Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. May 5, 2022 at 7:59 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    He's not beating his truck. He's not even caged. This isn't 4x4 wheeling
    Tacomoto23 likes this.
  2. May 5, 2022 at 8:04 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I wasn't piss pounding mine when it would pop either. I'm just saying its a very well known problem by anybody that uses these trucks. Not going to continue going back and forth on the topic. I know from experience a hit from the right direction at 20mph is all it would take. All of these steering rack solutions exist for a reason, and its not "just because".
  3. May 5, 2022 at 8:29 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Just the wheel knocking out of alignment? Check Your intermediate steering shaft pinch bolt real quick
  4. May 5, 2022 at 9:23 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    You literally cannot jump a tooth without it shearing. The rack has an adjustable saddle it sits against and isn't possible to bend it enough for the teeth to disengage and "skip".
    "Skipping" a tooth on Tacoma racks means the rack or pinion gets destroyed.
    Tacoma1192 likes this.
  5. May 5, 2022 at 10:08 AM
    906taco
    Cory
    08 Taco
    You're wrong. But I won't keep arguing. That saddle is preloaded with a spring and it does indeed skip teeth. I'm actually really shocked this thread of all places hasn't had this discussion yet.
  6. May 5, 2022 at 10:11 AM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    I thought it was just one of those, accepted things.
    desertjunkie760 and 906taco like this.
  7. May 5, 2022 at 10:12 AM
    906taco
    Cory
    08 Taco
    Thats what I thought as well. Didn't realize it was some big secret.
  8. May 5, 2022 at 10:27 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Maybe those tho have rebuilt racks and stuff could chime in.
    Tacoma rack jumping teeth possible ?
    @Basikbiker
    I had thought it was a decently known problem, but I’ve never messed with my rack or had that problem. Actually I’ve had less alignment issues since going LT.
    Nor could I tell you if it is actually the rack jumping teeth or some other occurrence in the steering parts that fails/bends/misaligns that TW has collectively labeled as “jumping teeth”.
  9. May 5, 2022 at 10:47 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Not saying you're wrong, but I can't imagine the rack is jumping teeth and lives another day (or year).
  10. May 5, 2022 at 11:49 AM
    99GC8
    99GC8 Well-Known Member
    Dwight
    Fort Collins
    2015 Taco supreme
    Mine jumps teeth almost every time I go wheeling.
  11. May 5, 2022 at 11:58 AM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I can verify this is correct and the amount of deflection a stock rack has is laughable. Don’t believe me, stroke your rack to one side with the tie rods off and grab the end of it... it will move around WAY more than anyone should be comfortable with. This is the reason we built the slide rack, it eliminates the deflection which prohibits the rack from skipping teeth
  12. May 5, 2022 at 12:13 PM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Idk i'm with him. Maybe jumping a spline on the column? Looking at the rack and pinion gears and the splines on the column it's hard to believe teeth on the rack would jump before the splines on the column sheer off
  13. May 5, 2022 at 1:20 PM
    tetten
    Andy
    Socal
    By skipping teeth you mean the rack or pinion bows/bends so far that it actually allows the pinion and rack teeth to disengage and change position relative to each other and then reseat without any damage?
  14. May 5, 2022 at 1:49 PM
    906taco
    Cory
    08 Taco
    Yes. That is what happens. And it does get worse over time. Idk what’s so hard to believe about it, our racks deflect a whole lot more than most would think.
  15. May 5, 2022 at 1:53 PM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I’ve gone out and hit something hard with a side load to the driver side in a sharp turn at 20-30mph. I didn’t check if it was a rock hidden by soft sand or a hole. Steering wheel alignment way off with no other symptoms of a bad wheel alignment. All paint marks lined up across the whole steering shaft to the pinion. Centered the wheel and there was obviously more rack on the passenger side. Recentered the steering rack, alignment was not much different than previous alignment numbers. Nothing checked out bent. Only thing I could come up with was it skipped a tooth on the RP.
  16. May 5, 2022 at 1:59 PM
    tetten
    Andy
    Socal
    Physics makes it hard to believe. I ran 40 inch tires on a stock rack, I'm very aware of how much stock racks deflect.
  17. May 5, 2022 at 2:00 PM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    we need a go pro and a sacrificial rig to test this! :bananadance:
  18. May 5, 2022 at 2:07 PM
    81Trekker
    La Jolla SD
    I bet I could push the end of the rack up by hand and if someone jerked the steering wheel it would skip a tooth.
  19. May 5, 2022 at 2:07 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
  20. May 5, 2022 at 2:13 PM
    tetten
    Andy
    Socal
    I've got junk racks sitting around, I'll put your hypothesis to the test.
