.
  2. Aug 1, 2021 at 1:40 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Its always been the general consensus that heimed steering is tougher on the rack. But the Howe PS pump will solve the feedback issue completely. The difference since I installed it a few weeks ago is amazing.
    EatSleepTacos[QUOTED] likes this.
  3. Aug 1, 2021 at 1:48 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The feedback was mainly when I would hit small rocks a little too hard. Idk if you’ve ever experienced it but if your tire catches a rock wrong and the steering wheel gets ripped out of your hands? Like that but toned down a lot. I had to grip the wheel a bit harder to keep it going where I wanted to go. Granted, this is me going probably too fast for conditions, but it was just an observation I had.
    I would love the Howe pump. Just not in the cards at the moment. For now I have a new oem pump to go in and some poly rack bushings to fix this whole “banjo bolt bending and losing braking” issue. So hopefully that improves steering somewhat.
  4. Aug 1, 2021 at 1:59 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    I know what you are talking about but i still think its an artifact of the shitty toyota pump and the check valve issue in it.. The OEM PS pump I just took out is less than 6 months old because the original was making noise. It solved nothing other than making the noise go away...hopefully the bushings solve the banjo bolt issue...thats a big one.
  5. Aug 1, 2021 at 2:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh perfect, that’s why I’m replacing mine, because of the noise. It’s due anyways though, 217k miles on it. And I agree about the bushings. It’s not fun having that in the back of my mind, wondering if I’ll lose my brakes again.
    Airdog[QUOTED] likes this.
  6. Aug 1, 2021 at 2:55 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Since it's a more "solid" connection along with the more "solid" pivots in your LT you're going to feel a lot more feedback. It isn't a bad thing as far as actually getting behind the wheel and getting better feedback as to what the truck is doing. If you've never really had a vehicle with solid mounted suspension stuff it'll take some getting use to. Personally I love feeling more connected to what's under the tires and what's happening via that feedback.
    As far as bad for the rack yup it's going to transfer more energy. I noticed I jump teeth far easier now. Eventually it'll cause an issue but how much sooner than just stock stuff not sure that's all depending. I wouldn't let that be a hesitation in doing it or recc it to someone. It's a worthwhile upgrade which most serious wheelers are replacing racks regularly or upgrading at some point. For the avg overlander meh not really worth it
  7. Aug 1, 2021 at 2:58 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I didn’t think about the solid bushings, that’s a good point as well.
    ovrlndkull[QUOTED] likes this.
  8. Aug 1, 2021 at 3:00 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yep it all puts more feedback.
  9. Aug 1, 2021 at 3:39 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    @EatSleepTacos you should be able to port the stock pump to eliminate the check valve deal. Would basically just take gutting the fitting.
  10. Aug 1, 2021 at 3:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Maybe I’ll try that with my old one as an experiment to see what happens
  11. Aug 1, 2021 at 3:46 PM
    906taco
    Cory
    08 Taco
    I would. It should help substantially with the feedback.
    You also gotta remember with uniball pivots, you will undoubtedly transfer more feedback to the chassis as a whole. Personally, I’d be willing to bet your super light spring rate is also a contributing factor.
  12. Aug 2, 2021 at 12:00 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Has anyone tried to bump off of the upper arm on a kit like Camburg or TC?
    Only see it on ones like Dirt Designs, Solo xlt, or LSK race kit.
    I assume there’s a good reason as to why it’s not commonly done, probably weak points like tapered uniball adapters or the spindles themselves bending/snapping?
    The reason I’d like to is so the bump is only working in the last 2” or so of travel, getting around the problem of them being too active when striking on the LCA.
  13. Aug 2, 2021 at 12:11 PM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    It comes down to support that sort of load to the chassis. A huge bracket to get it there would most likely have too much leverage on the frame. Engine cage install territory. The amount of work isn’t worth the trade off in most cases.
  14. Aug 2, 2021 at 12:23 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    you would need a full engine cage and fabricated spindles. a regular ( even gusseted) spindle would fold with all of that pressure on it
  15. Aug 2, 2021 at 1:12 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    These^^^
    Also add in packaging: the spot you need to put the bump can is currently occupied by the relay/fuse box on the drivers side and the ABS module on the passengers.
  16. Aug 2, 2021 at 1:31 PM
    Sterling_vH111
    Sterling
    socal
    Thats the other reason I was entertaining the idea, im going to be getting an engine cage/ installing bypasses by the end of this year. Might as well try and see if it makes sense to add a bump off the Uca since I’ll be cutting off the oem bumpstops anyhow.
    I’ll talk to my fab buddy who will be doing the tube work and see what he says as well, as the front core support is planned to be all tubes already.
  17. Aug 2, 2021 at 1:32 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    I know people will say you cant but it has been done successfully in the past many times. The kit doesn't change what is required on the truck to take the load/ hold the bump. A buddies truck still runs a stock gusseted spindle. We ended up welding the slug into the spindle because after awhile the snap ring gave. Just weld a bump plate on top of the unibal bolt to strike off of. This is a first gen taco.
  18. Aug 2, 2021 at 1:46 PM
    Tacomoto23
    Tacomoto23 Well-Known Member
    Carey
    Torrance,CA
    21’ TRD 4x4
    Might as well try and get a kit that uses a vertical uniball fabricated spindle so that you can bump off the upper. Especially if you’re going through all that work.
  19. Aug 2, 2021 at 1:57 PM
    Sterling_vH111
    Sterling
    socal
    @lemons6245 has some stuff that I like, but his LSK kit also relocates the uppers close to the frame so the can is mounted a lot lower than mine would have to be.
    Tacomoto23 likes this.
  20. Aug 2, 2021 at 2:04 PM
    Sterling_vH111
    Sterling
    socal
    The more I think about it the more this seems like the correct route lol. Think I’ll put this Idea on the shelf for now and just go off the lower !
    Tacomoto23[QUOTED] likes this.
