Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 5, 2022 at 6:32 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yeah I remember those days. Get that front coil over down to a 10/10 stack and report back. I think that’s gonna make things 100x better
    erok81[QUOTED] likes this.
  2. Sep 5, 2022 at 6:44 PM
    erok81
    erok81 Well-Known Member
    Imposter
    I’m looking forward to it. For the most part I’ve hated this thing for a while now.
    Took some complaints from an important passenger to get me motivated to fix it.
    BEAR_KNIFE_FIGHT likes this.
  3. Sep 5, 2022 at 8:06 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Two turns in from full open right?
  4. Sep 5, 2022 at 8:16 PM
    erok81
    Imposter
    Yep. In from fully open.
    Basikbiker[QUOTED] likes this.
  5. Sep 6, 2022 at 2:12 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Anyone running the deaver h70HD spring under? Dont want to get back into a HD spring setup when I dont carry more than 200lbs.
    This is the only spring dmz recs even after I told them my weight carrying specs.
    Camburg offers a prerunner spring with their setup but I dont want to mismatch parts with companies that know what theyre talking about.
  6. Sep 6, 2022 at 2:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I believe @906taco has those and pulled a leaf out and it was perfect for his moderate weight in the back. He can chime in with specifics.
    IvanhoeTaco[QUOTED] likes this.
  7. Sep 6, 2022 at 3:07 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Alright, so like randy said I am on the HD pack. My issue was how high the rear sat, after a call to Deaver they suggested pulling the 5th leaf. Doing so dropped the truck down where I wanted it and softened things up. I would not be afraid of going to the HD pack in the least. My truck rides incredible like this.
  8. Sep 6, 2022 at 3:54 PM
    IvanhoeTaco
    Eastern NC
    Perfect feedback. Whats your bed weight like?
  9. Sep 6, 2022 at 3:56 PM
    906taco
    Cory
    08 Taco
    Basically an empty bed. But a tube rear bumper and frame plating/bracing. Probably equates to around 150lbs over stock
  10. Sep 6, 2022 at 4:05 PM
    IvanhoeTaco
    Eastern NC
    Cool, thats probably will be me as well.
    Ill trust dmz and get the leaf pack they reccommend. Based on your experience I might pull that leaf before i even install.
  11. Sep 6, 2022 at 5:16 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I wonder if the different rear shackle design between JDFab and DMZ plays a role? Are you using the DMZ setup?
  12. Sep 6, 2022 at 5:23 PM
    IvanhoeTaco
    Eastern NC
    Have not ordered any kit yet. As of now DMZ has been super helpful and promt with the responses so if they say use X leaf pack, I will trust them as this will be my first long travel build.
  13. Sep 6, 2022 at 6:04 PM
    906taco
    Cory
    08 Taco
    For what it’s worth, the JD fab kit is nuts. Both front and rear. I couldn’t be happier. I would give them a serious look.
    Also, from what im hearing from others the regular H70 pack is bordering too light for even a stock truck. That’s likely why DMZ says HD only. It took some playing around with valving to make the rear work, but with a heavier spring I was able to back off of the compression a good bit as HD’s have crazy good bottom out control. And it still rides amazingly smooth and plush.
  14. Sep 6, 2022 at 6:23 PM
    IvanhoeTaco
    Eastern NC
    I definately like JD rear hanger and its adjustability.
    I just imagine a HD pack only being soft at higher speeds...is this completely wrong?
  15. Sep 6, 2022 at 6:25 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    H70 is what a lot LT tacoma kits use now. Camburg, JD, and I think DK also use it. DMZ has their own custom leaf springs made by deaver for their kit last I checked.
    Edit: I’d do what @906taco did and do the HD and remove a leaf if needed.
  16. Sep 6, 2022 at 6:32 PM
    IvanhoeTaco
    Eastern NC
    Im seeing that. Yes, thats good advice as others have mentioned. Thanks everyone
  17. Sep 6, 2022 at 7:14 PM
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Tim was great answering my questions. Seems like a really good dude. I felt a little bad not going with their setup after the help. I know their stuff is tried and true but i didn’t really want the low hanging shackle hangers like camburg ect. which i why i was stoked to get in the jd sua early. Its been really good to me. Have the h70s which are crazy plush. Put it in reverse and the truck just sits. Crouches? lol hard to explain just more pinned to the ground. I know you aren’t going in that direction which is probably smart just throwing my experience out there. I've only had about 200lbs in the rear. Access cab.
    *and by not going in that direction i meant the h70s
  18. Sep 7, 2022 at 6:06 AM
    IvanhoeTaco
    Eastern NC
    One last question, and i dont want to ask the manufacterers as this might offend them:
    Using a camburg bedcage with a dmz sua kit?
    Cage is a cage right?
  19. Sep 7, 2022 at 6:28 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Should work just fine. Just make sure to cycle everything before placing the lower shock tabs
  20. Sep 7, 2022 at 6:29 AM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
