Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 29, 2022 at 11:30 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    :rofl: Yeah... found your issue. Revalve your C/O.
    Tacoma1192 likes this.
  2. Aug 29, 2022 at 11:33 AM
    erok81
    erok81 Well-Known Member
    Imposter
    I was just worried an 18” spring would be be too long for my coil overs. Since it’s 2” longer than my current ones with 3/4” of preload. Even ignoring preload, at full compression I’d think that extra 2” would cause issues. But as you said @EatSleepTacos runs them and at first glance they look like standard LT coil overs?
  3. Aug 29, 2022 at 11:35 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Should be similar, they're the JDF spec LT shocks -- I can't imagine they're too much different than yours!
  4. Aug 29, 2022 at 11:38 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They're the JD spec'd coilovers, which are a universal king 8" coilover with a couple of minor tweaks. Full extension is limited by 1/2", tuning per their specifications and different hose fittings.
    erok81[QUOTED] likes this.
  5. Aug 29, 2022 at 11:41 AM
    not_nick
    not_nick Well-Known Member
    keeping jersey dirty
    Hahah yea looked at literally all of those just before i posted, thanks still
    They all have stuff that's close but not quite. Ruff stuff has exactly the caps i want but no center hole. Barnes has pre-threaded weld washers that would be even better than what i had in mind but they only come 1.25 diameter. Might try those but i think it'll be just barely the wrong size for both the 1x.120 and 1.5x.095 i like to use (odd, i know). And i usually use a stainless nut; bare steel like that scares me with the winters here even with anti seize. Gonna see if a local place will cut my scraps
  6. Aug 29, 2022 at 11:44 AM
    not_nick
    i really don't like drilling lol
  7. Aug 29, 2022 at 11:52 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yep there ya go. Revalve to 10/10 and go from there
  8. Aug 29, 2022 at 11:53 AM
    erok81
    Imposter
    Nice! Okay that’s good to know. I’ll give 10/10 a shot and see how it goes. The bypasses are pretty close already so maybe I’ll leave those alone and just do the coil overs.
    Even though my issue is likely valving I’m tempted to try some lighter/longer springs just for fun since that’s an easy swap.
    I know yours are super light but to you have extra weight like bumper/winch?
  9. Aug 29, 2022 at 11:56 AM
    erok81
    Imposter
    Think I’ll gain anything from a lighter/longer coil too?
    I know the issue is valving for sure, but while it’s apart and springs are cheap, if I’d benefit at all I might as well.
    For the rear I might go down one on both. Someone mentioned theirs are one less on the rebound.
  10. Aug 29, 2022 at 12:08 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I wouldn’t change the springs honestly. With the extra weight you have up front I think the springs will be fine.
    As for the rear valving I’d definitely change to 8’s on rebound and after that you will probably be good with the front changes. Should really balance the truck out
  11. Aug 29, 2022 at 12:13 PM
    desertjunkie760
    Shane
    Check My Sig.
    Sometimes it's nice to just change a single variable so you can isolate the correction. If you change valving & spring rate will you be able to identify which had the greater effect?
  12. Aug 29, 2022 at 12:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    My front bumper+winch is ~140 lbs, and I also count my front skid as well which is another 60 lbs or so. I approximate 200 lbs of extra weight in the front. I shared a picture on the last page so you can get an idea of what my truck looks like.
  13. Aug 29, 2022 at 2:01 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Springs.....if your within the acceptable preload range of the spring and able to attain the desired ride hieght....you have the correct Springrate for your truck.
    Springs are there to just hold the vehicle up.
    If that stuff checks out, leave the springs alone. The ONLY reason to go to a longer spring is if the current setup is having coil bind at bump.
    Sure a minor spring rate change has a correlation with damping rate but unless your pretty dialed in before you change rates you will not be able to tell the difference.
    Revalve the coilover to 10/10 and if the piston has freebleed holes make sure they're all open. And try that first.
    Springrate would be the last thing to burn money on
  14. Aug 29, 2022 at 2:12 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What’s “acceptable preload range”? Is that just where you avoid block height of the spring or is that something else?
  15. Aug 29, 2022 at 2:37 PM
    erok81
    Imposter
    That’s about like mine. I’ll keep that in mind if I decide to swap springs.
    EatSleepTacos[QUOTED] likes this.
  16. Aug 29, 2022 at 2:47 PM
    erok81
    Imposter
    I guess good news is there is no such thing as a 650 that’s 18” long. So I’d have to drop down to a 600 which might be too soft.
    Funny you say that. I constantly tell people to change one thing at a time for this exact reason. :facepalm:
  17. Aug 29, 2022 at 2:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Accutune has 18”x650 eibach coils. That said I think that would be too high for you. I tried 18”x600 and even that was too high for me.
  18. Aug 29, 2022 at 3:45 PM
    erok81
    Imposter
    when you say too high you mean ride height or ride quality (aka stiff = high)?
  19. Aug 29, 2022 at 3:50 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Ride height.
    I'll throw my horse in the race. I'm also running 18x500. So far loving it with no bumper and a little preload. Have it sitting high, but should settle down once I add a bumper.
    EatSleepTacos likes this.
  20. Aug 29, 2022 at 3:58 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It sat way too high and it couldn’t sit lower because the preload collar was all the way up.
