Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 3, 2021 at 9:45 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Fair enough, that's a point I hadn't considered.
    I'm sure you could upgrade and fit a bigger/longer shock in if you had the interest and knowledge, too.
    EatSleepTacos[QUOTED] likes this.
  2. Aug 3, 2021 at 9:48 AM
    StellaHolland
    StellaHolland New Holland Overland (Holland, MI)
    Jeremy
    Holland, MI
    2017 Tacoma TRD OFF-ROAD
    King 2.5 custom valved Milestar A/T Pro 285/70/17 on Method 702's New Holland Overland custom front bumper, roof rack, sliders & skids Mix of Diode Dynamics & Baja Lights 5.29's w/ KDMAX tune Skinny Guy Camper Bare Bones w/ Alu-Cab 180 Awning Freedom Retrofit custom headlights ... & So. Much. More
    Estimated travel is 13" with that new kit (+2"), im definitely going to be getting the kit once it releases since I dont wanna wait the 11 month lead time for new King coilovers.
    I still have 4-5 months left waiting for my rear King 12" shocks (ordered back in march, 9-10 month lead time).
  3. Aug 3, 2021 at 9:50 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Most people don't want or need a bypass shock. I'm sure that's why they call it a "trail kit."
    They know what their potential market is. Curious to see one in action.
    StellaHolland likes this.
  4. Aug 3, 2021 at 9:55 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    know their audience ? ...you really think people running a +2 kit that usually wont spring for air bumps are going to spend $1600 on bump stops ?
    Dalandser and a2lowvw like this.
  5. Aug 3, 2021 at 9:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'd be surprised if it could pull 13" while only being +2. I'm basing that off of the fact that the TC +2 pulls 11.5" and my JD +2.25 pulls 13" but it's only possible with the extra articulation the 934 CV's allow.
    I could be wrong, but I would think the CV would be the limiting factor here.
    desertjunkie760 likes this.
  6. Aug 3, 2021 at 9:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Absolutely I do.
    edit: Unless the slapper bump is optional. In which case I can see a lot of people opting not to add it. But it seems like the mounting tabs are where the OEM bump would hit. Hard to tell. If it's not optional then it's odd that it's not rolled into the whole LT kit.
  7. Aug 3, 2021 at 10:05 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    The mall crawlers will.
    Tbasch likes this.
  8. Aug 3, 2021 at 10:05 AM
    desertjunkie760
    Shane
    Check My Sig.
    I agree. The numbers don't add up but it's not unheard of for companies to exaggerate on travel #s.
  9. Aug 3, 2021 at 10:07 AM
    desertjunkie760
    Shane
    Check My Sig.
    Yes, I do. Save the cost of adding a bypass and obtain good bottom out control without the noise. Not saying it's a route I'd personally take but I see why it would be appealing.
    not_nick and EatSleepTacos like this.
  10. Aug 3, 2021 at 10:08 AM
    desertjunkie760
    Shane
    Check My Sig.
    Also, looking for a set of front fiberglass for a 2014 Tacoma with a 3.5" kit if anyone has a line on a set.
    jdiola and Dalandser like this.
  11. Aug 3, 2021 at 10:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Plus money saved from not buying a CO can be redirected towards the bump
  12. Aug 3, 2021 at 10:15 AM
    StellaHolland
    Jeremy
    Holland, MI
    Im surprised too if the kit can pull 13" especially without modifying the CV's. Im just pulling that number from the product page description for the kit
  13. Aug 3, 2021 at 10:30 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    unless i am misunderstanding their web site the slappy bumps are an extra $1600 over the price of the base kit
  14. Aug 3, 2021 at 10:32 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    def agree, a +2 kit with oe cv’s & properly bumped and strapped you’ll be lucky to see 12”
  15. Aug 3, 2021 at 10:33 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's what I'm seeing too.
  16. Aug 3, 2021 at 10:35 AM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    You've got it right, the slappys are an upgrade on the trail kit.
    Long Travel Kit:
    • Tubular 1.25 uniball upper arms with bushing pivots
    • Boxed lower control arms
    • Extended front brake lines
    • Steering extensions
    • Hardware
    Options:
    • Camburg 4340 4wd axle shafts
    • Billet 1.25 uniball upper arms with heim pivots
    • Camburg FOX 2.5 bump stop kit
  17. Aug 3, 2021 at 10:37 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You only lose about $400 on a resale of King or Fox OEM shocks - maybe reusing them sounds good on paper and I’m sure it does to noobs, but not worth it when you lose out on a bypass.
    Dayman Karate likes this.
  18. Aug 3, 2021 at 10:38 AM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    After selling my reg travel kings I only spent $250 on new foxes. They were ready to go before any front or rear LT stuff was.
    Dalandser likes this.
  19. Aug 3, 2021 at 10:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think some of you more hardcore guys might be out of touch with the potential market on a kit like this. Most people don’t give a shit about a bypass. They think “I can keep my existing coilover, so it’s cheaper and faster” and “that slapper arm is really cool and unique, I want it so I can be different.”
    Their goal will be increased wheel travel (that they probably don’t actually need) and increased clout.
  20. Aug 3, 2021 at 10:49 AM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I bet it’ll sell in pretty big numbers as a “drop in” LT kit using your existing coilovers.
