Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 15, 2021 at 8:39 AM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    i mean rear wider than front
  2. Sep 15, 2021 at 9:05 AM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    why? pretty sure that would make the front end less stable handling in turns... in theory
  3. Sep 15, 2021 at 9:36 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    One example is it depends on how your rear shocks are setup. For example, I did a standard rear shock relocation and I needed more aggressive backspacing so my tires wouldn’t rub the shocks while articulating. I added small spacers to the rear to clear that and when I was stock width front end, that made my back end .75” wider per side than the front. I didn’t make the front match due to more clearancing issues at the firewall.
    not_nick likes this.
  4. Sep 15, 2021 at 9:43 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Was meaning no to having the rear wider than the front. I ran spacers for years and years without issue to keep a proper stance. Only finally ditched all spacers a few months ago when I finished the rear axle swap
    tacotunner06 and Slashaar like this.
  5. Sep 15, 2021 at 10:02 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    My rear is currently wider than the front. Only issue I have is I do occasionally snag a rear tire on something when I'm in tight spots.
  6. Sep 15, 2021 at 12:01 PM
    not_nick
    to clear shocks in the back. I've had a wheel almost fall off before cause of spacers so i'm a little scarred from that and my front suspension cycles pretty well without hitting cab mounts right now. I don't wanna run more spacers than necessary AND have to chop more stuff to clear in the front
  7. Sep 15, 2021 at 12:04 PM
    not_nick
    anyone selling 3.5bs wheels on the cheap? that could work too haha
  8. Sep 15, 2021 at 12:53 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I'm running 1.5" spacers all around but I also have +30 offset wheels on right now. I'll be moving to 0 offset soon.
  9. Sep 15, 2021 at 3:45 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    No reason a spacer that is properly installed would be a safety issue.
  10. Sep 16, 2021 at 6:21 AM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    The wider the rear the easier it is for it to break traction in a corner and come around. So the narrower the more likely it is to grab traction and not want to rotate. In the end it is a compromise on handling preference. Your front width is constantly changing based on where they are in the travel. (A-arms). In my old days of ATV MX we changed rear width based on track conditions and riding style.
  11. Sep 16, 2021 at 10:12 AM
    not_nick
    that wouldn't be too bad honestly. DCLB is like stupid stable with how long the wheelbase is. Always makes me feel like i'll roll it long before it starts to slide on dry pavement.
    Although quads are a lot more square. Would that change those effects?
  12. Sep 16, 2021 at 1:41 PM
    BrownMike
    San Diego
    1999 Taco 4x4
    I guess maybe Im misinterpreting the question a little. I was thinking you mean significantly wider rear track than the front, as opposed to matching track widths while still clearing shocks (tundra/t100 axle).
    Ive ran spacers on the front pre LT, and ran spacers on the rear to match the LT since. Never had an issue with them, believe they are 1". Not enough space to run shocks outboard, but enough to make the truck not look like it skipped leg day.
  13. Sep 16, 2021 at 2:59 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Been running spacers since I got my drivers license 10 years ago lol
  14. Sep 16, 2021 at 3:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The issue isn’t whether or not spacers are a good idea. I think most of us know quality ones are fine.
    He specifically wanted to know if a marginally wider (1”-2”) rear (i.e. spacers to clear rear shocks) would cause any issues. The answer is while theoretically it’s not ideal for handling, realistically it won’t cause any noticeable effect for the vast majority of Tacoma’s, if not all of them.
  15. Sep 16, 2021 at 3:56 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    But you could also put them on front :notsure:
  16. Sep 16, 2021 at 3:58 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Which means more rubbing at the firewall/everywhere else, depending on your wheel/tire setup.
  17. Sep 16, 2021 at 4:00 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol I don't even want to hear about 2nd / 3rd gen guys complaining about rubbing - you guys have to tub about as much or less for 37's as I did for 35's
    tacotunner06 likes this.
  18. Sep 16, 2021 at 4:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You ain’t lying. I had to tub the fuck out of a 3rd gen 4Runner for 35s, which I assume is a similar wheel well to first gens
    I also tubbed my firewall for 35s but didn’t have to do as much.
    Dalandser[QUOTED] likes this.
  19. Sep 16, 2021 at 4:01 PM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    well you have a tacoma, 2nd gens are t100s lol
  20. Sep 16, 2021 at 4:04 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    o_O :confused:
